Question about Frigidaire ATF6000ES Front Load Washer
The drum on my front loading wash machine is very loose
You can shake it with your little finger. From what I have read this could be the bearings and the spiders. How hard are these to replace?
    Novelist:
    Champion:
  • 220 Answers
I recently replaced my bearings and seal for about $60. I could have bought the bearing cheaper online but I was in a hurry. If you do a search online there are several blogs about replacing these bearings. Here is a link for a service manual for $ 18 http://www.repairclinic.com/SSPartDetail.aspx?PartID=659075&PPStack=1 You pretty much have to disassemble the washer but it is not really that difficult depending on your mechanical experience. The manual should lay it all out for you. There are 2 notes on these frigidare washers: Sometimes the spider arms on the inner drum break and you will have to buy the complete inner drum assembly. I have heard they are warranted for 25 years, but they most likely will not warranty them if the owner does the work. Also, Frigidare does not list the bearings seperately, but you can buy the bearings from a bearing supply house, online or in your town. The bearing numbers are on the side of the old bearings when you remove them.
NOTE- The bearings that came out of mine were 6306-2Z and 6307-2Z (shielded) I replaced mine with 6306-2RS and 6307-2RS (sealed). The significance is that the shielded bearings offer minimal protection from water where the sealed bearings are built to seal out water/contaminants if you new seal ever fails. The seal I used was a CR15939 rubber coated seal.
If you need any other information, let me know
Hope this helps
Posted on Jan 17, 2009
  • jetfixr Jan 17, 2009
    I forgot to add that my washer is a Frigidare Gallery model, so this info may not be identical to yours.
The drum seems loose. When it spins to let the water out it will spin good then all of a sudden it will bump loudly
Search Results
    How to Diagnose Drum Problems in a Washing Machine ...
    ? 7:48
    https://www.youtube.com/watch?v=wUL5Wb1T71c
    Nov 19, 2013 - Uploaded by eSpares
    For all your washing machine spare parts go to http://bit.ly/1DumBrv The most common fault in a washing ...
    GE Washer Top Loader Out of Balance Shaking Repair ...
    ? 14:19
    https://www.youtube.com/watch?v=GA98ZmnzEfc
    Jul 12, 2014 - Uploaded by Mike Davies
    GE Washer that Shakes and is Load during Spin Cycle. step by step ... Washer Tub Seal Replacement - GE Top Load Washing Machine ...
    GE Front Load Washer Inside Drum Loose - YouTube
    ? 0:46
    https://www.youtube.com/watch?v=P8EcTTL2lcI
    Apr 4, 2013 - Uploaded by Wayne Meador
    I need help with my GE Front Load Washing Machine!!!! If you or anybody that you know can help me fix this, I ...
    Kenmore top-load clothes washer drum/tub is loose and bangin
Jan 08, 2016 | Washing Machines
Admiral washer machine tub appears loose and unattached in rrear
First of all is your machine working or not?
If it is working and it's a front loading machine. The machine drum is hanging inside the machine using strong springs that helps it to reduce vibrations during washing and spin cycle.
When machine goes into spin(dry cycle), it usually shakes a little.
Dec 08, 2014 | Admiral Washing Machines
Hi, I have a frigidare affinity front load washing machine and when it is running a cycle it sounds like the drum is banging around in the machine. It's a new noise, did something come loose? What
Hello gen0313 - From what you are describing it sounds like the unit could possibly have a broken shock/bearing or damaged tub. A certified technician will need to accurately diagnosis the bearing and pulling system behind the drum for repairs.
Feb 21, 2013 | Frigidaire Affinity ATF7000E Front Load...
My MAH9700 Front Loader washer is shaking a lot and making a loud banging noise when spinning.
unscrew the 4 screws inside the detergent dispenser and lift the top and see if the counterweight on the tub is loose,otherwise it may be the drum bearings going bad on the inner drum
Apr 01, 2010 | Maytag Neptune MAH9700 Front Load Washer
Nextra is shaking itself to bits and extremely
sounds like the bearing has gone possibly taken out the drum support to shaking could also be one of the wieghts has worked loose.
Mar 15, 2010 | Hoover Nextra HNF 3157 Front Load Washer
Washing machine drum is moving about it still washes but it spins with a knocking sound
front load or top load?
top load - basket retaining nut loose or hub worn, possibly rusted through basket
front load- main bearing shot or pulley nut loose
Mar 07, 2010 | Washing Machines
Washing machine makes noise on spin machine type LG
THE SOUND YOUR HEARING IS THE REAR BEARING BETWEEN THE STATOR AND THE DRUM. IF YOU'LL PULL THE BACK PLATE OFF THE WASHER IT'S PROBABLY STARTING TO GET A LITTLE DRIP RIGHT ABOUT NOW TOO. BEARING COSTS AROUND $20.00 OR SO AND IS RELATIVELY EASY TO CHANGE. YHE EASIEST WAY TO MAKE SURE IT'S THE BEARING WITHOUT PULLING IT OUT AWAY FROM THE WALL IS OPEN THE FRONT DOOR AND SEE IF YOU CAN SHAKE THE DRUM UP AND DOWN AND SIDE TO SIDE.
Sep 25, 2009 | LG WM-2277HW Front Load Washer
Broken shock and drum/seal leak
Power off the wall mains. Open up the machine panel to look interiors. See if any springs or shocks (known as dampers) have broken or come off. The dampers should not slide in & out freely, if they're defective, replace. Tighten all loose wires, which may have come loose, future probs, so you dont have to open up again.
Next level your machine, front legs way up, means your machine is tilting towards you. Then adjust accordingly so that u cannot shake the machine with both your hands. Lock the nuts, only the fronts legs are adjustable, for most machines. (will get back to u)
Mar 09, 2009 | Frigidaire GLTF1670A Front Load Washer
High vibration front loader
have u checked the bearings to do this u open the door place your palm on the front of the face panel and place your fingers on the inside of the drum and grab the inner drum and move your fingers towards your palm if there is movement then the bearings are gone and need replacing if there isnt then it could be the springs that are placed under the top they could be broken if not then replace your damper legs they may look ok but they will be down on pressure m
Mar 15, 2008 | Hoover AL130 Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
205 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
