Question about Kitchen Ranges
Elements work at maximum temperature regardless of settings.
Two of the elements have this problem. Is it the elements or the temperature controls? Where can I buy parts in Brisbane, Australia?
  • Kitchen Ranges Master
  • 8,220 Answers
  • Dan Webster
    Dan Webster Jan 17, 2009
    The Robertshaw 5500-200 "no push" or the 5500-202 "push to turn" is your choice, either one will work for the large or small eyes.
Two of my Hotpoint EW95 Halogen Double Oven elements have lost temperature control. When switched on they go to full heat and stay there regardless of setting on dial. What is wrong?
change switch if there is no control if talking cook top elements
Infinite switch burner control need model number in full for quote
Nov 18, 2014 | Hotpoint Ovens
Simpson alpha range
The simmer stat element control needs replacing with new one. Turn the power off before working on the switch.
May 29, 2014 | Ovens
How do I replace the heating elements in my Rheem water heater
Replace heating elements can be found at amazon, click here and take a look: Amazon com rheem heating element . I hope this was helpful... cheers
Jan 31, 2013 | Rheem 82V40-2 Fury Electric Residential...
Oven will not heatup
  1. Make sure the controls are set properly: that the oven selector switch is set correctly and that the temperature switch is set to the desired temperature. Where applicable, make sure the oven timer is set to manual.
  2. If nothing else on the Range, Oven or Cooktop is working then Check the fuse
  3. Test the oven elements
  4. Test the oven thermostat
  5. Test the oven selector switch.
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
Jan 18, 2010 | Ovens
Elements do not heat to proper settings
If both elements are not working properly then the problem is either the temperature probe or the control board.
Replace the temp probe first.
May 21, 2009 | Frigidaire 30 in. Electric Gallery Series...
Oven elements just stopped working
If I understand your use correctly, you were using the oven to heat the space? Or for baking?
Regardless, it sounds as though the elements have failed. If you used the oven for heating the space (with the door open) the broiler element comes on during preheat of the oven to get the oven to temperature more quickly. The elements are NOT designed to heat a space, and will quickly burn out if used in this manner.
Jan 23, 2009 | Ovens
Chances are that both elements should energize when starting up in bake mode. Since bake is by the very nature of the principle "constant heat" then the job of the control on the unit is to maintain an stable temperature for a specific period of time. Sooo... when starting up, both elements would be available to quickly raise the temperature. Once that temperature is reached then the bottom element would be all that is required to maintain the set temperature. Watch the elements for a period of time, until the "bake" temp is met and see if the bottom element is the only one energizing for the remainder of the time alloted.
Mar 27, 2008 | Kitchen Appliances - Others
Plug in element burner
Need to replace the switch behind the knob.
Sep 19, 2007 | Hotpoint RB757 Electric Kitchen Range
Kitchen Ranges Logo
53 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
