Question about Insignia LCDTV26 26 in. Television
Need code for motorola cable box with a insignia remote
I got a insgnia remote with my flat screen tv and and need the code to program it to my motorola cable box thru insight cable and need to know what to do to enter the code to
  • 11,896 Answers
Assuming you have the DRC800 remote:
Codes are 0467 or 1376
You can EASILY program the remote without a key code:
1. Press the "cbl" button
2. Press and hold "setup" button Until red light blinks twice
3. Press 9-9-1
4. Press power button
5. Press chanel up repeadedly until your cable box shuts off
6. Press "setup" button again
That should be all there is to it. You can do the same thing for TV,VCR/DVD,Audio, whatever
It's easier than it looks.
Here is a website with more info if you need it:
http://www.eastlink.ca/cable/support/documents/DRC800_User_Guide.pdf
Posted on Jan 17, 2009
I own an Insignia flat screen tv, NS-LCD27, & I was given the Insignia converter box, NS-DXA1; how do I program tv remote for the box? Thanks, frances b.
The digital to analog converters did not exist when the TV was built and the remote programmed. Thus you will have more luck programming the converter box's remote to control the TV. (At least with my converter box, the included remote could only turn on and off the TV. It would only change channels on the converter.)
Most universal remotes only have codes for devices released 6 months or more before the TV was programmed. So a new universal remote will probably control both the TV and the converter box. (Program the converter box using a code for LG or Zenith set top boxes if Insignia isn't listed. LG makes Insignia video products for Best Buy.) The remotes that are programmable by a USB connection to a computer are the fastest to set up.
A replacement remote for your TV is available here: http://www.mcmelectronics.com/partfinder.aspx?brand=&mdl=NS-LCD27&mode=part . An exact replacement remote for the converter box can be purchased at: http://www.remotes.com/remotes/servlet/rs?a=gmi&uuid=13055197980390&smodel=NSDXA1&brand_pn=INSIGNIA_NSDXA1 . The manual for the converter box (as a PDF) is here: http://cbsdallas.files.wordpress.com/2011/01/insignia-ns-dxa1-manual.pdf .
I hope this helps.
May 16, 2011 | Insignia Televison & Video
NEED REMOTE CODES INSIGNIA TV "IS TV040918"
Try the suggested codes contained in your remote user manual for the following brands: Orion, Emerson, Memorex, Sansui, Sylvania, Zenith. If you still need help or want to share a remote code that works, participate in our online community: Community@Insignia.
May 26, 2010 | Insignia IS 20" TV040919 TV
I need to program my att uverse remote to control my insignia high def tv. In order to do that I need the proper code to sync the two together.
Is that remote from ATT cable company? you can also Google the info for your remote or call the Cable Company. Your cable box should have a channel that list tv remote codes
Mar 18, 2010 | Televison & Video
Can't get my hannspree remote to work with comcast
10030 for the comcast dvr remote. Code is from NEC
Oct 02, 2009 | Hannspree HT09 28 in. LCD TV
Programming the Acquos Remote
There is a code out there to try.  The code would be 47.  Just follow the steps in your manual on how to program this box and you should be able to go from there. Can't garantee that it will work as that code came out with the newer tv but it should work.
Nov 08, 2008 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Insignia is-tv040919 remote codes
The Insignia is-tv040919 is a Cytron and the code is 11326. But no Comcast multifunction remote contains that code -- so you cannot enter it manually and the 991 search function will not find it. I discovered the make and code by the serendipity of having a cable box with a multifunction remote and several DTAs with the small, black two function remotes. I first installed the Insignia on a DTA and the remote programmed quickly. I just moved that tv to the room with the cable box with the multifunction remote and mayhem ensued. I got an $8 RCA 3 function remote today and it's working great on the Comcast cable box, a DVD player and, drum roll please, our old friend the is-tv040919.
Nov 01, 2008 | Insignia IS 20" TV040919 TV
Codes to operate a cable box with TV remote
Try code 038. If that doesn't work try 039.
Aug 05, 2008 | Televison & Video
SERVICE CODE
I have a 26" Insignia HD-TV and just found out the cable remote code (to connect TV with the cable box) is 0463.  If that's not what you need, try calling Insignia's help line at 877-467-4289
Mar 27, 2008 | Insignia LCDTV26 26 in. Television
Remote control code needed for this TV
Need to program my Insignia TV to my Direct TV remote. Need code
Nov 07, 2007 | Insignia IS 20" TV040919 TV
Insignia LCDTV26 26 in. Television Logo
911 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
