Question about ViewSonic VP181b 18.1" LCD Monitor
Service/Repair Manual for VP181b LCD
I have a Viewsonice VP181b LCD Monitor, that will not power up. I'm looking for a Service manual for it. I'll take any disassemble guide, or Repair Manual for it. Anyone have one? Thanks,
  • 1 more comment
  • Rog Mine Jun 20, 2007
    I have changed power cords with known working cords, and tried in other outlets, so the main power cord is not the problem. I wish it were that simple, but Thanks!
    I should also mention that the LED power light on the front does not come on at all. When it started having problems, I could turn it off/on and for a second I could see the Desktop, but now that won't even work. No Power, no Display, nothing.
  • memor99 Sep 12, 2008
    Same problems, the internal fuse is good. Only getting 2.8v dc on the output of the main power board. Any schematics or ideas?
    New Friend:
    Problem Solver:
Http://elektrotanya.com/viewsonic_vp181b_s-2_sm_1a.pdf/download.html
Posted on Dec 04, 2014
Firstly check main power is comming
Posted on Jun 20, 2007
SOURCE:
I HAVE A NEOVO E-19A MONITOR. ON BOOT UP SCREEN GOES BLANK AFTER ABOUT 5 SECS. TURNING OFF THE MONITOR THEN TURNING BACK ON BRINGS THE SCREEN ON FOR APPROX 5 SECS BEFORE GOING BLANK AGAIN. THIS IS REPEATED...
http://www.devicemanuals.com/guide/LCD/AG%20Neovo/AG-Neovo-S-19A-LCD-Display-English-Owner's-Manual-T1RjMU9Uaz.html
dlc.sun.com/pdf/820-0119-10/820-0119-10.pdf
http://www.scribd.com/doc/3082274/AOC-LCD-Monitor-786LS-Service-Manual
Use these training manuals, to troubleshoot and sort your issue out.
Above is a user manual, and a service manual, in the service manual, are the troubleshooting steps to perform to isolate the problem, and hopefully repair.
May 25, 2010 | Neovo AG 17" LCD Monitor
Viewsonice VX2835wm strongly magenta
check u'r degusing section u'r degusing is not working if it works then change CRT
Jul 20, 2009 | Philips 170B4MG 17" LCD Monitor
Monitor is going out...
hello
I am a technician-informatic. I have repaired about 80 Lcd Samsung monitors with theese problems. I offer the repair manual.
Manual has been done with the experience of the repairing Samsung Lcd monitors. Manual was made by me and shows how to open monitor, how
to solve dark screen problem, how to check and replace capacitors, how to solve the problem non-optimal mode (without reprogramming MCU or
changing the main board) photo are included. 100% functional. The repair process is very simple 30-40min. (does not need a lot of
experience in electronics and expensive instruments) and is not expensive. With this manual you can solve problems by yourself and save
money.
"Not Optimum Mode 1280x1024 60Hz"
- The monitor turns on but turns off by itself, the LED blinks green.
- If you detach from the PC points to "control cable" the picture runs continuously in the vertical direction or presents while line , and
as soon as it is reconnected, the monitor goes off.
- The monitor does not turns on and dont dispaly anything, the LED blinks green-lit, if you detach from pc points to "control cable".
- The monitor turns on, works well some time, but after a window apiers "Not optimum mode. Mode recommended 1280X1024 60Hz"
- The monitor turns on, works well only with low resolution 800x600, when try to change a window that reads "Not optimum mode. Mode
the manual you can find on ebay (my ebay name is asnerejas123):
Samsung monitor repair manual guide 710n,913v,510n more
220498646211
Riparazione - repair Lcd Samsung monitor 710n,913v,510n
220498645860
Reparaturhandbuch für Samsung 710n,913v,510n und andere
220499443698
Jul 01, 2009 | Samsung SyncMaster 940N Flat panel Monitor
MONITOR POWER SUPPLY BAD WHERE YOU PLUG IN BACK OF MONITOR BUT NOT CORD
It is inside the LCD the at the main board. You have to repair the board to make it function.
Apr 19, 2008 | Acer AL1916W 19" LCD Monitor
Samsung syncmaster 711p power issue
Its a general fault however all these units are under a 3 year warrantee the dates printed on the back, just call 08706010309 speak to a service engineer and they will arrange a swap out within 5 working days, no need to a receipt as they can tell the units age from the serial. the replacement will be under the same 3 years cover in my case it was for another 6 months
Nov 24, 2007 | Samsung SyncMaster 931B 19" LCD Monitor
Where do i get a power cord?
first, try the internet...http://www.pricegrabber.com/ and search for your model and then for optional accessories. if no-go, then... remove your car battery, then devise a makeshift 2-wire cable to deliver 12 volts to the proper pins on the back of your monitor. look for polarity markings 12v at 6.5 amps (70 watts) may be hard to find as a "universal" supply. many older pc case supplies (pre-ATX they are free at recycling centers) have the 12V available...just ensure the yellow and black (ground) wires only are used...may also need to ensure that "power ok" signal is set to activate said supply
May 27, 2007 | ViewSonic VP181b 18.1" LCD Monitor
Service Manual VISON 17" LCD Monitor
You can go to http://www.fastrepairguide.com , they have a lot of free service manual, included lcd monitor, lcd tv, plasma tv & etc. May i know, what's your lcd monitor problem?
May 10, 2007 | TDV Vison F173 17" Flat Panel LCD Monitor
ViewSonic VP181b 18.1" LCD Monitor Logo
531 people viewed this question
Top ViewSonic Computers & Internet Experts
Steve Allison
Steve Allison
Ekse
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
