Question about SanDisk Sansa e250 MP3 Player
Mp3 is Blue
When i was charging it my Sansa turned blue. (screen)
How can i fix this ?
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out:
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jan 17, 2009
It won't turn on and tried to charge it. Won't charge on anything.
Battery and Black screen Blue ring: Remove the back and check and see if the battery isn't fully connected. Black screen Blue ring also push softly but firmly on the Rubber rectangle above the battery (This is the Chipset For the screen,and memory ) and put the back on.
Jun 25, 2010 | SanDisk Sansa e260 MP3 Player
My m3 player froze while charging and now it wont turn on
I held it in the off position while at the same time pressing the menu shut off, then I restarted it. It will repair the media itself.
Jun 26, 2009 | SanDisk Sansa e250 MP3 Player
Black screen, lit up blue wheel ,won't turn off or on
Goto >
There is a FAQ page here that might help you.
May 29, 2009 | SanDisk Sansa e260 MP3 Player
Sansa e250
hold the power button for a SLOW 20 sec, then power up with NO PROBLEM!
Aug 31, 2008 | SanDisk Sansa e250 MP3 Player
My mp3 doesn't work
my player is 2gb .but now it shows 0mb
Jul 14, 2008 | SanDisk Sansa e200 MP3 Player
Sansa e250
Take the screws out of the back, take the battery out then put it back in again. This worked for me.
May 02, 2008 | SanDisk Sansa e250 MP3 Player
Blue lines
Try to reset it with a needle at the a hole on the side where it says reset button (it says in the back next to the hole). I hope that can take of the problem.
Jan 15, 2008 | SanDisk Sansa e260 MP3 Player
Mp3 player wont play songs or anything
Only 2 suggestions here: 1) Make sure your HOLD switch is not enabled. 2) Try to update the firmware If neither of these work, time to send the unit back to Sandisk
Aug 09, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
15 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
