Question about HP PSC 950 All-In-One InkJet Printer
Dry cartridge how do i get it out?
    President:
  • 2,692 Answers
Directions are in your manual.
HP Website to download manual from:
http://h10025.www1.hp.com/ewfrf/wc/product?product=60259&lc=en&cc=us&dlc=en〈=en&cc=us
Posted on Jan 17, 2009
It only pirnt red
Cartridge depleted or contacts dirty on cartridge. Remove cartridge clean contacts replace. If does not work replace print cartridge. Liquid toners dry out dry toners last long time but contacts get dirty. Clean with acetone or nail polish remover.
Jul 05, 2015 | Canon Pixma Mg5220 Wireless Photo...
No print even on test print cartridges say the ink is about a quater left in both
Cartridge might have dried up, remove and use a Qtip with nail polish remover and rub over bottom part of cartridge where lines of micro sized holes can be seen, usually there is some ink dried there. Ink is water based until dry.
Oct 21, 2010 | Lexmark 1100 Color JetPrinter InkJet
CHANGED COLOR CARTRIDGE AS I HAVE MANY TIMES BEFORE. NOT WORKING. MESSAGE IS THAT THIS CARTRIDGE WAS NOT INSTALLED CORRECTLY. HAVE TRIED EVERYTHING - HELP PLEASE ! thanks
good day sir/ma'am, hi, the reason why the printed sends the mesaage "cartridge not installed correctly" mean that it cannot get ink from those cartridges due to dirt and dust, or the ink on the cradle dried out, you may need to clean the cradle, the part were it houses the ink cartridges, since dried ink is solluble to water, use warm water to clean the cartridge. you can remove the cradle or use a dipstick with cloth wrap around and dip it to the dried ink. If the dried ink has soften enough you can place again your cartridge and test print again, do this several times to get the ink flow again. Carefull not to moisten the electronics part of your printer. thats it.
Nov 19, 2009 | HP PSC 950 All-In-One InkJet Printer
Cleaned heads about 10 times. Still get no magenta and a light black Also replaced magenta cartridge
Remove the cartridge from the printer. Wipe the cartridge electrical contacts and the corresponding carrier contacts with a dry fabric or paper towel. Then moisten a paper towel and wipe the cartridge printing surface (not the electrical contacts) until clean. Also you can hold the moist paper towel against the cartridge printing surface for a couple of minutes to dissolve dried ink. As a last resort, I have immersed cartridges in water to dissolve the dried ink. Dry all cartridge surfaces with a dry paper towel then reinstall into the printer carrier. Good luck.
Aug 22, 2009 | Office Equipment & Supplies
Hp photosmart 2610 not recognizing new color printer cartridge (97)
Print cartridge
When the print cartridge contacts are dirty and the printer cannot detect/communicate with print cartridge.
Clean the contact points on the cartridges with a dry, lint-free cloth.
1. Open the top cover of the printer.
2. Remove the print cartridges.
3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth. Use a dry, lint-free cloth to remove moisture from the contacts.
5. Insert the cartridges back into the printer.
6. Close the top cover.
7. Try printing again.
If you still cant communicate try with new cartridge .
Aug 19, 2009 | Office Equipment & Supplies
Replaced all cartridges will not print black
Before you replaced the ink cartridge, did you let the ink in the previous cartridge run completely dry? If you did, then the printer heads are completely dry and it will take awhile for ink to start flowing again.
Jul 31, 2009 | Epson Stylus CX6000 All-In-One InkJet...
May be cartridges become dry due to unused
renove the cartridge from the printer now take a small bolwl and put some hot water in it put the ink nozzel of thr cartridge for 1 min in the hot water and then clean the cartridge with a soft cloth repeate the step 1-2 more time and now try printing
Jul 12, 2009 | HP Office Equipment & Supplies
Ink cartridges don't last and can not use one without the other.
Sounds to me like the cartridges are drying out quickly. Make sure you are using original cartridges and not the remanufactured ones or 3rd party ink cartridges. Also try to use your printer at least once every couple of days even if its just to print a document cause the longer you go without using it, the more of a chance that the cartridges will dry up.
Also one other thing, when the cartridge dries up you can try putting the bottom of the cartridge in a dish with warm water so the hole is covered with water, you can let it soak like this overnight then wipe off the bottom of the cartridge so its dry and then reinsert it back into the printer and see if that takes care of that issue, hope this helps.
Let me know if you need further help.
May 14, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Ink cartridges
The symtoms of a dried out cartridge is white lines through the printed letters.
I've seen brand new dried out cartridges.
Aug 08, 2008 | HP DeskJet 882c InkJet Printer
Light is flashing
check cartridge compatibility first:- HP Deskjet 810c HP15................black cartridge compatibility HP 23 ....................colour cartridge compatibility Issue ---A print cartridge is missing. Solution Install the missing cartridge. Issue --The printer detects a faulty, incompatible, or improperly installed print cartridge. Solution 1. Open the top cover of the printer. 2. Make sure the correct print cartridges are installed. Click here to go to the printer/cartridge compatibility chart. 3. Replace or reinstall the print cartridges. 4. Close the top cover of the printer. Issue ---The print cartridge contacts are dirty and the printer does not recognize the print cartridge. Solution Clean the contact points on the cartridges with a dry, lint-free cloth. 1. Open the top cover of the printer. 2. Remove the print cartridges. 3. Clean the copper-colored contact points on the cartridges with a dry, lint-free cloth. NOTE: Do not wipe the nozzle end of the cartridge or touch the silver-colored nozzle plate on the bottom of the cartridge. 4. Use a dry, lint-free cloth to remove the moisture from the contacts. 5. Insert the cartridges back into the printer. 6. Close the top cover. 7. Try printing again.
Sep 11, 2007 | HP DeskJet 810c InkJet Printer
HP PSC 950 All-In-One InkJet Printer Logo
21 people viewed this question
Seeker5211
Seeker5211
