Question about Samsung HLN5065W 50" Rear Projection HDTV-Ready Television
Samsung 50" DLP Lamp died, new lamp will not light`
While unit was powered up and working, picture turned to black and white, froze - then went all black with snow band on the bottom. After short while powered off, the unit came back up normal - shortly there after the blackout sequesnce reoccurred. Trouble lights indicated lamp failure, replaced lamp unit will not light up new or old lamp. cannot even get the maintenance mode to display on the screen - only 3 lights indicating lamp failure.
Suggestions?
  • scott_stanto Jan 26, 2009
    Thanks ND,
    Yes I replaced the ballast to no avail, unit makes the same struggling sounds at power up, and never lites the lamp. One thing I have found short on a lot of posts - if you continue to help people in this forum, is that there is a counter that should be reset when the bulb is changed - sequence is from the maintenance manual
    "Power off, mute,1, 8,2, power on" - it will put the unit into service mode. Please share it if you like. Thanks for your reply - I've got a deal for any authorized center that needs parts...
    Enjoy.
    Scholar:
  • 49 Answers
Bad news.  Mine did the same thing.  Mine is the 61", but the internals are basically the same.  I replaced the lamp and the problem was fixed.  Then after a couple days, it died again.  I replaced the ballast, to no avail.  Took it to the certified repair center and they said I needed a new DLP Light Engine.  They wanted $1250 to fix it, but I was able to order one online from partstore.com for $700 and fixed it myself.  No problems since.
Your certified repair center will charge a minimal fee to diagnose and then you can fix it yourself if you choose.
The easist fixes for the lamp problems are A) replacing the bulb and B) replacing the ballast.  Anything else, you'll want a certified tech to diagnose the problem.
Posted on Jan 24, 2009
  • Nick DelRegno Jan 29, 2009
    Thanks scott.  I don't believe the lamp hours counter has to be reset.  It is more informational in nature.  With that said, it is a best common practice to reset the lamp hours counter when you replace the bulb, according to the directions you provided.  At a minimum, it implies how soon you might have to replace the next bulb.  Strangly enough, I have had my 61" for 5 years and my 50" for almost 6, and haven't had a bulb fail yet.  I have had ballasts, light engines and digital boards fail, but not the lamp... :-)
Got a Samsung dnie model code spp4251x/data tv when powering up the front light comes on but no picture or anything anyone got some good info??
tv seems to turn on but no picture? - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - ... Samsung Dlp TV (HLR-5067W) it seems like the TV turns on butthere is no picture. ... the lamp is, light is visible from where the lamp is located but no picture. DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
The timer, lamp, and standby/temp. light are flashing?!
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...I Have A Sanyo TV I Can Hear But Black Screen Im 14 And Dont Know What To Do ! .... power button the power light goes from red to green, the screen flashes on then goes black ....Troubleshooting LCD Backlight Failure Samsung LNT-4066 ...
Samsung plasma tv repair blinking light no picture ...
Jan 09, 2016 | Samsung Televison & Video
SMASUNG DLP 50 HDTV
defininatly the fan that cools the lamps is either not working or going out and needs replaced
Nov 12, 2007 | Samsung DLP HL-P5663W 56" TV
Power light blinking red..tv won't come on after replacing lamp
DLP TV Repair Tutorial - DLP Bulb Won't Turn On - YouTube
? 14:13
https://www.youtube.com/watch?v=5frOnh58Z6M
Jun 26, 2013 - Uploaded by ShopJimmy.com
DLP TV Won't Turn On Common How to Replace Ballast DeadTV ... solid green power light plus sound ...
• New Lamp Doesn't Turn On? Try This! - Fix Your DLP - FixYourDLP.com
www.fixyourdlp.com/forum/viewtopic.php?t=19
Mar 12, 2009 - 50 posts - ‎36 authors
Mine did the same thing after replacing the lamp. ..... TV won't turn on and Color Wheel is GOOD, Temp sensor is GOOD, Ballast is GOOD, and ... • NEW Bulb- still not working
Jan 14, 2010
• Resetting the Samsung DLP Lamp Counter/Hour Meter
Mar 20, 2009
• Samsung Dead Lamp, Black Screen, or Intermittent
Mar 12, 2009
More results from www.fixyourdlp.com
Samsung DLP: replaced lamp however tv won't turn on - HDTV ...
Dec 09, 2015 | Televison & Video
Samsung HLR5667W 56-Inch DLP HD TV not working
A black and white picture usually indicates the color wheel has failed or the DMD board has failed. Call 1-800-samsung to find neaREST SERVICE CENTER.
Jun 16, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
The tv went black no sound or picture. We
U have a solid green light from the LED power light indicator right?U have this DLP tv for awhile like two or three years,and use it alots right?Never change the lamp and the ballast right?Change the lamp and the ballast should solved ur problems.
Apr 01, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
I own a Samsung HL-R5067W 50'' DLP. Set is about 3 years old. Recently I heard a loud pop while viewing, picture distorted, but never went blank. I turned set off. When turned on again a loud whining noise...
Check your color wheel. There is a DIY guide for replacing the color wheel. Mine did the same thing yours is and my color wheel was all busted up. Unfortunately after replacing the color wheel my set continues to do the same thing, but this could mean I need to replace the ballast as well.
Sep 20, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung HLS4266W 43" dlp
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Dec 24, 2007 | Samsung DLP HL-P5663W 56" TV
Samsung dlp
HLS4266W 43" dlp. In less than 1 yr whining grew worse, but did know what it was. Year passed with warranty and lamp went out. Replaced lamp. Worked for 3.5 hrs. Turned on next day and did not work. Got another lamp, but did not work. Figured out might be color wheel. Replaced it too. TV started up. Watched that night. Turned on next day, heard loud pop. Lamp never came on. Withdrew and reinstalled lamp a couple times to see if that worked. Did not. Currently, with new lamp and color wheel installed, lamp light blinks, but no lamp comes on. What now?
Sep 17, 2007 | Samsung HLN5065W 50" Rear Projection...
Samsung HLN5065W 50" Rear Projection HDTV-Ready Television Logo
151 people viewed this question
Henry  Thomas
Henry Thomas
