Question about Toshiba 46HM95 46" HDTV
Orange/muddish color?? I'd bought my tv in November 2005 and about a year later, i had almost all the lamps replaced. Ain't it sucks? Then, 5 months afterwards, i have this problem. The color seems odd on the areas when the images are ...say... faces, orange-whiteish walls, tables. Other colors are fine. I think something is wrong with its color lamp. It must be the orange spectra that causes it. I'm new to these kindda problems so please guide me. Thanks
  • 3,130 Answers
Re: Orange/muddish color??
Sounds like a color wheel or a light engine problem problem my friend. This set is a DLP type projection set. The light engine part number is 234054 and cost $456.00. Good Luck
Posted on Jun 20, 2007
0 characters
3 Points
Bought Samsung dlp h-l 5667w new in 2005. Replaced lamp, fan, and color wheel in 2008. Now lamp lights up and lamp indicator on front lights up, fans turn on, but tv picture will not show. After a few...
It time to replaced the tv projection lamp again,the tv projection lamp life span have ended.The tv projection lamp life span only last 2000 hrs.Average out like 1 1/2 or 2 years max for tv on watches 4 or 5 hrs of tv every days.
Jul 07, 2011 | Samsung HLR5667W 56" Rear Projection HDTV
When you turn it on, the green LAMP light goes on, then it clicks and the STANDBY/TEMP red light goes on, then clicks and back to the green LAMP light. It does this a few times, then The TIMER green light...
Usually if all 3 indicator lights come on this could be the color wheel is not functioning or the DINe chip needs to be re-soldered. Be sure the lamp door is closed all the way, but the color wheel needs to be looked at first.
Nov 17, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
Mitsubishi WD-52327 TV won't consistently turn on, new lamp
the problem is in the power supply circuit
capacitor may be or so the click mean theres cap are leakink or get dry that why is so long to power on.
hope that give you a idea.
May 05, 2010 | Projection Televisions
Just had the bulb replaced in the beginning of November the T.V. just died on night while watching it. All 3 little lights started to blink at me. I was told it may not be the bulb seeing it was just...
It depends on what kind of bulb you purchased and where you purchased from. If you go to an authorized distributor like, then you're sure to get the OEM--in this case a newer Philips 100W-120W UHP lamp. If you buy from a cheap replacement store, then you're lamp can last anywhere from 1 month to 1 year.
That being said, it may be another component such as a ballast or color wheel. Do you hear sounds or smell anything funny? Those can be telling signs of what's wrong.
Feb 04, 2010 | Samsung Projection Televisions
Toshiba 52HM95 Light Engine
this is the worst investment I have ever mede after replacing the bulb for every six months the color wheel goes out and its 750 to repair
basically after the initial arm and a leg the TV came back for the other ones And the customer service from Toshiba is even wors than the TV I guarantee you will end up cursing at them before you hang up in there face after the smart *** remarks If you buy this TV your as stupid as I was
Toshiba is the worst brand to buy
Jul 27, 2008 | Toshiba 52HM95 52" HDTV Projection...
Light green and pink spots on my hd tv!!!
Hi--Bought my panasonic pt-52lcx65 on sale for $2200 in 8/05. Replaced the lamp for about $300 in 1/08, just prior to Superbowl. Admittedly, this was to be expected after family members watched lots of tv over 30 months. However, two months later the blue spot emerged in 3/08, and red spot emerged 5/08. Set looks decorated by a Andy Warhol or Van Gogh wannabe. I'm looking for a fix it solution. Dr. Bob Heiliger, Lebanon, OH.
Jun 08, 2008 | Panasonic PT-52LCX65 44" HDTV
Color Fading on Zenith E44W46LCD
you neeed to change the lamp. the access is located on the right side of the television. you can buy the lamp for about $125 from
Mar 10, 2008 | Zenith E44W46LCD 44" Rear Projection...
How long does a lamp/bulb of a Toshiba DLP 46HM95 46 in last?
Your bulb may be blowing because of airflow issues or power cycling issues, first does your outlet get switched off at any point in time? if so you may be killing the bulb before it cools, if you turn the set on/off alot and or restart it after off quickly this could lead to permature bulb failure, if the original lamp was not replaced with a proper lamp to match the ballast it could blow the bulb. If your tv is too near a heat vent or the airflow thru the set is not adequate it could blow the bulb.
Aug 01, 2007 | Toshiba 46HM95 46" HDTV
Toshiba 46HM95 46" HDTV Logo
180 people viewed this question
Top Toshiba Projection Televisions Experts
Jaime Hernandez
Dave Naylor
Dave Naylor
Are you a Toshiba Projection Television Expert? Answer questions, earn points and help others
