Question about Clarion MAX385VD Car DVD Player
No sound I have the Clarion MAX385VD and everything was running great until one day nothing worked. The unit turns on but no sound coming out of any speakers. I also get this wierd red symbol in the bottom left corner that looks like a remote or cell phone with a "Y" and an "X" through it?
Lol hope you figured this out, your power muted the unit.
Posted on Jan 13, 2011
I have forgotten the password on my Clarion MAX385VD and the unit has subsequently locked. Is there a bypass code for the remote or what can i do. I have contacted Clarion in Mylasia and httey referred me...
The only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C7000000 + + + + on a label somewhere on the metal casing.
(There are usually two barcodes on one label. The one required is the lower one )
T
If not then it will only be available from your Main Dealer or a Decoding
Jul 18, 2009 | Clarion MAX385VD Car DVD Player
Clarion XMD3
This is typically the output IC not working. This can be due to a speaker short. The unit will need to be repaired or replaced.
Jul 05, 2009 | Clarion XMD3
Park brake switch
If you have the old firmware then all you need to do is ground the parking brake wire..
if you have the new firmware(just bought the system) a toggle switch is involved:
1 - connect e-brake wire from dvd unit to the switch
2 - connect a ground wire from switch to the unit chassis(any good metal grounding surface will do)
3 - pop in a dvd, toggle the switch back and forth 2 or 3 times depending on what wire you placed where...and voilaa!! your dvd system should work in motion!!
Jun 29, 2009 | Clarion MAX385VD Car DVD Player
No video
all u need to do is run hand brake wire to a on off switsh and then ground when dvd playes u flick switch on and it trips screen mine works great
Mar 23, 2009 | Clarion MAX385VD Car DVD Player
No sound
you need to buy the wireless head phones for this unit. try the dealer or best buy
Mar 09, 2009 | Clarion MAX385VD Car DVD Player
I am installin a Clarion DB185MP auto source unit. It's on but no sound, when I turn volume control it says "amp ground" on screen- a code not in manual. I have reset unit but get "amp ground code". ...
Hi
It sounds like its wired inproperly, get a amp and note that everything is set up and wired properly, I assume the speakers are working fine could you test them with another unit?
Feb 24, 2009 | Car Audio & Video
I just installed a Clarion max385vd. When we turn the headlights on, the buttons and screen illumination on the head unit keep flashing from dim to bright. Everything else is working perfect.
illumination wire does not need to be installed on this model. depending on your car, it may use odd voltage for the dash lights. Clip and tape off the illumination wire going to the harness.
Dec 26, 2008 | Clarion MAX385VD Car DVD Player
No volume
The Bose system in the Z is wired to control the entire car's speakers. Each speaker has its own amplifier, and the OEM head unit puts out a line-level signal to each amp. Your Clarion unit puts out speaker-level signal (in effect, an amplified signal), into the Bose amps, and it's probably overdriving them and putting them into shutdown.
Your best bet is to replace the Bose speakers with aftermarket speakers meant for a speaker-level drive (which is what I did in my Z, and never once regretted it). If you do so, you'll need to run new wires to the speakers, or if you use the OEM wiring, you'll need to unplug the amps and run the wires from the amp harnesses directly to the new speakers. I think there is an adapter harness you can use that will tap into the line-out jacks on your Clarion, so that a line-level signal can be sent to the Bose speakers - I'd do a google search for "Metra harness 300zx" or something along those lines (Metra makes the lineout harness adapters - I use one in my Audi).
Sep 16, 2008 | Clarion DXZ755MC CD Player
Clarion DXZ655MP Speakers worked then stopped...
sounds like the ohm load of your speakers is incorrect and overloaded the amp,....check all your specs, i.e. max, min ohm load on stereo, and speakers,...this stuff is important and must be within the range allowed or stuff like your experiencing happens,.....it's happened to me before,.....fried my amp because i had house speakers in my van, was great for about 3 loud days,....good luck, cracklin joe,.......
Sep 26, 2007 | Clarion DXZ655MP CD Player
No sound.
Disconnect speakers one by one and reset the unit each time. If the speaker is blown, or the wires are frayed, it will shut down the internal amp. Also check the fuse in the back of the radio first, it should be near the wire harness. Power cycle the unit as well, unplug it from the power source, plug it back in. Hope this helps.
Aug 16, 2007 | Clarion M475 CD Player
Clarion MAX385VD Car DVD Player Logo
149 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
