Question about Fantech AEV1000 Air Exchanger 120 cfm
I have central air and heat(the unit is about 8 yrs old)..when my heat kicks off there is still extremly cold air continually coming through the vents as if there is still a fan going,but it's not from the outside unit ..there is another unit of some sort located adjacent to the outside unit located under my home...I read about air to air exchangers which I am assuming is what that unit is..not sure though ,but as I said earlier the air that is coming through the vents isn't caused from the outside unit and the air that is blowing through is just as cold as the temp outside and being winter time is very cold ...I have a vent about 3 to 4 feet from my bed that I actually have to close because of the air being so cold...could this be a problem stemming from the unit from under the house and if so what would you recommend? Thank you for any assistance you can offer in this matter and God Bless, Jimmy Ray Wix, Franklin,Ky
  • 21 Answers
Does it look like a box with four flex ducts or pipes coming off of it? if so its a fresh air/ heat recovery ventilator, supposed to bring in fresh air, keep in mind, the outdoor unit does not bring in air, it is just a pump to the indoor unit. that unit may be running independently, or wired incorrectly
Posted on Aug 06, 2009
Central heat not blow hot air
you posted in november if it was very cold auxillary heat issue.
Nov 11, 2013 | Goodman Heating & Cooling
Goodman # GMS81155CNA light blinks 4 times - furnance won't light and blower runs all the time - it's cold - please help
The 4 blinks means that the high limit switch or the regular limit switch are tripped... try to find the high limit switch... it is usually near the blower...there will be a red reset button in the center of it... push it in and the unit should work again...
if the regular limit switch is kicked you may have to replace it for the unit to work again...
This often happens after a power failure if the unit was running at the time of the failure. If you did not have a power failure, then find out why the limit switch kick out...
Here is a tip that will help you try to figure out why yourfurnace is not working.
BasicFurnace or Heating System Troubleshooting
heatman101
Apr 23, 2011 | Goodman GDS81155CNA Open Flame Mid-Size...
Central heater kicks off and on constantly
It is a strong possibility the flame sensing electronic thermocouple has become contaminated. Buildup on it causes malfuctioning like you described. To remedy it you simple remove the flame sensor and clean it with steel wool. here is a video I found on line:
Furnace cycling frequently
Jan 06, 2010 | Mr. Heater Model MH12TS - Single Tank-top...
Will not blow cold air
pls check your remote setting
Apr 27, 2009 | Heating & Cooling
Furnace runs on heat, air conditioner does not
If you have a Gas furnace in the Attic then the answer is yes. The outside condenser will not run if in fact you have a gas furnace.
Feb 11, 2009 | Ruud Central System Air Conditioner
Central heat/air unit for home blows cold air
could just be heat trapped in ductwork for attic temp or from not running for more than a few hours.
Jan 13, 2009 | Haier HC48C1VAR Central Air Conditioner
Central heat not blowing warm air
Do you know if your unit is a heat pump or not? Sounds like it may be an electrical problem and yes you would need to call a service tech.
Dec 03, 2008 | Intertherm P3RA-048K Air Conditioner
My central air never kicks off
Sounds like you need to recharge it .. To tell while the unit is running go outsiode and feel the large insulated copper line going to the unit it should be cold to point od sweating like a can of coke you take out of the refrigerator and sit on the counter. also feel the air coming out of the unit outside it should be warmer than the outside air if not your freon is low
Jun 09, 2008 | Weather King 10AJA2501AH Air Conditioner
No cold air
if unit is more than 5 yrs old dump it!!! most frigidaire models just dont last...that is why they are so cheap...get it???
Jun 09, 2008 | Frigidaire FAH085N1T Air Conditioner
20 year old central a/c heater not working
Check your thermostat and mode selector setting, thermostat setting should be set at warmer and mode selector setting should be at low heat or hight this is applicable for manual unit.
If it is a remote control just set the remote to heat mode.
sample only
Jan 02, 2008 | GE Quiet-Aire Ductless Split System Air...
Fantech AEV1000 Air Exchanger 120 cfm  Logo
277 people viewed this question
Top Fantech Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you a Fantech Electrical Supply Expert? Answer questions, earn points and help others
