Question about Xerox DocuColor 12 Printer
System fault 3-380
First it tell me thatwaste basket is full and i went ahead and dust it then turn on machine and it gives me system fault 3-380
    Novelist:
  • Xerox Expert
  • 297 Answers
Remove and reinstall the print cartridge. If the error is still there you should replace the print cartridge.
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=21,E=0000000001181489224,K=5792,Sxi=0,Case=obj(18087)
Posted on Jan 17, 2009
Nespresso won't reset after emptying capsule basket. Lights flash as if basket is still full or water is empty??
Call company ASAP..
and they may give you a new one..
after my research.. many have a lot of troubles,
some are different than yours.
or call 1-800 555 1212.. for company information
to call company..
Bummer not having Coffee when you want it.
Apr 06, 2013 | Coffee Makers & Espresso Machines
My hotpoint aquarius wmf720 keeps flashing either door or f-10, can anyone help??
Please read in full before attempting any repair.
p.s. Before working on machine "turn of the power".
Only carry out if you are confident that you can carry out safely.
Note check small black hose to the air pressure switch is connected,
When machine is turned upside down, the hose has a tendency to come off.
If unsure call a service engineer.
My machine just had the flashing "door" fault.
On carrying out fault finding checks,
I Found that the main PCB had a built up dust.
This dust was in black lines going between components of the board.
Cleaned around components of the board with a small soft brush.
assembled & tested okay 2 months ago & still working.
Mar 31, 2013 | Hotpoint Aquarius WD640 Front Load...
When water starts coming in, washer gets a F54 code. what should i check?
This is what the fault is telling you:
F54(F54)-Motor Control Overcurrent
An overcurrent condition is either a wiring problem (lower harness) or a motor problem. (I.e short)
F then 54 flashes when the machine/motor control detects high current for the motor module.
Does basket turn freely? If not, determine cause of friction.
If basket turns freely, see TEST #3.
Test 3 is on this link just below mid page:
http://www.appliancepartsquick.com/WhirlpoolCabrioWasherFaultCodes.html
You will also need to perform Test 1 same page to verify any repairs.
Kelly .
Sep 20, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore Elite Oasis 110.27032603 f50 fault code. I am reposting this at the request of one of the gurus offering advice.I may be making this too hard but I went thru the diagnosis procedure in the repair...
The F50 error code indicates that the RPS (rotor position sensor) detects no motor rotation. Check to see if the basket spins freely. If not, you could have an item caught between the outer tub and the inner spin basket. A toy or other item underneath the washer could also prevent the basket from spinning and would result in this F50 code.
If the basket spins freely, you could have a wiring failure that would prevent the motor from spinning.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@@@@
Jun 17, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
No Suction + loud Noise
motor is probably is full of dust or needs replacing
May 11, 2009 | Vacuums
'Full light' blinks on and then off when you replace shred basket. Aurora AS1712x shredder. It's not full, won't work at all.
The sensor or button that tells it it's full, probably has paper dust or something jamming it. Clean it up without liquid and it will probably work.
Apr 24, 2009 | Office Equipment & Supplies
WASTE BASKET NEED CLEANING. AFTER CLEANING IT AND REPLACE IT THE MACHINE GIVES ME SYTEM FAULT 3-380
Waste basket? Do not know what you mean. 3-380 most likely dirty silver patch on IBT belt. Caused by bad drum{leaking}
Jan 17, 2009 | Xerox DocuColor 12 Printer
Gibson front load washer will not spin
well lol thats what i was going to tell you to do if you didnt hear the crunching sound with the power off but good for you
Mar 28, 2008 | Washing Machines
"OL" error message
I believe that I had this same problem. The machine was skipping the wash cycle. After the water level rose to where you would expect the machine to go into an agitation cycle to wash clothes; it would start a spin cycle and drain the water. In the process of spinning it would stop to display the OL message over and over again as quick as you redistribute the load.
I found the problem to be clothes that got stuck underneath the impeller (round thing at the bottom center of the basket). Somehow I also had clothes get pulled down and got stuck underneath the basket next to the lint filter, these items were shredded to the point that they probably were not causing any issues, none the less they should not have been in there. Even though it was not the problem, I went ahead and took out and cleaned the lint filter since it was within reach.
This machine works a bit different then other machines. The agitation cycle is dependent upon the basket floating up and disengaging from the drive shaft. I guess the clothes that got stuck beneath the impeller did not allow the basket to float high enough to disengage from the drive shaft. Because the basket was still engaged to the drive shaft the drive motor would spin the basket and start a drain cycle rather agitate the load to wash it. The imbalance of the basket caused by the clothes stuck underneath the impeller kicked of the OL error since the basket was spinning at an unacceptable angle. I am not a repair dude but based on my observation of what I did to fix the problem this explanation works for me.
I've attached some pages of a repair manual that I found on-line to illustrate the areas that I am referring to.
Mar 16, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Basket sticks - FrancisFrancis X1
I have the X1 and have this problem. I do two things - the first being (paradoxically) to tighten the handle a bit - that often frees the basket. If that doesn't work, I loosen the handle (to the point where it's quite loose) and then turn the pump on - that gives enough pressure to the basket to free it. So far, that's worked for me 100% of the time.
Good luck! -Greg
Nov 16, 2007 | FrancisFrancis! X1 - Stainless Steel...
Xerox DocuColor 12 Printer Logo
218 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
