Question about Philips MX5500D System
Disk changers won't open
When we turn the system on and select disk (1 through to 5) the unit makes a sound as if changing disks but will not open any of the compartments. I am hoping that my one and a half year old did not circumvent my sophisticated security system on the entertainment cabinet (a twistie tie around the handles) and jammed a disk or something into one of the disk compartments, Are there any other likely scenarios and associated fixes or will I have to take it apart or worse pay someone else to.
    President:
  • 3,130 Answers
These mechanisms are pretty complicated, and yes there could be a goodies jammed inside the unit to prevent the unit to operate. But a lot of the times when these units jam up, it is because of the unit going out of timing due to a broken gear. This really should be looked at by an authorized Phillips servicer, as they would have all of the proper documentation and equipment to service it properly. Good Luck
Posted on Jun 20, 2007
SOURCE:
Disk Changer won't open
What model RCA disk changer?
Jul 19, 2013 | Audio Players & Recorders
Promblems with LG LHT 874
Troubleshooting Solution
  1. Lift disk changer doesn't work comes message "Disk Error"
  2. Lift disk changer work fine but doesn't load a DVD
  3. Power light is ON but doesn't want to Power UP
  4. From the beginning start DVD movie the picture distorted and freeze
Your solution is #3 problem w/Main Board
avsystemparts.com
1. Possible Problem w/ Main Board PCB
2. The dive laser assy replace. or full complete 5 Disk changer ROM
3.More chance problem w/ Main Board
4. Problem w/Main board need replace it.
Dec 11, 2011 | LG LHT874 Theater System
Bose system plays disk one beautifully,but when changing to disk 2 it says reading disk and then "disk error"....difficult to remove disk...
hi,
There is some problem with the timing of the changer mechanisum of the player. As it is very complicated mechanisum you should need a good reparing experence to rectify the same.The mechanisum is not properly selecting the disk 2. Try to consult the bose autorised servicing center or any trusted electronics reparing shope near you.
ok
Sep 04, 2011 | Bose Wave music system Multi-CD Changer...
I deleted the administrator my mistake now i cannot login to windows can I reset to the factory settings
hi, hope this helps,
1. Make sure the computer is turned off.
2. If any peripheral devices, except the optional external CD-ROM drive unit
(CE-CD05), are connected to your computer, disconnect them.
3. Turn on the computer.
4. When the message Press <F2> to enter SETUP appears, press F2. The
Setup Utility opens.
5. Insert the Product Recovery CD-ROM disk 1 into the CD-ROM drive.
6. In the Exit menu, select Load Setup Defaults; then, press Enter twice.
7. In Boot Sequence of the Main menu, set CD-ROM Drive to the top of the list;
then, press ESC.
8. In the Exit menu, confirm Exit Saving Changes is highlighted and press
Enter twice.
9. Read the message on the screen, and select the operating system which you
had selected for the first time you use the computer; then, press Enter.
You cannot change the operating system from the first choice.
10. Read the message on the screen, and select the way to recover your system;
then, press Enter.
11. Read the message and select Continue; then, press Enter.
12. Read the message and select Continue again; then, press Enter.
13. If you see the message asking you to insert the Product Recovery CD-ROM
disk 2, remove the disk 1 and insert the disk 2; then, press Enter.
14. If you see the message asking you to insert the Product Recovery CD-ROM
disk 3, remove the disk 2 and insert the disk 3; then, press Enter.
15. If you see the message The Operating System has been recovered
successfully, remove the Product Recovery CD-ROM disk 3. The system will
restart automatically.
16. When the message Press <F2> to enter SETUP appears, press F2. The
17. In the Exit menu, select Load Setup Defaults; then, press Enter twice.
18. In the Exit menu, confirm Exit Saving Changes is highlighted and press
Enter twice. The system restarts.
19. Set up Windows, following the instructions on the screen. When you finish
the setup, the recovery is completed.
Jun 02, 2011 | Sharp PC UM20 PC Notebook
I have a Panasonic SA-PT660. It is just over a year old...and I get the 5 Disk changer to open. I turn the unit on and it just clicks (sounds like machine gun) going off. It says Disk Changer Error....
Hi there
Q: Did you push the CD Door by force?
If yes ...
1: you have misplaced the mechanical wheels ..
or broke some thing.
2: Or the second possibility is that the Driving motor rubber is broken
the answer is to service it.
Good Luck
Hope this helps
Nov 19, 2017 | Panasonic SC-PT660 Theater System
Disk changes no sound jvcchx359
check to make sure that the colors are line up on the sound system.
Jul 24, 2010 | JVC CH-X350 12-Disc CD Changer
RCA RS 1285 5 disk audio system won t show or play
When you turn on the unit the cd draw seams to open. I hear it making a noise like if it is trying to get ready to play. When you shut the draw it won't play, change tracts, or the disc thing to put in more disc wont work. Someone please help me
May 01, 2009 | RCA Audio Players & Recorders
Jeep RDS CD Problem
Did you change the battery ? If so try disonnecting and reconnecting the CD changer.
Dec 27, 2008 | 2005 Jeep Grand Cherokee
6 disk will not eject
you are all correct......
as are many other people with 6 disk cd changers in the same boat. check out this web site i have found at least 15 others with the same problem ( round about , but all problems relate to the 6 disk cd changer.)
the 6 disk changer is not excluse part to bose.
i recommend forcebaly removing the dam thing trying not to damage it further,( savge smashing the cd changer cassette) and trying to get a new one somewhere)
really though, you should consider surgury, - > open it and obtain spare parts to repair in the usual bodging fashion. ( that is to say any way you can ) or else return to manufacturer for remanufactured or replacement units at a cost or try to find replacement units on line such as ebay.
Dec 30, 2007 | Bose Lifestyle 12 System
Aiwa 3 disk CX-NMT 70 MODEL SPINS A FEW TIMES ON EACH DISC..wont play at all..What can I do? Thanks!!
This can be fixed by adjusting the POT on the rear side of the laser. My Aiwa had the same issue and there is an orange screw on the rear of the laser. Turn it about 1/16 - 1/8 turn COUNTER clockwise.
Please understand, this is a temporary fix, and will eventually ruin your laser mechanism completely. The company is out of business and the unit is 10 years old, so I didn't much care...perhaps I will run across a CD assembly I can replace it with, but this is a temporary fix for this issue.
Oct 16, 2007 | Aiwa NSX-DS55 CD Shelf System
Philips MX5500D System Logo
104 people viewed this question
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
