Question about HP Pavilion a1410n (ER890AA) PC Desktop
One drive is small and full... how do i combine it with the other
I have one drive that is 18 gig and is full of operating stuff. there isn't even enough room to defragment it. my other drive has 280 gig and all i can do is save other files in it. i have about 200 gig of free space. how can i use that as my main drive and not even bother with the small one. or something else that would help me. i have an hp pavilion m7560n . if you can help, thanks
  • 3,940 Answers
You can use a program like Acronis to make an image of the 18 GB drive and copy it to the 280 gb drive, then just remove the 18 GB drive.
You can download acronis from www.download.com
Posted on Jan 17, 2009
Get full full capacity of external 2 tera Seagate that now is reaing only 110 gig
This has happened to me before, also. What I had done was copy a disc IMAGE from the old, smaller drive to the larger drive - and the larger one turned into the same size! You did not mention your operating system (Windows, Mac, etc) but my solution was in Windows to go to Disk Management function and view the unallocated space left. Sure enough, there was "unclaimed/unused" space for the entire difference in size. Following the instructions of the Disk Management tool, I just added the remaining space to what was C: drive. I could have just as easily created a different drive space with the leftover, it's up to you - but I find it preferable to have my space in one chunk.
Note: This is a very sensitive area of Windows when you're dealing with file systems. A raw beginner might want to have an experienced friend help them through it, but if you follow instructions EXACTLY even a first-timer should be able to do it. If this solution does not work, let us know. Best wishes - Mark
https://www.lifewire.com/how-to-open-disk-management-2626080
How To Open Disk Management
Oct 19, 2016 | Seagate Computers & Internet
My System image backup fails.NTI Claims to be almost full?
Are you sure you have it pointing to the correct drive? Maybe it's looking at the home pc drive.
Jul 13, 2014 | NTI Backup Now EZ
Hard disk c drive is full
You will have to re-do your software Operating Software Windows and install it to D: as the primary drive. Why not just do a good cleaning of the main drive send anything over to D: that can be saved there and free up the primary drive making more room even better. Use the D: as a saving and use to gather all your goodies and take them off of the drive get rid of any unwanted software. Do a good cleanup I'm sure you will find lots of room once you do that. Just a suggestion!
That is what I do I have one for the operating system only primary C: and the other for things I wish to save to it that is bigger than the primary since all I will be doing is using the space on C: to just run Windows. Then anything else I save I either burn to a disk, slap it on a USB Stick or send it to a free 5 gig service thus illuminating clogging of my drives.
Most people do this when saving stuff they want to keep they get it off the primary drive in case of a crash. Again just a suggestion. John
Apr 13, 2012 | Sony VAIO M1 (VGCM1) PC Desktop
Hi there , i have an acer travelmate 6592 laptop , the original 80 gig hard drive crashed , and i dont have the recovery disc , the hidden partition wont re install either , i have bought a new 320 gig...
You cannot get the full 320Gb capacity because the BIOS can only support a maximum of 127Gb.
You only hope is a BIOS firmware upgrade that can support 320Gb. Check out the Acer WEB site to see if a BIOS upgrade will solve your problem.
OTHERWISE
Install a 127Gb hard drive in your Acer and put the 320Gb hard drive in an USB hard drive adapter case and use it as an external USB hard drive because it is not affected by the BIOS limitation.
Jun 13, 2011 | Computers & Internet
My 2Gig Sansa says it is full - and indeed almost the full two gigs are used up, and yet the music folder is not even 1 gig full and all the other folders, even the hidden ones, are empty - 0 bytes. Where...
The Sansa player can hook up to a computer in two different modes. Through normal use it can switch modes on it's own, although rare it can happen. Now stuff added in one mode can not be seen in the other mode and you can not delete the files. So you have MSC mode which means Mass storage class and is the best mode to use. Then MTP mode means Media transfer protocol, you have to use this mode if you use Napster and such to download MP3's with protected content (DRM) you have to set the player to one mode or the other, to see the files and delete the files you want to delete or to find the missing room. MSC makes your player look like a thumb drive, and is easy to use. If you need any more info go to SanDisk.com/support.
Jun 12, 2010 | SanDisk Sansa e250 MP3 Player
I have an old competer with a QUANTUM FIREBALL 1ct 1507. When I reboot or start up the competer says: Windows found a problem with the hard drive consult your owners manual. Press any key to continue. I...
Maybe getting some of that stuff off of the C: drive will help. Windows needs 15% free drive space to run correctly. Going to a bigger drive is also an option. depends on how old the system is.
Jul 30, 2009 | Computers & Internet
Wd3200 shows 320 gig total space yet says it is full at 36gig?
i used MyBook 640gig but i didn't have a problem like yours,.. but maybe i can help with your problems, here is a tip to run Mybook properly, and i've seen a cause which the capacity of small even though you are expected and have more space on it... one thing is did you got spam by some kind of virus like trojans, worms, mostly this thing come up to used your availability of space, if theres is so remove it by using Trojan Remover,... with all due respect always update your antivirus everyday if you still use. so far this what i notice about this problem and i solve it with my mybook640gig.. good luck!
Jul 09, 2009 | Western Digital My Book Essential 320GB...
C drive full, d drive empty, d drive has 104g what do i do
hi
ok here may e you really dont have to worry all that much nor do you have to buy a new drive
there are many software on the net that can help you
may be you can have some disk management software like Partition manager or Partition Magic and you can change the drive space without even leaving your comfortable windows platform GUI and increase the Disk space to your choice
a word of caution though ALWAYS BACK UP BEFORE ANY ACTIVITY LIKE THIS
hope this helped
cheers
PLs rate this solution if it had helped you
Jun 28, 2009 | Lenovo IdeaPad Y510 Notebook
Sandisk memory micro stick m2 for sony ericsson
This is normal. You never get all the space as the card is labelled. You have nothing to worry about.
Feb 06, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
HP Pavilion a1410n (ER890AA) PC Desktop Logo
54 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
