Question about Samsung ML-2240 Laser Printer
Sansung ML-2240, does not work. the red light is on. I refill the catridge, clean the exhaust toner tank.
  • 1 more comment
  • Anonymous Jan 27, 2009
    We just bought this printer. Installed the toner as directed. The printer pulls the paper through ok but there is no print on the paper. There is a red light on. Can anyone help?
  • ademathews Feb 03, 2009
    I have the same problem - I've installed the printer, however the red light stays on. I've not been able to print anything. The diagnostic utility tests the hardware however decides that the driver is damaged. Reinstalling does not fix the problem.
  • Anonymous Apr 13, 2009
    toner saya isi ulang tapi tetap tigak berfungsi,,, toner tidak terditek
    Problem Solver:
  • 6 Answers
Hi, we just got a chip for this model, it will work on ML-1640, ML1641, ML-2240, ML-2241, ML-2242 Y ML-2245 this chip goes on the printer mainboard, it's a permanent one, never needs replacement , it will allow you to recharge the original demo cartridege , over ondo over again, if you need more info you can contact ma at nahmmacher@hotmail.com, thank you.
Posted on Feb 08, 2009
  • 33 Answers
Go and download this software work for u http://www.megaupload.com/?d=HZO6CT90
Posted on Oct 06, 2010
Hi i am using samsung ml1640 printer after refiling it gives toner exausted messafe what i do to solve the problem
When the number of pages reach the limit specified in the chip it starts to give the message that tonor is exhausted no matter if it has tonor in it or refilled. Replace the chip or tonor and it would work fine.
If its the starter cartridge try following: -
Download the firmware from here http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=in&CttFileID=2238869&CDCttType=FM&ModelType=N&ModelName=ML-1640&VPath=FM/200904/20090416100856890/ML-1640_V1.01.00.83.exe
run the software and this will reset the page count to 0. Samsung printers generally do not support a refilled cartridge and thus the red light.But resetting the page count to 0 makes the printer detect the cartridge as an introductory one.
Also check out
http://www.savetoners.com/toner-products-a-services/77-free-information-how-to-refill-samsung-ml-1640-1641-1645-2240-2241.html
http://www.arbikas.com/forum/Attachments/ML1640_reset.pdf
Nov 04, 2010 | Samsung ML-1640 Monochrome Laser Printer
Refilled my starter cartridge ML-2240 and put in new reset fuse
Did you change the chip? These cartridge have a chip that tells the printer it has received it's new toner. You can get the chips cheap from a variety of sources online. Just search for samsung 2240 reset chip.
Good Luck
Feb 24, 2010 | Samsung ML-2240 Laser Printer
Iam using samsung mlt-2240 printer after refill the toner it was no working red light blinking in the printer.
You have to reset your printer. I think You have refilled the toner cartridges.
www.nakshatraworld.com
Jan 02, 2010 | Samsung ML-2240 Laser Printer
Toner is exhausted!! insert a new toner; this message appears while printing the page; i m talking about samsung ML1640. i have refilled the toner cartridge; but still that message appears; wat i can do...
We have Zero cost solution for samsung -scx-4300, scx-4824/4828
ml-2240,ML 2245, ml 1640. clp 310/ 315, It is working permenently.
Refill cartridge is working for ever. which is running successfully.
also provide other new model reset solutions.
mob: 9713862555, 9893282285
vivekryp@yahoo.co.in
Nov 04, 2009 | Samsung ML-1640 Monochrome Laser Printer
The ML2851DN cycles on but then has a red light that stays on.
The red light stays on until paper is loaded, and also if there's a problem with the fuser not heating, or toner is empty.
Oct 09, 2009 | Samsung ML-2851ND Laser Printer
I have a Samsung ML-2010. I refilled the cartarage once and it worked great. I have refilled it a second time but now the print is very light. I have vibrated the cartarage to ensure that the toner was...
hi this is kamal...
just purchase your printer catridge coz ur catridge is not working properly.. so u need to change pls
and let me know this information was good or not
best regards
kamal singh
Oct 08, 2009 | Samsung ML-2240 Laser Printer
Toner Exhausted
RESET YOUR PRINTER
Jun 09, 2009 | Samsung ML 1610 Laser Printer
Samsung ml-2245 toner refill problem
have a samsung ml2245 laser printer. using the printer tonner catridge refilling But Is Not Working can you have aney help me
Jun 08, 2009 | Office Equipment & Supplies
Refiiled catridge of samsung 1640 has not supporting,is it refill
RESET . Open the cover on the back of 1640 and see to small board . There is a m/s 93C66 near a big chip . Turn OFF the printer , connect pin 3 and 4 of 93C66 and turn printer ON . Hold on connected pin 3 and 4 of 93C66 until lamps on the front panel light , when lamps end light disconnect pin 3 and 4 of 93C66 . Now the page counter is 0 , and starting cartrige will work . May be different time between lamps on front panel OFF and disconnect pin 3 and 4 , it is about 0,5 sec , but may be larger or smaller , may be you will need to do this sequense once more . This method works if page counter before  RESET not more than 2000 pages .
Jan 14, 2009 | Samsung ML-1640 Monochrome Laser Printer
Toner Exhausted and replace the toner
Refill cartridge is working for ever. www.nakshatraworld.com
Dec 12, 2008 | Audio Players & Recorders
Samsung ML-2240 Laser Printer Logo
4,017 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
