Question about Philips 55PP9352 55" Projection Television
Remote will not adjust red convergence/multi-point horizontally
Philips 60PP5232/17 red multi-point and convergence problem.Why does Remote not adjust horizontally ?Moves up and down.Remote works the Blue multipoint/convergence both vertical and horizontal.
  • metzo22 Jan 19, 2009
    Ditto, happened on the same day too, spooky.
    Problem Solver:
  • 5 Answers
Check resistors around convergence i.c.(red) philips may use 2 resistors in parallell. should be about 1.8 ohms. assuming you already changed the i.c.
Posted on Mar 30, 2009
Need code to enter on remote to engage multipoint convergence adjustments.Need save proceedure after adjustments are made & exit proceedure for RCA Projection TV Model # HD52W59, ITC 222A
To get the code to enter on your remote to engage multipoint convergence adjustments, you need to contact the rca customer care for that, you get them your model number and they will get your code for you.
To process and save the adjustment made, follow the steps below;
  1. Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
  2. Enter the menu on your TV. Use the remote control and bring up the menu.
  3. Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  4. Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  5. Press "Enter." A crosshair pattern will appear on your screen.
  6. Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  7. Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  8. Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  9. Repeat these steps for all colors.
Take care
Jul 06, 2010 | Televison & Video
Cannot adjust red multi point
Symptom:
Unit appears to have poor convergence due to:
1. cross hatch appears tilted
2. one color (or more) being larger than the others.
Cause:
The yoke or yokes may have:
(1) rotated slightly or
(2) slipped down during transport.
Resolution:
Loosen a yoke and lower to inspect the tape. If black tape is present remove it from under all yokes (white tape or no tape is OK). Slide yoke or yokes up tight against the CRT and tighten to prevent slipping or rotation. Precede with
alignments and or convergence as necessary.
Jul 29, 2009 | Philips 60PP9202 60" Rear Projection...
Screen hazzy and issue with blue convergence
bad convergence would cause show to look as if it was supposed to be a 3-d movie, if a bulb was going out then people would look purple blue -green,or some other off color, so likely the green bulb is going out from the color of the people you described.
Feb 06, 2009 | Philips 60PP9202 60" Rear Projection...
CRT Rear-Projection Red Vertical Alignment
You may have a convergence problem. Here are some of the most common symptoms and example photos.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
Oct 11, 2008 | Philips 51PP9200D Television
No color adjustment
Problem with Hitachi 51F500 51 in. Rear Projection HDTV-Ready Television
i want to learn how to do convergence on my tv its a hitachi rear projection i have problums with colors not aligning,could you lead me in the right direction ps: i don't have the remote so i
can't magic focus
Posted by avatar13.jpgejaparks on Mar 03, 2011
AdChoicesMajor Appliance Repair
www.graysoncollinapplianceandac.comResidential/ Commercial, all brands Friendly, knowledgable technicians!
Get $75 of Advertising
www.Google.com/AdWordsPromote Your Business On Google. Claim Your $75 Coupon Now!
Solutions (1)
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Jul 04, 2008 | Philips Magnavox 9P6034C 60" Rear...
Multi point convergence
In the multi-point adjustment grid use the exit/status button on the remote to lock onto the cross-hair that you want to adjust and again exit/status button to continue back to moving the cross-hair around to another location.
Bill
Dec 01, 2007 | Philips 43P8341 43" Rear Projection...
Converging green?
jaymz, you can`t move the green, the green tube is always mounted in the middle and is not adjustable from the convergence menu. red & blue should be converged one at a time on top of the green, once you have accomplished this the crosshatch grid will be white and that means your done :)
Nov 30, 2007 | Philips 43PP9202 43" Rear Projection...
Blue out of whack around sides
I have the convergence problem with the red. After reading your site I replaced the 2 ICs and the problem is worse. Before the only problem was I could not adjust the red horizontal. Now I have no control over the vertical or horizontal and the overall picture is very red and it bows at the top and bottom very bad. A friend said I might have the ribbon connector in wrong or the convergence (silver box?) box maybe bad. Any ideas? Thanks,Dave.
Oct 12, 2007 | Philips 55PP9352 55" Projection Television
Philips Magnavox 51MP392H Rear Projection TV
A sign that amps are going bad, right now you can check resistors in convergence board alongside the amps, check resistance to see if right.
Oct 08, 2007 | Philips Magnavox 51MP392H Rear Projection...
Philips 55PP9352 55" Projection Television Logo
274 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
