Question about Toshiba REGZA 46RV530U LCD TV
HDMI issues with Comcast HD Box
This t.v. will periodically "lock out" the functionality of the Comcast Remote either when I turn off the set or just leave it on for a while. I cannot change channels on the cable box until I turn the set off and then the remote can communicate with the box. This happens with the hdmi cable connected to the box. I've been turning the set off, then the box, then turning them back on. Is there a setting? I've turned off the HDMI Sync and that seemed to delay the problem for a day.
  • Anonymous Feb 19, 2009
    I tried the component cables with my Samsung..same problem. This is a real mess. unfortunately I only have comcast or I would change to something else
  • Anonymous May 13, 2009
    remote freezes up and must wait about 5 to 10 seconds to get it to respond. I've had Comcast tech out twice and they replaced the box three times and still have the same problem. They claim it is feedback from my TV but I did not have this problem on the old style component cable box just with the motorola HDMI box.
  • 11,896 Answers
HDMI Has a safety feature that blocks other remotes from changing things. What a Joke I say. There could be a problem with the feature.
You can push up on the "Settings" button on the remote twice to enter the "advanced" settings menu. There might be something in there that needs to be set.
I found out that if I change the cable box output from HDMI to DVI it will work fine but the picture is not as clear.
I believe its a hdmi and communication problem with you box.The only thing you can do is to go back to component video cables until they come up with a fix.
Posted on Jan 17, 2009
How do I change the HDMI from 720 to 1080.
How do I get 1080 instead of 720. - Comcast Help and Support Forums
forums.xfinity.com/t5/XfinityTV-and.../How...1080...720/.../1152741
Jan 3, 2012 - I can switch one of them from one HDMI input to the other HDMI ... The YPbPr option might be set at 720p, and you can change that to 1080i.
How do I change the resolution on my LG tv to 1080p ? - Nvidia ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Apr 20, 2012 - 7 posts - ‎4 authors
Hello, I have recently bout a new LG tv, and I use a HDMI cable with my sky HD box, but ... only shows 1080i resolution, and i cannot find where to change it to 1080p. ...Forum; Optimizing blu-ray settings for 720p Plasma tv? 1080p TV outputs 1080i from desktop - Radeon ...
May 24, 2012
Bravia Full HD won't show pc via HDMI on 1080p but ...
Oct 30, 2011
More results from www.tomshardware.com
Change it: Your Comcast/Motorola HD Cable Box may be ...
www.darrowart.com/.../change-it-your-comcastmotorola-hd-cable-box-...
Oct 20, 2012 - Change it: Your Comcast/Motorola HD Cable Box may be outputting ...they set it to output a 720p signal via the HDMI out to my 1080p-capable ...
How To Change your PS3 from 720 to 1080p - YouTube
Jan 03, 2016 | Televison & Video
Lip sync
Vizio HDTV- Lips out of sync
Anyone with a new Vizio E601i-A3 60" or 70" HDTV that is having audio "Lips out of sync problems" with a cable or satellite box.
On Comcast cable boxes (or others), here's what you need to do: FIND MENU for AUDIO or HDMI setup on CABLE BOX or Satellite Box.
FOR COMCAST
1. Turn on TV and have Cable box Turned OFF.
2. Press MENU on COMCAST REMOTE.
3. Go to AUDIO Setting OR HDMI Setting. (On cable or Sat. BOX)
4. Change setting from Auto to L-PCM. (Turn off cable box to exit)
This should resolve any "out of sync" lips to picture after commercials on HD channels.
*This is a handshaking issue from the cable box to the Vizio E601i-A3
Dec 08, 2012 | Vizio 60" E601I-A3 Full HD LED-LCD TV
MX900 repeating commands after learn
please go to customer.comcast.com and get the support online via chat or phone, and explain the problem
God bless you
Jul 31, 2012 | Universal Remote Control MX980 LCD Remote...
How do I connect to Sharp HDTV and Comcast cable
Your dvd recorder only has rca, red white yellow inputs it wont allow you to record in HD, although you can play your comcast box any hd, regular digital through and record. Hook up the comcast box if HD through preferably HDMI if not get one from comcast. The HD box is the only box that allow HDMI, component and regular RCA and some RF out. This way you can play HD to your set but also record through RCA or RF again will not allow for HD record unless its TiVo. Hope this helps
Jan 07, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
Sylvania lc370ss9 remote problem, comcast
you have to turn off the power save setting
Mar 01, 2009 | RCA RCR450 Remote Control
Philips TV HDMI CEC EasyLink tries to control Cable set top box
I finally found a fix to this! YAY. I thought I might have to return the TV. I have the Phillips 42PFL5603D, but should work for other models.
On the TV press menu picture settings---picture---dynamic contrast (turn off) AND active control, turn off
If you have Comcast Moto box: on the Cable box go menu--->setup--->cablebox set up---RF BYbass set to ON
If you have a non-Comcast Moto Box, I'm sure there is an RF bypass setting in the menu. You'll just have to look for it. Another fix was close saying to only turn of the active control, but it took all 3 of these for it to work consistently. The latter let it work for all of 30 seconds.
Dec 29, 2008 | Philips 42PFL7403D/27 42 in. LCD TV
Need help hooking up TV, BluRay, Home Theatre & cable box
I found that since the Panasonic TH50PZ80U TV has only 2 HDMI ports on the back of the TV, the best solution for me was to use component (red, blue, green) cables to connect the Home Theatre to the TV. I suppose I/you could connect the home theatre to the HDMI port on the front panel, but I don't want cables hanging out the front of the TV (personal preference). Unfortunately, I am no longer able to use the VIERA Link functionality available by connecting all Panasonic components to each other using HDMI cables, but I feel it's a small price to pay for the incredible picture quality acheived by using the HDMI cable to connect the HD Cable Box to the TV. I may yet be able to control everything using the HD Cable Box remote, but I haven't gotten that far yet but I've got Comcast coming on Saturday and hopefully they can let me know if this is possible: let me know if you have a solution.
So here are the components and the cable types used to connect:
  1. HD Cable Box to TV: HDMI cable & Optical Audio cable
  2. Home Theatre to TV: Red, Blue & Green component cables
  3. BluRay Player to TV: HDMI cable
I hope this helps someone else.
Nov 19, 2008 | Televison & Video
No sound on NON HD channels
I had the exact same problem on a brand new Insignia 26 " LCD with DVD. Comcast tech was able to fix it by changing the Comcast box diagnostics. Here is what he did. Using the Comcast remote with the TV on - press power, cable, menu in that order. A comcast diagnostic srceen will appear. Select Additional HDMI options, then audio options. Change the audio options to L-PCM. Press power again to exit the diagnostics. That will fix it and you get to use the HDMI cable.
Jun 26, 2008 | Insignia LCDTV26 26 in. Television
HD Picture is Scrambled, but Has Sound
I had the same problem
you have to set up the componant on DTV.
the signal my be hd 1080i and the only connection with componant that can support this is the DTV port.
the other componant connections only support 480,
good luck
Apr 06, 2008 | Mitsubishi WS-55711 55" Rear Projection...
Sony kdl-40s2000
Probably need a software upgrade. Contact Sony for that information. This would be a common fix in most sistuations when using HDMI.
Dec 30, 2006 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Toshiba REGZA 46RV530U LCD TV Logo
847 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
