Sony Home Theater 5 DVD changer, was dropped in transit
Its SONY AVD-K800P - 05 Disk DVD changer & Home Theater (around 4 years old)
It does not start-up, a message 'PROTECT' comes on he screen and it shuts down.
I have disconnected all speakers, still It does not pass the Power on Test and it 'shuts down'.
I suspect a physical damage in the DVD mechanism, How can I disable the DVD Changer and use only the AMP & Speakers with an external DVD player?
Thanks
Anura
  • 27 Answers
If you know how to open it, remove the top cover( a couple of screws on the rear) and remove two connectors, one being a ribbon cable and the other a multiple wire connector. If it still does the protect, then it is not from the dvd mechanism but a fault on the board.
Posted on May 13, 2009
My older Sony Home Theatre/DVD player sometimes will not output any sound.
Sony eSupport - DAV-HDX500 - Support
https://esupport.sony.com/.../model-home.pl?...DAVH...
Sony CorporationHCD-HDX500 - DVD/Receiver Component for Home Theater System ... How to troubleshoot if there is no sound or intermittent sound from the speakers.
[PDF]DVD Home Theatre System - Sony
https://docs.sony.com/release/DAVHDX500.pdf
Sony CorporationDVD Home Theatre. System. Operating Instructions. DAV-HDX500/HDX501W ... not expressly approved in this manual could void your authority to operate this ...
Sony DAV-HDX500 No Sound : hometheater - Reddit
https://www.reddit.com/r/.../3nenei/sony_davhdx500_no_sound/
RedditOct 4, 2015 - My Sony DAV-HDX500 only plays sound when using the built in dvd player. ... Sony system you have does have a digital optical input so that's ...
Jan 10, 2016 | Sony DAV-HDX500 System
Hook up new blueray thru old home theater system
Yes you can. If you have more than 1 HDMI sources and your old system only has 1 HDMI in, you may want to invest in an HDMI switch. They are inexpensive (under $20 on Amazon) and let you choose 4 HDMI sources to feed your system. The audio is embedded in HDMI and you may have to select the choices (surround versus stereo) when you play the disc.
Dec 25, 2012 | Sony DAV-DZ175 DVD Home Theater System
Cds will not play in loop. plays one cd and shuts off will not move to the next cd
Troubleshooting Solution
  1. Lift disk changer doesn't work comes message "Disk Error"
  2. Lift disk changer work fine but doesn't load a DVD
  3. Power light is ON but doesn't want to Power UP
  4. From the beginning start DVD movie the picture distorted and freeze
    avsystemparts.com
1. Possible Problem w/ Main Board PCB
2. The dive laser assy replace. or full complete 5 Disk changer ROM
3.More chance problem w/ Main Board
4. Problem w/Main board need replace it.
Dec 24, 2012 | LG LHT874 Theater System
Promblems with LG LHT 874
Your solution is #3 problem w/Main Board
avsystemparts.com
Dec 11, 2011 | LG LHT874 Theater System
I have a Sony Home theater 5 disc changer, that will play a dvd for one minute and 13 seconds and then either re-starts the dvd. Any ideas on what could be causing this? I took the cover off the unit and...
You may want to try lubricating the spindle motor (that spins the disc). A couple of drops into the holes on the bottom of the motor. It could also be a cracked drive gear.
Mar 14, 2011 | Sony Audio Players & Recorders
Put movie in to play. Movie gets fuzzy and stops by itself.
Available parts: avsystemparts.com
Available parts
Jan 22, 2011 | LG LHT874 Theater System
My LG LHT874 system is not reading any dvds. Can you please advise on the best course of action. The system is only 3 years old. Should I attempt to utilize a DVD cleaning kit? If not, is it worth...
You can contact directly by email. Please check online click "About us" avsystemparts.
avsystemparts.com
Jan 07, 2011 | LG LHT874 Theater System
I have sony avd-k800p and it keeps going on protect mode and then shuts off.how do i fix this
I am having Sony HTD-C800DP Home Theatre system. I would like to know how to play DIVIX DVDs. I couldnt successful. Any one of you please help me in this. Kindly send information to my e-mail id thayumanavan@yahoo.com
Thanks in advance.
Regards,
Thayu
Jan 24, 2010 | Sony HTD-C800DP System
Need owners manual for a Sony avd-k800p sound system
You can download the required manual from:
http://esupport.sony.com/US/perl/model-documents.pl?mdl=AVDK800P
Hope this solves your problem. Thanks.
Oct 28, 2009 | Audio Players & Recorders
SONY DAV-BC150 - NO POWER
try to identify the location of fuse and try to change.
Jul 12, 2007 | Sony DAV-BC150 System
259 people viewed this question
 Grubhead
Grubhead
