Question about Garmin nuvi 255W GPS Receiver
What are the instruction on how long to charge
I plugged in ac adaptor and only have a lit blank screen. do I need to wait for a period of time
  • dmeehan Jan 17, 2009
    looking for more instruction on charging battery. does not say how long it takes
  • Beaumartin Jan 24, 2009
    I have my unit plugged in with an AC Adapter and all I see is a screen that says Garmin and a picture of an Ac adapter and a unit. How long will it take to see something else on the screen so I know if it taking the charge?
  • 3 Answers
I just purchased the 255w yesterday and set it up in the car for the return trip. I also saw it did not say how long to charge, but there are green bars on the top right that tell how much charge there is. The return trip was about an hour and a half and it was completely charged with all bars by the time I arrived, from the car's 12v accessary jack.
Posted on Jan 18, 2009
I have a new e627 used only once before today. Battery connection was partially out and screen indicated low battery. After five minutes screen went black and now I cannot power up.
Maybe your battery is totally drained.
Try to connect the AC adaptor of your laptop and plug it to the wall outlet and let it charge for 3 hours or more. When you plug it on the wall socket, it won't show the laptop's led blinking since it was totally drained. But after 3 minutes or more, it will start to show the blinking led to indicate charging. When blinking stops led light disappears, it is fully charged and ready to use.
Remember: Do not use your laptop while it is plugged in to save your battery life. When at home, remove the battery while it is fully charged and plug the AC adaptor directly to the wall outlet. It will still work without the battery as long as it is plugged directly to the wall socket.
Feb 23, 2010 | Computers & Internet
I can't get it to charge
This is typically caused by one of two issues:
  1. (Most likely) The battery has failed and needs to be replaced. If the battery is older than a year and seen heavy use or been plugged in to the charger for long periods of time, this is likely the problem. Verify that the power adaptor is not bad (below) and purchase a new battery from a local retailer or online.
  2. The power adaptor is bad. Plug in your power adaptor and verify that the power LED is lit. If it is not, then it is bad and will need to be replaced or alternately, you can purchase an inexpensive external battery charger. They are available online or often from your local retailer.
A couple good sources for batteries/chargers:
http://everydaysource.com
http://www.all-battery.com/
Hope this helps.
-Tor
Dec 12, 2009 | Sony Handycam DCR-PC9E Mini DV Digital...
My Gateway 1450 will not power up. For the last 2 weeks that battery light has been red (battery need recharging). i had the unit turned off with no ac power to it all weekend and not it will not power up....
The motherboard battery is just a little round battery that you can buy at almost any retailer in most pcs. The model number to the battery is usually a CR 2032. This battery does not receive any power from your power supply. Have you noticed your PC loosing time over the last few months? This is usually a good indication that the motherboard battery is dying. The lights that you refer to though should only partain to the rechargable battery of the notebook. During the past two weeks while the red light was on, was the AC adaptor plugged in to the laptop and plugged into an AC source? If your AC adaptor has been plugged in and is not charging the notebook battery then there could be one or both of the following problems: your notebook battery could be bad or your AC adaptor could be bad. Something you may or may not know is that it is not good to keep the AC adaptor plugged in all the time. This causes the notebook battery not to fully discharge after being charged. Over a long period of time, the battery will not even charge anymore. My suggestion is that if you know someone with a similar AC adaptor to yours, borrow it to see if it charges your battery. If the battery doesn't charge then you know to replace. However, I am almost certain that you problem is the battery. Sometime older laptops like the one I have has a reset button on the underside. If yours has one try removing the battery and leave it out. Then plug in the power and press and hold the reset button for 10 to 20 seconds. If no reset button is on yours then do the same process with the battery removed and power adding, but hold the power button instead.
Dec 07, 2009 | Gateway Solo 1450 Notebook
When i go to charge my kodak M863 camera (in the wall or by USB) the green light flashes and then the red light blinks 3 times. please help this is the first time charging my camera.
You can used the USB cable to charged the camera, But some of the M863 camera will not take charged usign the USB cable., I strongy suggest used the AC adaptor just make sure the AC adaptor is 5V ac adaptor it will only charged using the 5V adaptor., About the flashing green it indicates camera is charging just wait for the solid green light it means it fully charged
You may purchased also a special charger for your battery(KLIC-7001)- cahrer model is K8600-C. i think the price of this charger is around $29.00
Nov 14, 2009 | Kodak EasyShare M863 Digital Camera
M465-E will not turn on
Simply your RAM or mother board is faulty. Replacing RAM is cheap but repairing Mother board modules is an expensive affair.
Rate this solution if it was helpful to you.
With Regards,
Shyny
May 29, 2009 | Gateway M465-E Notebook
The battery of my 4920 dry so fast,i have to charge it every 30 minutes and the warning sign for charging dissapear
Your battery is going bad, the cells inside of the battery itself is not holding the charge that is should. Get another battery and then make sure the ac adaptor is not plugged into the laptop when your not using the laptop, this will make sure the battery isn't always charging for long periods of time when it doesn't need to.
May 05, 2009 | Acer Aspire One PC Notebook
I have a problem with asus eee 901. I've just bought it. It had linux, but it was changed into windows xp. Since it had been fully charged only once I was using it on battery and setting it up with new...
Remove the battery for a couple of minutes while the unit is not plugged into the a/c adaptor. Reinstall the battery, plug the unit into the a/c adaptor, and see if it will boot up.
Mar 14, 2009 | ASUS Eee PC 901 20G Notebook
Battery on lap top is not charging
switch off - disconnect ac adaptor - wait 3 seconds - connect ac adaptor - repeat about 20 times.
Is charge light blinking when you connect ac adaptor?
Try reseating battery.
If battery is old (over 2 years) or heavily used then it may need replacing. They only last for 250-500 complete discharges.
Aug 08, 2008 | Evesham Computers & Internet
Labtop does not turn on
Try this; Disconnect from the AC outlet rmove the dc plug from the jack. Remove the Battery and wait for 5 mins and plug in the AC-DC adaptor without the battery. If the Laptop runs, then wait for the Windows to totally boot up and while running try to put back the battery and observe if it still charges. If it won't still boot up repaet the procedure and before connecting the power remove the memory modules first and install 1 memory at a time.
Hope this helps.
May 02, 2008 | Acer Aspire 5630 Notebook
Motorola W370 will not charge
Motorola provides a USB driver for just charging the W370. I installed it using the installation instructions from the Motorola website, but it just wouldn't work. The USB driver would install but would not activate (error Type 10). The W370 said that it could not charge. I recommend not bothering with this device driver, at least not with Windows XP.
However, I did figure out how to get the W370 charging from a USB port by trial and error. It's a pretty simple process.
1. Before plugging in the USB cable, turn on the W370 and wait for it to fully boot.
2. Connect the phone to the USB port of the computer.
3. When the phone asks "Connect phone as storage Device?", press the phone's left soft key, choosing "YES".
4. The phone will say "Please Wait...... Connecting Phone as Storage Device"
5. Eventually, the phone will display a white screen with the message, "In storage mode, no regular phone activities can be done."
6. Flip the phone closed. The yellow battery indicator will be lit. The phone is charging.
You'll note that the computer will see the W370 as a storage device with around 512 Megabytes of free memory, with empty "picture" and "sound" directories. The W370 appears to be a generic mass storage device to the computer. No special device driver is needed to charge the W370!
Mar 02, 2008 | Cell Phones
Garmin nuvi 255W GPS Receiver Logo
279 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
