Question about Panasonic KX-P7110 Laser Printer
Paper jam problem on KXP7100
When I go to print, the paper gets jammed in the printer and doesn't come out until I remove it by removing the print cartridge first. Nothing gets printed at all. I would be grateful if someone can offer any solution to this problem. Thanks
    Scholar:
  • 35 Answers
Typically, most of the time paper jams are caused by a defective photostatic print drum. When the drum goes bad and can no longer hold a charge, the paper sticks to the drum because the paper has a charge on it that attracts the two. There would be where I would look first. Now, if thats not it, the feed rollers could be getting worn. For a quick fix, take some fine sandpaper, and scuff up the rollers a little. This will create enough friction to allow the paper to feed through the printer smoothly. Keep in mind that using th sandpaper is only a stop gap measure. If the rollers are worn, they will need to be replaced soon. Hope this helps. Good luck.
Posted on Jun 20, 2007
SOURCE:
When printing documents no matter how few or how many pages, paper gets stuck in the middle of printing.
Try using regular paper on unit as specified by Samsung. If that does not resolve the issue then the hassle lies with the paper feed mechanism. Often a good cleaning of all the rollers in the path can take care of the issue.
Aug 24, 2015 | Samsung ML 2525 BW laser Printer
Paper Jam
Hi Matt,
Here's how to:-
  • First turn the printer off and on.This is known to automatically clear paper jams by pushing the stuck paper out.
  • Remove all the papers from the feed trays.
  • Remove the cover from the housing of the printer to gain access into the inside of the printer.
  • Check for the jammed paper inside and gently pull it out.
  • Press on the flashing paper jam button to make the clearing easy.
  • If this doesn't clear the jam,unplug the printer from power and try removing the stuck papers firmly.
  • Plug the printer back and try printing now.
Check out these video tutorials for more on the same.
Hope this helps.Thanks!
Dec 16, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
4TH LIGHT FROM THE TOP KEEPS COMING ON LEXMARK E232
What this light sequence means that the printer has a paper jam.
When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
How to clear Paper Jam
Press Continue button twice quickly to see the secondary error code.
To get the secondary error codes
When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
Press and release Continue button twice quickly to display the secondary error code light sequence.
Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
We recommend that you clear the entire paper path when a paper jam occurs.
To clear a paper jam:
1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
2 Open the front cover and remove the print cartridge assembly.
NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
3 Remove any jams in the area behind the print cartridge assembly.
4 Lift the flap at the front of the printer and remove any jams beneath the flap.
5 Open the rear exit and remove any jams.
6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
NOTE: The printer reprints the pages that caused the paper jam.
Jun 30, 2011 | Lexmark E232 Laser Printer
Light is flashing on Resume on my HP Deskjet F2110 All-in-One printer scanner copier. What does that means?
Regular paper, envelopes, or specialty media may get stuck or jammed in the printer. Follow the instructions below to find and remove jammed paper (or other media) from the printer. If the HP All-in-One has a paper jam, first check the rear door. If the jammed paper is not in the rear rollers, check the front door.
Step one: Check for and remove any paper stuck in the paper In tray
  1. Remove all loose paper from the paper In tray.
  2. Press the RESUME button.
    • If the paper jam is cleared, skip to Step Four
    • If the paper is still jammed, continue on to the next step below.
  • If more than one sheet is stuck in the printer, remove the paper, one sheet at a time by taking hold of a sheet in the middle of the stack and, with both hands and firm, even pressure, pull the sheet towards you. Usually, removing one or two sheets from the middle of the stack will release the pressure and the rest of the stack can be removed.
  • After removing the paper, check to make sure no scraps of paper are stuck in the printer.
    • If the paper jam is cleared, skip to Step Four.
    • If the paper is still jammed, continue on to the next section.
  • Step two: Clearing a paper jam from the back of the printer
    If the paper jam is not accessible from the In tray, follow the instructions below to clear the paper from the back of the printer.
    1. Unplug the HP All-in-One.
    2. Press in the tab on the left side of the rear door to release the door. Remove the door by pulling it away from the HP All-in-One. Figure 1: Removing the rear door
      CAUTION:If the paper tears when removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the device. If all of the pieces of paper are not removed from the HP All-in-One, more paper jams are likely to occur.
    2. Replace the rear door. Gently push the door forward until it snaps into place.
    3. Press Cancel to continue the current job.
    Step three: Lift the front cover and slowly remove any jammed paper
    1. Unplug the power cable.
    2. If necessary, pull the input tray down to open it. Then, lower the print cartridge door. Figure 2: Lowering the print cartridge door
      CAUTION:If the paper tears when while removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the device. If all the pieces of paper are not removed from the HP All-in-One, more paper jams are likely to occur.
    2. Close the print cartridge door.
      Figure 3: Closing the print cartridge door
    1. Plug the power cable into the HP All-in-One.
    2. Turn the power on.
    3. Press Start Copy Black or Start Copy Color to continue the current job.
    Step four: Verify the print cartridge carriage can move freely
    2. Check to see if the print cartridge carriage can move freely from one side of the printer to the other. If the carriage is to the right and out of plain view, skip to Step Five. Do not try to force it to move if it is hung up on something. [img src="http://h10025.www1.hp.com/ewfrf-JAVA/Image/common/note.png" alt="">
      NOTE:Be careful not to force the print cartridge carriage. If the carriage is stuck, forcing it to move will damage the printer.
      • If the carriage does not move, continue with the next step below.
  • Remove the print cartridges.
  • Step five: Reload and test the printer
    Once the jammed paper is removed, verify that the printer is still functioning properly.
    1. Reload the printer with plain paper.
    2. Perform a self-test by pressing and holding the Resume button until the printer starts printing. A test page should print.
    NOTE:Do not put more than 35 sheets of plain paper in the document feeder tray.
  • Gently move the print cartridge to the far right of the printer.
  • Remove the paper from the paper In tray, but do not remove the drawer.
  • Remove the rear access door.
  • With your fingers, rotate the rollers "up" three full rotations.
  • Push the rear access door back into the printer until it snaps firmly into place.
  • Replace the print cartridges.
  • Plug the power cable into the HP All-in-One.
  • Turn the power on.
  • Step six: Service the printer
    Perform all the steps mentioned above. If the problem continues, service the printer.
    Cause Paper jams can be caused by several factors. Follow these guidelines to prevent further paper jams.
    • Insert paper into the paper tray only until it meets resistance. Do not push it farther in.
    • Make sure that the paper is flat in the paper tray and that the guide is adjusted to the width of the paper.
    • Do not add paper while the product is printing.
    • Remove printed pages frequently.
    • Do not use paper that is too thin, too slick, or that stretches.
    • Do not use torn or creased paper. Used paper might cause jams.
    • Make sure that the rear access door is securely fastened.
    Jun 17, 2011 | HP Deskjet F2210 InkJet Printer
    There is a paper jam...how do I unjam it
    Hi dorothyhover,
    Here's how you would clear paper jam from your Brother HL 1430:
    1. Remove the paper cassette completely from the printer.
    2.
    Pull any jammed paper up and out of the printer.
    3.
    Open the front cover and remove the drum unit assembly.
    4. Pull any jammed paper up and out of the printer.
    Do not remove the drum unit assembly with additional force at this time if you cannot remove it easily. Instead, pull the edge of the jammed paper from the paper cassette.
    5. Open the rear cover and pull the paper towards the back of the printer, the fuser may get dirty with toner powder and may result in toner scatter on the next printed page or pages. Print a few copies of the test page until the toner scatter on the printed pages clears.
    6. Close the rear cover and install drum unit assembly, close the front cover.
    Hope it helps.
    Thank you for using Fixya.
    Apr 28, 2011 | Brother HL 1430 Laser Printer
    Paper feeds about half way and then stops. All of the indicator lights come on.
    If you get a paper jam, the Paper Jam indicator light promptsyou to clear the paper path. If the paper has just started to feed from thepaper feeder when the jam occurs, pull the paper straight up out of the paper feeder. Open and close the printer cover toresume printing. If the paper jam occurs inside the printer, remove the paper from the output bin. Turn the printeroff, then on. If this doesn't clear the jam, open the printer cover.Remove the print cartridge and cover it.For additional assistance, please contactLexmark Technical Support
    Apr 11, 2011 | Lexmark Optra E312L Laser Printer
    Paper jam???
    Follow these steps :
    1.1
    Remove all paper from the trays. This will prevent further jams during the clearing.
    2.2
    Remove the covering to the printer's outer case to expose the jam. Locate the jammed paper to ensure there is not another problem causing the stall.
    3.3
    Pull gently on the jammed paper, taking care not to tear it. In most cases, this will remove the jam.
    4.4
    Press the flashing "Printer Jam" button. This will allow the rotors to turn and facilitate the release of the jam.
    5.5
    Turn off the printer and firmly pull on the jammed paper. Be careful not to tear it.
    6.6
    Remove remaining paper shreds. if a tear occurs, remove any residual paper that may hamper printing.
    7.7
    Refill the paper tray and try printing again. If the jam persists, repeat the process and search for more paper.
    Oct 29, 2010 | Canon ImageClass D861 Printer
    Had paper jammed - removed jammed paper - but nerror light still on
    Before you can clear a "PAPER JAM" or "PRINTER JAM" error, you must locate where in the unit the paper is jammed.
    First, unplug the machine for safety and disconnect the telephone line. Next, follow these instructions based on where the paper jam is located.
    Paper is jammed inside the paper tray:
    1. Pull the paper tray out of the machine.
    1. Pull out the jammed paper to remove it.
    1. Reload the paper in the paper tray.
    2. Reinstall the paper tray.
    Paper is jammed inside the machine:
    1. Remove the jam clear cover on the back of the unit. Pull the jammed paper out of the machine.
    1. Re-insert the jam clear cover.
    2. If you can not pull out the jammed paper, lift the scanner cover from the right-hand side of the machine until it locks securely into the open position.
    3. Remove the jammed paper.
    4. Check the print head's position. In the example photo the print head is positioned at the left hand side of the platen area.
    5. Gently move the print head to the center.
      Note Be careful to not force the print head to move.
      If the print head is positioned at the far right hand side, you cannot move it. Please contact Brother Customer Service from "Contact Us".
    6. Examine under the print head. If anything is found, remove it.
      Note Use a flashlight if necessary to check thoroughly.
    7. Lift the scanner cover to release the lock. Gently push the scanner cover support down and close the scanner cover.
    8. Reconnect the power cord and telephone line.
    Note To prevent paper jams, do not put multiple kinds of paper in the paper tray at the same time.
    If the message continues to appear on the LCD, the machine will require repair. Please contact Brother Customer Service from "Contact Us".
    Thanks for using fixya......
    Oct 26, 2010 | Brother Office Equipment & Supplies
    The printer is constantly sending a message- 'paper jam'
    HP Officejet 7200, 7300, and 7400 Series - 'Paper Jam: Clear jam, and then press Enter' Message Displays on the Control Panel Display
    Issue
    During printing, the paper becomes stuck in the all-in-one and the error message 'Paper Jam: Clear jam, and then press Enter' displays on the control panel display.
    Solution
    Use the following instructions to clear a paper jam from the product:
    Step one: Check for and remove any loose paper from the In tray
    Do not try to remove jammed paper from the In tray. First remove any loose paper from the In tray to avoid worsening the jam.
    CAUTION: Always try to remove jammed paper from the back of the printer first to avoid mechanical damage.
    Step two: Clear the jam from the back of the printer
    Follow these instructions to clear jammed paper from the back of the product. If the product is equipped with a two-sided printing accessory, skip to that section.
    Remove the rear access door to clear the paper jam
    1. Remove the rear access door by pressing the buttons on the side of the door and pulling it toward you.
    Figure 1: Removing the rear access door
    Rear access door
    2. Gently pull the jammed paper out of the rollers.
    WARNING: If the paper tears while removing it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the product. If all the pieces of paper are not removed from the product, more paper jams might occur.
    3. Replace the rear access door. Gently push the door into the all-in-one until it snaps firmly into place.
    Remove the two-sided printing accessory to clear the paper jam
    1. Remove the two-sided printing accessory by pressing in the buttons on the sides and then pulling the accessory toward you.
    Figure 2: Removing the two-sided printing accessory
    2. Gently remove any jammed paper.
    WARNING: If the paper tears while removing it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the accessory. If all the pieces of paper are not removed from the accessory, more paper jams might occur.
    3. Press the button on top of the two-sided printing accessory to open the door.
    Figure 3: Opening the two-sided printing accessory door
    4. Gently pull the jammed paper out of the rollers.
    5. Close the accessory door.
    6. Reinstall the two-sided printing accessory.
    Step three: Clear the jam from the automatic document feeder (ADF)
    1. Remove the document feeder tray from the product by gently pulling it.
    2. Lift the cover of the automatic document feeder by pulling it outward.
    Figure 4: Lifting the cover of the automatic document feeder
    Automatic document feeder (ADF) door
    3. Gently pull the jammed paper out of the rollers.
    WARNING: In the rare occurrence of a severe paper jam, you might need to remove the face plate from the front of the automatic document feeder and lift the pick assembly to remove torn pieces of paper from deep inside the automatic document feeder.
    4. Close the cover of the automatic document feeder, and then reattach the document feeder tray.
    Step four: Verify that the print carriage can move freely
    Follow these steps to try to move the print carriage.
    CAUTION: Do not force the print carriage to move if it is out of plain view or feels stuck. Forcing it may damage the printer.
    1. With the product turned on, open the print cartridge access door. The print carriage might try to move into the access area. If so, allow it to move to that position.
    2. Without turning off the product, unplug the power cord from the back of the product. Unplug the power cord from the power source. The power cord must be unplugged to allow the parts to be moved by hand and to reset the paper feed mechanism, without the risk of an electrical shock.
    3. Looking in through either the print cartridge access door or the output paper tray, make sure the print cartridges are locked into the carriage and have not come loose. Also, make sure that there are no obstructions under or around the carriage to block it from moving.
    4. Make sure the print carriage can move freely across the width of the product by gently pushing the carriage to the left and then to the right. Clear any obstructions found.
    You may have to reach through the output paper tray to access the print carriage.
    5. Close the print cartridge access door and plug the power cord back to the back of the product. Plug the power cord into the power source.
    6. Press the On button to turn on the product.
    After you have removed the jammed paper, make sure the product is still functioning properly.
    1. Reload the product with plain paper.
    2. Peform a self-test by pressing and holding the RESUME button on the control panel until the product begins printing. A test page prints.
    If you have completed all the steps listed above and are still experiencing a problem, service the product.
    Dec 30, 2009 | HP DeskJet 3745 Printer
    Paper jam on my i560
    there is a small paper very small paper stuck in the printer remove it it will work
    Nov 09, 2009 | Canon BubbleJet i560 InkJet Printer
    Panasonic KX-P7110 Laser Printer Logo
    150 people viewed this question
    Top Panasonic Office Equipment & Supplies Experts
    Norman  J Weimar Jr
    Norman J Weimar Jr
    Shannon Murphy
    Level 1 Expert
    HEMANT GROVER
    Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
