Question about Apple iMac G5 Desktop
Imac won't turn on
Started having trouble turning computer on a while back. Some times it came on sometimes it didn't. You could press the switch a number of times with no results and then finally it would come on.
I just went threw the instrution on this page:
The #1 LED was on but the internal button would not turn the computer on.
Can you help?
  • dmdobbin Jan 17, 2009
    Pressing and holding doesn't work either.
    It didn't crash or power down. It won't start up again after it has been properly shut down.
    Thanks for your help.
  • 121 Answers
Dmdobbin, To restart after a "crash" or an "unexplained" power down, press & hold in the start button, don't just press it over and over, press and wait until it comes on.  Same for a shutdown when all else fails if you can't force quit an application and every thing is locked up. let me know if that does it. randy320sgi
Posted on Jan 17, 2009
2 Suggested Answers
  • 86 Answers
SOURCE: Apple iMac 17 Model A1058 won't turn on
Re the light turning on for about 3 secs.
Does the computer make a 'start up' chime or any other tones?
If not, this could be for a variety or reasons.
Firstly you need to verify that the power supply is working. Remove all connections from the computer including the keyboard and mouse. Try to start up again. If the computer still fails to start up, you will need to gain access to the computers internals.
Lay the computer face down on a soft cloth to protect the screen. Undo the 3 silver screws on the lower edge of the computer. (one at each end and one central. These are captive screws.)
Lift the rear cover away from the main body of the computer.
On the Logic Board there are 4 diagnostic LEDs indicated by a yellow arrow on the board. To the left of these LEDs there is a small button. This allows you to power on the computer with the rear cover removed. Connect the power lead. LED1 should be 'ON'. If it is 'OFF' then you need to replace the power supply.
Turn the computer on by using the internal power button.(LEDs 2&3 should now be 'ON'. If LED2 only comes on momentarilty then replace the power supply).
Does the computer start up normally after pressing the internal power button?
- Yes: Press and hold the power button until the computer powers off.
• Unplug the power cord from the iMac, and reinstall the back cover.
• Return the computer to the upright position.
• Plug the computer back in, and press the power button to turn on the computer.
• Make sure the computer is starting up properly. If the computer will ONLY start up
from the internal power but will not power on from the power button on the back
cover, the power button on the back cover may be faulty.
- No: Reset the SMU.
• Unplug all cables from the computer, including the power cord.
• Wait 10 seconds.
• Plug in the power cord while simultaneously pressing and holding the power button
on the back of the computer.
• Let go of the power button.
• Press the power button once more to start up your iMac G5.
If the computer starts up normally then shut down and replace the rear cover.
If you feel uncomfortable about working on the computer, take it to a reputable repairer.
Hope this helps.
Posted on Jan 05, 2009
IMac Computer will not turn on
Don't worry, I am a factory trained Apple expert! When you press the power button, do you see the white LED power light on the front of the iMac light up? Does it make ANY sound? If it is completely non-responsive, it will at the very least need a new Power Supply with the worst case being a logic board.
Dec 16, 2013 | Televison & Video
2004 Honda Odyssey won't start or try to turn
You tried it in neutral but did you take it out of park and force it back into park? Just a suggestion since sometimes the switch that tells it that it is in park needs a bit of a nudge sometimes.
Sep 09, 2013 | Cars & Trucks
F5e1 error code
The F5 E1 error message indicates the latch motor was unable to lock the door. When the self clean cycle is started, the control board will turn on the latch motor which is mounted on the rear of this range. The motor is connected to a cam that transfers the motors motion to a rod that runs under the cooktop. This rod connects to the actual latch mounted behind the oven door. The control board will then monitor a position switch that is actuated by the latch motor cam. As the motor rotates, the latch will engage the door locking it in place just as the cam contacts the switch button. When the switch contacts close, the control turns the latch motor off and starts the cleaning cycle.
When diagnosing this failure, the error code gives us a good starting point to begin our trouble shooting. I removed the rear panel and started a clean cycle. Once the start button was pressed, the latch motor began to rotate, but didn't stop at the locked position. It continued to rotate three times and then displayed the error. I unplugged the range from the wall and using my meter, did a continuity check of the latch position switch (the one on the right). The switch was reading as an open circuit in standby and when I actuated the switch which tells me the switch has failed. The second switch on the latch assembly, by the way, is to turn the oven light off during the self cleaning cycle to protect the bulb. That way, if you leave the light switch on the control panel turned to the on position, that second switch will turn it back off. Good to know if you can't figure out why the oven light won't turn on.
With the failure down to the latch assembly, I checked the range parts to see if the switch came as a separate piece, but it looks like it's an entire assembly, and not individual parts. I removed the old latch after removing the two screws and six wires, then installed the new latchshow?id=y6f3ez5blva&bids=92089.709229668&type=10&subid=. Once all the wires were back connected to the proper terminals, I put the rear panel back on and plugged the range back into the outlet. Started a self clean cycle, but this time I heard the motor make one revolution and stop. The cycle started for the customer and a few hours later, I am sure the oven was nice and clean.
Aug 14, 2011 | Ovens
Apple 20 in Imac G5 turn on for about 40 second and shut it down itself .. please help
Sounds like you need to reset your SMU and NVRAM:
To reset your SMU:
  1. Turn off the computer by choosing Shut Down from the Apple menu, or by holding the power button until the computer turns off.
  2. Unplug all cables from the computer, including the power cord.
  3. Wait 10 seconds.
  4. Plug in the power cord while simultaneously pressing and holding the power button on the back of the computer.
  5. Let go of the power button.
  6. Press the power button once more to start up your iMac.
To reset your NVRAM:
  1. Shut down the computer.
  2. Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously in step 4.
  3. Turn on the computer.
  4. Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
  5. Hold the keys down until the computer restarts and you hear the startup sound for the second time.
  6. Release the keys.
If those don't resolve the issue, your computer will probably need service. Good luck!
Oct 10, 2010 | Apple iMac G5 Desktop
2170W wireless connection to mac computers
My suggestion would be to connect an ethernet cable from the printer to the router. This is a more stable connection for the printer on the network.
All of your wireless computers will be able to connect to it and print to it as long as they are connected to the network.
To get the printer back in wired mode, you will need to reset the printer and network card of the printer.
1. Turn off power
2. Hold down go Button while switching back on
3. Wait 2 secondes before letting go and press the go button 8 times quickly
4. Wait for the unit to finish warming up
5. Repeat steps 1 and 2
6. Wait 2 secondes before letting go and press the go button 7 times quickly this time
7. Wait for the unit to finish warming up then plug in the ethernet cable.
Mar 28, 2010 | Brother HL-2170W Laser Printer
Hi Latoya
I'm guessing that the mac has frozen and you don't know what to do.
Most folk just pull the plug out of the wall, count to 5, and then plug it back in again and then switch the computer back on. Although this works Ok it it not the ideal way to do it as it can cause problems with the hard-drive.
The correct way is to press the power button on the back of the iMac while counting to 10. By the time you reach 9 it should have turned itself off (completely off - no white light glowing on the front!)
Leave it off for another 10 seconds and then press the button again to start it up.
Nov 09, 2009 | Apple iMac G5 Desktop
Loud fan noise
You may need to reset the SMC. Unplug all cables from your iMac including the keyboard, mouse, power cable, DSL, everything. Wait at least 5 minutes. Now plug the power cord in making sure not to be pressing the power button at the same time. Connect all cables and press the power button and start your iMac. If you still hear the noise then take it in for service.
Sep 27, 2009 | Intel iMac 24" Core Duo, 2.16GHz Mac...
Samsung 50" DLP TV turns itself off
I had the same problem which also included the picture having streaks of red in it sometimes too. I found that both problems were due to the TV getting too hot inside. I bought a $7 small 4" fan from Walmart and pointed it at the back "door" of the TV (where the bulb can be replaced). Both problems have disappeared which I think is due to not letting the interior get too hot.
Not sure if there is an internal fan to cool the parts inside, but if there is it is not working well enough.
Jun 11, 2009 | Samsung DLP HL-P5663W 56" TV
Apple iMac G5 Desktop Logo
3,617 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
