Question about Car Audio & Video
Speakers are crackling
I just bought a used kenwood reciever and technics speakers and they are crackling. So I hooked up two different speakers and they also crackle. Could this be the input or reciever is bad? Or what else could it be?
  • akerr68606 Jan 17, 2009
    I tested the reciever out with another set of speakers that I know work and it still crackled. I also tried switching the RCAs to all the outputs and crackles. Tried all of the wire docks still crackles. So the reciever is dead right? Is there any way to fix this? Thank you
    Sergeant:
  • 233 Answers
This could be caused by one of your speaher wires being shorted out to ground, OR one of the speaker terminals in the doors or rear coming into contact with metal. If you remove the unit and test it with the speakers hooked directly to the back of the unit and they do not crackle, then the unit is fine. If they still crackle - then you either have two diferent sets of bad speakers, Or more than likely the outputs of the kenwood have been damaged by an improper installation in the past.
Posted on Jan 17, 2009
Kenwood KR-V7080 reciever will not play through speakers.I can still plug headphones into the reciever and get audio but not through the speakers. Tested the speakers and they still work.
If the speakers used to switch off when the headphone plug was put in the socket, suspect the socket it goes into as being the trouble. It is clearly not connecting the speakers, when the headphone plug is removed.
Aug 17, 2015 | Kenwood Audio Players & Recorders
I hooked up a 2-Ohm dual voice coil 800 watt max 12" Kicker CVR subwoofer and 4-Ohm single voice coil 1000 watt max 12" Kenwood KFC subwoofer to 1000 watt Kenwood Ampilifer. After hooking it up, the Kicker...
off the same amp? you have two way different sounding speakers man. you can buy 2 identical speakers from the same company and brand and series and they will play differently every time. you have 2 speakers with nothing in common so you will hear a difference and maybe interference because of the different ohm levels.
Apr 14, 2010 | Kicker CVR12 Car Subwoofer
Kenwood rx29 reciever protection fault
Check the speaker ohms. If you still have the factory ones they are rated at 2ohms. All new stereos need a 4 ohm speaker. I had the same problem with a different kenwood and all I did was change to a set of kenwood speakers and that fixed the problem
Feb 27, 2010 | Audio Players & Recorders
No tv sound through reciever's speakers. How do I hook up?
TV is not customarily a sound source. It is a video destination. Get your TV-related audio to the receiver from the same places the TV gets it - each source device's audio outputs.
Feb 06, 2010 | Technics SA-DX750 Receiver
I have a new house that had speakers built into the cieling. I bought an onkyo to push all eight speakers. the reciever went into protect mode. i had an old reciever and hooked four speakers to the onkyo...
you can check them with a ohm meter, hook it to the wires that you hook to the reciever and if you get a reading it is good if no reading it is bad wires
Nov 22, 2009 | KEF Audio Cresta 2 Speaker
No sound coming out of speakers
A quick way to check your speakers is to put the contacts from a 9 volt battery to the positive and negative speaker wires (briefly). You should hear a crackle of some sort if the speakers are functioning. If there is no crackle, speakers are bad / if there is a crackle, your head unit must have a problem.
Jan 22, 2009 | Kenwood VR-509 Receiver
Truck radio problem
it sounds like your wires need to be reran you might have a bad wire or two if that doesnt work email me
Aug 21, 2008 | Kenwood KDC-MP4028 CD Player
Crackling Sound from Speakers
check audio cables wiggle them around if no difference in sound check other inputs if they all crackle call for service it sould be under warranty probably in the speakers or the input board
Oct 23, 2007 | LG 50PX4DR 50 in. Plasma TV
Linking DVD/CD to Receiver
You use rca cables to hook them up to each other. On the back of your Reciever make sure it is hooked to the cd. There should be speaker outlets in the back of the reciever. You should have suroundsound, Center, left and right speaker ports. I've never seen just 2. Crazy
Oct 16, 2007 | Kenwood VR-707 Receiver
Car Audio & Video Logo
347 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
