Question about Kenmore 43052 Front Load Washer
KENMORE FRONT LOAD WASHER - PULL THE SHAFT OUT OF THE BEARINGS.
WASHER: FRONT LOAD - KENMORE - 8 YEARS
PROBLEM: VERY LOUD SOUND WHEN SPINNING - SO WE TRIED TO CHANGE THE BEARINGS , BUT IT IS SIMPLY IMPOSSIBLE TO PULL THE SHAFT OUT OF THE BEARINGS.
Q: IS THERE ANY WAY OF DOING THIS EASILY???????
  • cmicsa Jan 17, 2009
    BOB THANKS FOR HELPING, BUT THERE IS NO DAMAGE TO THE SHAFT.
    WHAT'S THE CORRECT WAY OF PULLING THE DRUM FROM THE BEARINGS?
    President:
  • 267 Answers
NO , if there is damage to the shaft you will need a drum BIG $$$$$$$$
Posted on Jan 17, 2009
  • BOB  BROWER
    BOB BROWER Jan 17, 2009
    i have a puller made just for this washer . if its real bad and falling apart you might be able to get a claw puller in there . i had to torch the race on time and ruined another one that way . so i bought a tool that has an adapter for this years ago ...... call an apliance guy or parts place around you and see if anyone has one you can borrow or rent
Makes noise in spin cycle and now it started smoking. Tub seems to spin more easy but i don't hear anything like a bearing.
LG WM2688H Front Load Washer Smoking power ... - Fixya
www.fixya.com > ... > LG > WM > LG WM2688H Front Load Washer
LG WM2688H Front Load Washer, smoking power related issues. ... is it worth trying to fix drum loud and rattles when on spin cycle, then smoke started pouring out of ...hi working till smoke came out the back and now no power - Unplug it. ... washer makenoise doing spin cycle smell smoke make the power cord warm to ...
LG 4280FR4048L Bearing - AppliancePartsPros.com
www.appliancepartspros.com > ... > Washer > Kenmore Washer Parts
Rating: 5 - ‎189 reviews - ‎$32.19
Burnt rubber smell at end of cycle from 11 yr old lg wm2277hw front load washer i hand spun inner drum it was ... Appliance: LG Washer WM2277HW ... Our LG "Tromm"washer (a.k.a. "Trommy Baby") started making a horrible ... The bearings were worn and made very loud noise in the spin cycle John A. • Punta Gorda, FL.
LG WM2455HW washing machine problem - YouTube
? 10:29
https://www.youtube.com/watch?v=__abhTwmi1I
Sep 15, 2010 - Uploaded by djmcarter
I also have an LG refrigerator, which makes a loud sound (it's the.... I am watching your video while mopping up water underneath the exact same machine right now. ... How to Fix an LG Front load washer machine that wont spin - Duration: 5:32. ...
Jan 19, 2016 | LG WM2277H Front Load Washer
Noise during high speed spin cycle
sounds like the bearings need replaced, when replacing bearings you need to replace all of them to ensure proper function and life longevity.
Dec 11, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Why does my washer make noise before the spin cycle
Depending on what the noise sounds like, these front load washers have rear bearing issues. The drum bearing is just not strong enough to support the weight and the larger the drum the more weight and I doubt they use larger bearings for more cubic feet machines. They need a buddy bearing or some sort of support to take all the weight off the rear bearing.
Nov 19, 2013 | Kenmore HE2 Plus Front Load Washer
Kenmore front loading washer drum is loose and makes loud noise when spinning?
sounds like support springs for the drum have become detached or broken. Do not use, suggest new machine as old ones not worth the investment.
Oct 01, 2012 | Kenmore Washing Machines
My Kenmore front loading washer sounds like a airplane taking off when it is in a spin cycle, is it supposed to sound like that. They are only two years old!!
I can't tell you how many times a year I have that description about a front load washer.
I always find the same problem with them too. The tub seals has let water get into the rear drum bearing making the bearing fail.
Remove the back washer panel and look at the center of the tub. You will often see little trail of grease and water residue from the seal leaking.
If you do not have a extended warranty it's can be a costly repair as you can not just replace the rear bearing. You will need to replace the outer tub that come with the bearing pre installed and often the spinner shaft too.
How to receive the best washing machine repair help on FixYa
Aug 03, 2011 | Kenmore Front Load Washer
Front load washer problems
Hello,Most likely this will be the drum bearings.
Bearings normally last quite a long time but some will fail sooner than others. Quite often bearing failure is due to a faulty drum shaft seal which allows a small amount of water through and in to the bearings. The bearings then start to rust, which then accelerates the wear on the bearings.
Thanks
May 31, 2010 | Kenmore HE2 Plus Front Load Washer
My washer is very loud when it is in the spin cycle.
if the machine is more than five years old or it gets a lot of use it sounds like the drum bearings are starting to wear. If it sounds like a jet taking off when it begins to spin then thats your problem. Basically bearings have seals which over time and use will eventually allow water in and the bearings will start to wear. Now is the time to get the bearings done before they seize. It can be a laborious and expensive job
May 24, 2010 | Kenmore 43042 Front Load Washer
Loud jet noise in spin cycle on Kenmore stackable top load washer
it is the drum bearing seal and it has gone out and ruined the bearings,you would need a lip seal kit and appropriate bearings for that particular unit,i do a lot of maytag front loads and it can take anywhere from 2 hours up to 8 hours depending how the old bearings come out and the damage to the bearing and seal surfaces,the sooner you get to it the less chance of severe damage it will cause,because water will kep on destroying bearings till they lock up and destroy the drive pulley
Mar 05, 2010 | Kenmore 44042 Front Load Washer
Kenmore 43052 Front Load Washer Logo
547 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
