Question about Audiovox Richmond 6G40-36F 6-Year Tall Gas Water Heater
Need reset code for hot water talk
The tank locked out due to the vapor sensor it is a richmond model 6G50PVW-42F
  • 90 Answers
Go to www.richmondwaterheaters.com and see if they can assist you with it. Just click on residential products on the left side of the page.
Posted on Jan 22, 2009
Reset lock out due to fvd
You can reset some models.... depending on gas control valve and FVIR design.
Some newer models you replace the sensor located on outside of tank.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://waterheatertimer.org/How-flammable-vapor-sensor-works-Therm-O-Disc-25VS.pdf
Gene
Jun 04, 2014 | Rheem 40 Gallon FVR NATGAS Low WATER...
Hot water heater womt light, flammable vapor sensor code
Most likely: Combustion chamber got too hot because air intake is clogged with dust, causing less air to flow upward through vent pipe ... the slowed flow of air caused combustion chamber to overheat.
What brand and model water heater?
Look at label on side of unit and add comment.
Otherwise call service tech to repair/ replace water heater and clean arrestor screen (air intake) and replace or reset parts as needed, depending on model number and brand water heater.
AO Smith, Bradford white, and Rheem are main manufacturers.
Each has slightly different repair protocol, and each gas control valve can also be different. So more information is needed.
Identify gas control valve:
Rheem TRD/ FVIR glass vial
http://waterheatertimer.org/How-to-repair-Rheem-FVIR.html
How to remove combustion parts to inspect for Rheem glass vial and clean arrestor screen located under combustion chamber:
http://waterheatertimer.org/How-to-replace-thermocouple.html
Sep 30, 2012 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
I have a richmond 40 gallon powervent water heater. It seems to light, but shuts itself off after about 5 seconds. I am leaning toward the vapor sensor. I know there are reset codes, but have not been...
1) Could be the vapor sensor. That's a suspect.
2) General troubleshoot: clean burner and combustion parts, clean air intake, bleed air from gas line, check gas pressure. Color of gas flame should be clear blue, and flame should be strong, and no combustion by-product dripping back into combustion chamber. No chemicals of any kind stored in air supply. Plenty of fresh air. Water heater in hot attic needs more air. If water heater has igniter, then igniter has to be checked. Flame sensor must be positioned correctly and operational at time of combustion, or sensor will signal gas control to turn off gas. Gas control valve can be bad.
Open following link for possible illustrations and reading.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
3) Specific troubleshoot begins with identifying gas control valve and reading the service manual.
I think the Rheem/Richmond power vent has intellivent gas control
Open following link to identify gas valve and download possible service manual:
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html#intelli
4) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 04, 2011 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
Water hearer gas valve locked out. has code #15 fv sensor. has no flammable vapors around. how do i reset?
If water heater has FV event, check your manual for re-setting procedure.
Look at label on side of tank for brand and model number of your water heater:
http://waterheatertimer.org/Water-heater-manufacturers.html
My understanding is that Bradford White has resettable FVIR but all other manufacturers require service technician for part replacement.
I have found one internet thread that covers do-it-yourself FV.
http://www.diychatroom.com/f7/rheem-hot-water-heater-pilot-burner-not-staying-lit-65755/
I also posted same question on water heater forums, and nobody will answer 'due to liability concerns.'
This leads me to believe there are serious safety issues that could lead to manufacturer and-or plumber liability since FV-lock-out mandates were written to reduce widespread insurance property and casualty losses.
Apr 19, 2011 | Water Heaters
We have a Rheem powervent gas water heater (50 gallon). We can't seem to get the pilot light lit, it won't light at all. The Flammable vapor sensor code flashed. We had a fire in the basement but the tank...
yep, for certain it is the vapour sensor tripped by the paint fumes. I work in the hvac field, on service and at least half a dozen times a year, i go to no hot water calls, due to the sensor being tripped off by kitty litter. the sensor is designed to be as failsafe as possible. Any slight detection of vapor, that could potentially be combustible and the ignition sequence is locked.
Mar 14, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
Audiovox Richmond 6G40-36F 6-Year Tall Gas Water Heater Logo
998 people viewed this question
Top Audiovox Water Heaters Experts
Paul Carew
jdthefixer
Richard Lindsey ...
Are you an Audiovox Water Heater Expert? Answer questions, earn points and help others
