Question about Audiovox Richmond 6G40-36F 6-Year Tall Gas Water Heater
Need reset code for richmond hot water tank model 6G50PVW-42F the vapor sensor tripped tank due to some paint fumes
  • ksshev Apr 28, 2009
    I painted in the basement with a oil base paint and it set off my vapor sensor on my 40 gallon power vent Richmond hot water heater any solutions?
I am poting this here hopefully it will help someone else. I have a richmond 40 gallon power vent water heater and it was not working. It was flashing 2-3 on the LED. I used this procedure and it started up..
you can reset the control by unplugging the blower during start up, leave unplugged for at least 5 seconds, plug back in and within 30 seconds cycle temp control from hot to low 6 times.
Posted on Apr 13, 2010
  • 3 more comments
  • Jennifer Cagle Apr 26, 2011
    L, R, L L, R L R R (Cold, Hot, C, C, H, C, H, H)
  • Ryan Brown Apr 27, 2012
    This worked great!!! Thank you for putting this up
  • sheilavangor
    sheilavangor Sep 09, 2012
    I had the same problem with my Richmond 6G40PVW - 40F
  • sheilavangor
    I first had to hold both Hot and Cold buttons until the left light starting blinking; then let go ahead and enter the code LRLLRLRR like above. Make sure you shut off the blower for at least one minute. Then you have 10 seconds for each step. If that doesn't work take the sensor outdoors for half hour for "fresh air" then try again. IF that doesnt work replace the sensor and try the code again.
  • Anonymous Sep 07, 2016
    Tom Sh, Thank you for posting the solution! I found your post within a minute of encountering an issue with my Richmond water heater today. I immediately followed your advice, and the problem was solved. :) x 10000
    New Friend:
Richman power vent light blinking 7 times. You must turn it off and wait 5 minutes also put dial to the lowest temp. once the 5 minutes is up, turn it back on and dial the knob from lowest to high 3 times then set your temperature
Posted on Apr 28, 2013
    New Friend:
Flammable vapor sensor lockout reset 7 blinking lights with a three second delay between each set,for Richmond 40 gallon propane power vent water heater. Unplug water heater wait 1 minute, set manual thermostat to low, plug in heater cycle from low to high heat and back to low seven times this will reset sensor error and unit should start up after this. If the condition continues to come back you will need to replace the sensor which you can get from Richmond. 800-621-5622 parts center. This reset worked for me. Hope this helps someone else out.
Posted on Jun 29, 2015
  • Angel Velazquez
    Angel Velazquez Jul 13, 2017
    It works thank you so much that was pretty easy. Stress free!!!!
P2270,p2271
Posted on Mar 21, 2012
5v40 hot water heater. Lite the pilot and the burner come on and work fine if i have it open at the door so air can get in. If the burner is on and i shut the door pilot and burner goes off. There is some kind of mechanical air valve in the bottom floor is this valve the problem and how to fix it.
Posted on May 17, 2011
  • 90 Answers
Go to www.richmondwaterheaters.com and see you can get the reset code from them. To the left, click residential products. Good luck!
Posted on Jan 22, 2009
Reset lock out due to fvd
You can reset some models.... depending on gas control valve and FVIR design.
Some newer models you replace the sensor located on outside of tank.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://waterheatertimer.org/How-flammable-vapor-sensor-works-Therm-O-Disc-25VS.pdf
Gene
Jun 04, 2014 | Rheem 40 Gallon FVR NATGAS Low WATER...
Richmond gas water heater need reset code
Intellivent gas control can be reset on some units.
Honeywell does not make Intellivent.
1) Copy following links:
http://waterheatertimer.org/How-to-repair-Rheem-FVIR.html
http://waterheatertimer.org/How-to-replace-thermocouple.html
2) For Rheem, there is a glass vial that is broken if FV system tripped.
This requires new glass vial, which Rheem may send depending on model.
It might also require new parts such as gas control valve, and/or replacement FV sensor depending on model.
Some models require full replacement of water heater.
Each model can be different.
3) Rheem does not post service manuals, and says customers should call service technician.
Combustion parts are held in place with tamper-proof screws and combustion door gasket might need to be replaced when removed from front of unit.
Jan 29, 2013 | Water Heaters
Hot water heater womt light, flammable vapor sensor code
Most likely: Combustion chamber got too hot because air intake is clogged with dust, causing less air to flow upward through vent pipe ... the slowed flow of air caused combustion chamber to overheat.
What brand and model water heater?
Look at label on side of unit and add comment.
Otherwise call service tech to repair/ replace water heater and clean arrestor screen (air intake) and replace or reset parts as needed, depending on model number and brand water heater.
AO Smith, Bradford white, and Rheem are main manufacturers.
Each has slightly different repair protocol, and each gas control valve can also be different. So more information is needed.
Identify gas control valve:
Rheem TRD/ FVIR glass vial
How to remove combustion parts to inspect for Rheem glass vial and clean arrestor screen located under combustion chamber:
Sep 30, 2012 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
Detecting gas and won't light
Open following link for troubleshoot error codes showing 7 flashes on Honeywell gas control valve is system lockout due to flammable vapor:
http://waterheatertimer.org/pdf/Honeywell-gas-control_error-Damper-series.pdf
The FV system in Rheem can be tripped by presence of flammable vapors such as gasoline or paint fumes etc, or it can be tripped if water heater was dropped, or mis-manufactured, or if gas control valve is defective, or if water heater is not getting adequate fresh air, or there is inadequate venting of combustion by-product.
When combustion chamber overheats, then glass vial breaks and damper shuts off air supply to water heater and it will not light.
Open following link for possible help fixing the problem:
Jun 13, 2012 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
No hot water, unit will not fire,
It sounds like the Flame vapour sensor has tripped. Have you been painting in the basement recently or have and pait thiner, bleach or any other flamable material in the same room?
You will have to air out the room for at leaset 24hrs to get the fumes out and then try reseting the tank. If this doesn't work you need to call in a service technition to reset the FVIR sensor
Jul 02, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
We have a Rheem powervent gas water heater (50 gallon). We can't seem to get the pilot light lit, it won't light at all. The Flammable vapor sensor code flashed. We had a fire in the basement but the tank...
yep, for certain it is the vapour sensor tripped by the paint fumes. I work in the hvac field, on service and at least half a dozen times a year, i go to no hot water calls, due to the sensor being tripped off by kitty litter. the sensor is designed to be as failsafe as possible. Any slight detection of vapor, that could potentially be combustible and the ignition sequence is locked.
Mar 14, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
Need reset code for hot water talk
Go to www.richmondwaterheaters.com and see if they can assist you with it. Just click on residential products on the left side of the page.
Jan 17, 2009 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
GG50T06PVJ 2 yr old unit, no hot H2O, ECO Failure code.
Parts should still be under warranty. Call the manufacture at 800-432-8373.. Have your model & serial number. A tech agent should be able to assist you.
Jan 16, 2009 | General Electric GE SmartWater Household...
Audiovox Richmond 6G40-36F 6-Year Tall Gas Water Heater Logo
9,328 people viewed this question
Top Audiovox Water Heaters Experts
Paul Carew
jdthefixer
Richard Lindsey ...
Are you an Audiovox Water Heater Expert? Answer questions, earn points and help others
