Question about Microsoft LifeCam VX-6000 (68C-00001) Webcam
Webcam microphone sound
When I installed the webcam, I had it plugged into the front of my computer, then later moved it to the back, now I have several sound devices installed example lifecam1, livecam2, livecam3 livecamV and the sound does not work, when I run the software the microphone just turns all the way down and I can not change anything, I have unistalled it and everytime I re-install I just get a new driver number and it never works.
  • richie_mulle Jan 17, 2009
    Tried that, still nothing, all I get is noise when the microphone is on, I wish when you un-installed software it would get rid of everything that was install, but I guess this crappy software did not get rid of everything and thats why I keep getting new updating drives everytime I unplug it and plug it back in, and I get a new driver name and the problem is always there.just might have to get a new cam from another company, never had good luck with Microsoft products.
  • 106 Answers
My grandfather told me something a long time ago.. if something works don't try to fix it..
plug it back into the front of the computer.. good luck ray
Posted on Jan 17, 2009
ConnectLand cl-me 606 goose neckdesktop microphone to desktop
Look for a 3.5 mm microphone port on the computer. Usually the port on the back of the desktop will have a pink surround. (There will be other ports there; the usual minimum are the green port for speakers and blue one for line-in.) Put the 3.5 mm jack on the end of the cord on the microphone into the port. If you have an add-in sound card, use the microphone port on the sound card.
Some machines will also have a front panel microphone port. This will have a small mike icon next to the port.
Next you need to ensure that the audio device is set to Microphone. For Windows systems (Vista/7/8), enter the Control Panel and go to the Hardware and Sound panel. Click on Manage Audio Devices under Sound. Then click on the Recording tab. Check if the microphone listed as plugged in. Make this the default recording device. (XP has a slightly different name for the panel.) For XP through Windows 7, click on the start button and then find the Control Panel listed on the right. For Windows 8, from the desktop, press the Ctrl and X keys at the same time. Then find the Control Panel in the list. (Alternatively, activate the Charms menu, Ctrl+C or hover on the upper right of the screen. Move down and click on the gear (Settings). Then select the Control Panel.)
If the computer doesn't indicate that the microphone is plugged in, make sure that the 3.5 mm plug is in the correct port. Next try the microphone on another computer. The audio card port could be damaged or the microphone cable could be faulty. If the microphone works on another computer, you can try a USB audio adapter (StarTech ICUSBAUDIO or similar) or a new sound card. (Note: some older sound cards do not work properly on newer versions of Windows. If you have a sound card installed and the motherboard has an on-board audio device, remove the sound card. Enable the on-board audio in the computer's BIOS. Install the appropriate audio drivers. Try that audio device. Accessing the BIOS will depend on computer. Often you can press Esc, F1, F2, F10 or Delete repeatedly after you turn on the computer. If Windows starts to boot, turn off the system and try again.) If another computer doesn't recognize the microphone, I'd recommend a new microphone. Fixing the cable isn't worth the effort.
I hope this helps.
Sep 20, 2013 | Computers & Internet
Microphone on imicro webcam not working
Click start control panel view devices and printers you should see your webcam from there if you are have trouble with your webcam Click start control panel administrative tools ,computer management ,device manager scroll down or click start right click on computer select properties device manager scroll to image devices image devices you could see a yellow question mark? right click to reinstall drivers or update driver Some webcams and programs require additional software, although that should be installed with the webcam if things are right. But is does not harm to check if your Java, Flash and Quicktime software are installed and up to date. But certainly check your DirectX software, since all video applications, including webcams, use DirectX for video processing. Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c - Windows Vista: DirectX 10). http://windows.microsoft.com/en-US/windows7/Which-version-of-DirectX-is-on-your-computer click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it also during a video call at the top of your screen you will see an option to for a video call using yahoo messenger this might vary if you are using another messenger service
Apr 05, 2013 | Imicro 1.3MP PC WEBCAM W/MIC
No sound
Webcam Audio Getting sound to broadcast with streaming video using a webcam requires a few components to work in unison. Because most webcams do not have a microphone built in, you will need to buy a microphone for your computer or locate your microphone input if you have one built in (some laptops have these). The audio and video are two separate functions and must be diagnosed as such. b> Webcam Software b> If you have a webcam set up correctly and you are streaming video, then you are already halfway there. This details only how to make the sound work, so please refer to an article related to webcam video if you do not have that working already. The webcam audio and video both communicate with your computer via your webcam's software application. Due to this, you will find that there are settings specific to your webcam software for sound. Because there are various software applications that can act as an interface for your webcam, you will want to do a product-specific search on the Internet for your application's settings. Most often you will find the settings for sounds under Tools or Settings, then choosing Options or Preferences. Regardless of the application that you are using to broadcast your webcam video, you will need to ensure that your microphone is plugged into the "Microphone In" jack on your computer or laptop. The microphone input jack is commonly colored pink. b> Microphone Connection b> With your microphone plugged into the "Microphone In" audio jack, test the audio inside your webcam's software application. Most webcam applications allow you test your microphone by reading a sentence and watching a graph move as you speak. If you see this happening, then you have correctly hooked up your microphone. If you have a Windows PC you should also see if your computer recognizes your microphone by clicking on "Start" > "Settings" > "Control Panel" > "Sounds and Audio Devices." Under the "Audio" tab you will find a section for "Sound Recording." From there you can select or change your "Default Device." b> Hardware Troubleshooting b> In the event that your microphone is not recognized by your computer, continue hardware troubleshooting by contacting your computer's support staff. With a properly connected microphone and some minor adjustments in your webcam's software application, you should be broadcasting audio with your video in no time. Hope this helps.
Jan 22, 2013 | Gear Head Gearhead quick webcampro...
Can I add a webcam to my computer and do I need a mic?
Yes, you should be able to add a webcam. If your computer is running XP or later, you can find cameras almost anywhere. For Mac machines the selection is more limited, but Mac-compatible cameras are available. Cameras typically have a microphone built in, so you don't need a separate one. You don't actually need a microphone at all to use a camera, but if you want to use programs like Skype or do video chatting, you need one for the sound. The webcam will come with a disc containing the necessary drivers and installation program, so getting it working is usually not a difficult job.
Aug 04, 2011 | Computers & Internet
Logitech Webcam Microphone not working
You may have a laptop with another mic installed or other mic software installed
try setting the webcam mic as default
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Jun 14, 2010 | Logitech QuickCam Communicate STX Personal...
We got a new computer and it comes with a built in webcam but when i try and use the cam on msn it wont work...it just goes all fuzzy. what can i do to fix it?
Configure a webcam can take the course, however, a series of simple manipulations can improve the performance of your equipment.
Launch the Configuration Wizard
Close your audio or video conversations.
Then, in the main MSN window, go to:
Tools> Adjustment of audio and video
Adjust the picture
Once the setup wizard started, let yourself be guided by it.
Select your webcam (its name should appear in the list) and click "Next."
A window appears and prompts you to set your webcam. Check the layout and image sharpness. If the image is fuzzy, adjust the lens of your camera until the image is sharp. Then click next.
Adjust the sound
Once the camera set, the wizard offers to adjust the sound. To do this, select your microphone in the selection, either the webcam or a microphone plugged into the microphone on your computer.
Then select the speaker output of your sound card to hear from your speakers.
The wizard will then adjust the volume of your microphone. To do this, move the cursor until the sound obtained is satisfactory. Then click "Finish". Configuring your webcam is complete.
Dec 30, 2009 | Toshiba Satellite A135-S2276 Notebook
WEB CAM NOT RECOGNICED
Step 1: The "Tools" menu of Windows Live Messenger
1. Recover Windows Live Messenger in our software if you do not have it yet.
2. Start the installation of the software.
3. Once this is done, go to the Tools menu software.
In this menu, two links are important in order to properly configure your camera:"Setting audio and video" and "Parameters of the webcam."This is the first that we will discuss first and foremost, the second used primarily to adjust the parameters of the image in the secondary stage but we are dealing with. Launch therefore setup wizard and click on "Next".
Step 2: The setting of loudspeakers
1. Select your hardware in the menu.
2. Check the box if you use a helmet.
3. Test finally your sound output in order to adjust the volume.
It is possible that you find in the menu several choices. That means you have several elements in your computer capable of transmitting sound, a dedicated card and your motherboard, for example. In this case, make sure to select well the correct input, what you quickly verify the test by loudspeakers.
Step 3: At the turn of the microphone
1. Select your sound source.
2. Start talking to your microphone.
3. Observe the cursor, if it moves, your microphone is working.
Two remarks on the stage configuration. On the one hand, if your camera has no microphone, you must go through a device that you must annex plug into the pink on your sound card. On the other hand, if your mouse does not work, you may have selected the wrong input device sound. Take particular care in this setting and not leave this page only when the cursor s'agitera,
indicating that your voice is recognized by the software.
Step 4: Turning finally to the image
1. Specify this time the source of the video.
2. Observe the window of return: if your setup is satisfactory, your image should appear.
3. Adjust the frame rendering through the "Option" button.
Aug 03, 2009 | Microsoft LifeCam VX-3000 Web Camera
Soundmax microphone error
Check your front panel connectors are wired correctly :)
Nov 14, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Sound
Normal 0 Go to Control Panel and Click on Sounds, Click on Audio, then Click on the Microphone. Then Click on the drop down and select Camera Microphone or sound card installed in your computer..
Click OK and it should work.
Hope this helps. Bud
Jan 22, 2008 | Logitech Webcam
Microsoft LifeCam VX-6000 (68C-00001) Webcam Logo
100 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
