Question about Whirlpool Calypso GVW9959K Top Load Washer
WHY is water leaking under the unit. It's not the supply hoses.
.Why is water leaking from under my washing machine?
  • Anonymous Jan 18, 2009
    I have the same problem but it leaks some time when the temp of the laundry room drops below 60 F. Anyone knows why that happens please let me know. Thanks
  • santosh_gaut Jan 21, 2009
    MY WASHING IS LEAKAGEBY DRAIN PIPE IF DRAIN PIPE IS CLOSED .
  • 4 Answers
Using too much laundry soap.
Posted on Mar 19, 2009
    Sergeant:
    Champion:
  • 239 Answers
Pump seals are bad
Posted on Jan 17, 2009
Water leak from bottom of unit
Loose/broken clamp or drain hose. Fill hoses attached to fill valves or leaking pump housing.
Jul 29, 2014 | LG Washing Machines
My samsung washing machine 8.0 kg diamond drum model WA104F does not function and no water comes out from the source but power supply is ok
Turn off the water going to the washing machine, and disconnect the hoses at the machine (put a pail under each hose to catch drips or leaks from the shutoff valves). Inspect the strainers at the hose connectors on the machine - they may be clogged with lime or sediment. If so, use a wet-or-dry vacuum cleaner (e. g., ShopVac) to clean the strainers, or if they are easily removed, you can back-flush them under a faucet.
Even if one valve is plugged, the machine may shut down until the problem is corrected. Some models flash an error code indicating a water supply problem - see your owner's manual.
Dec 02, 2013 | Washing Machines
Water underneath unit
Check your water hoses may be leaking behind the machine or at the tap.If the hose is leaking turn all taps off. the alloy crimp needs to be cut off & put a hose clamp on the hose.turn all taps off when machine has finished the wash.
Feb 01, 2013 | Fisher and Paykel GWL11 Top Load Washer
Hot water connected but does not fill into the drum? The machine will provide us with a cold wash but on the warm and hot settings the hot water dies not pull through the connection
Turn off the water valves which supply the water to washer hoses. Switch the hot and cold water supply hoses and tighten. Turn the water valves back on and try to run a wash cycle using cold. If hot water only is entering the wash tub the water supply is ok. If this is the case you can unplug the washer and turn off the water valves. Remove the washer back cover and follow the water connection for the hot water. The water solenoid valve will have two electrical wires connected to it. Interchange the hot water solenoid wires with the cold water solenoid connection. Connect the water supply hoses hot to hot and cold to cold then plug the unit then test the washer on the cold wash. If the problem persists it could be a water hose restriction or the timer circuit could be defective. If you have hot water at the normal pressure purchase a new hot water solenoid valve. With the electrical cord unplugged be sure to restore the correct wire connections on the hot and cold water solenoid. To replace the hot water solenoid remove the hose clamp and hose to replace the old valve. Connect the unit to the water and electrical outlet. Turn on the water and test the unit for leaks being careful not to touch any electrical and moving parts. If all checks ok and the correct temperature work, unplug the unit and reassemble.
Jun 21, 2010 | Admiral AW22 Top Load Washer
Problem : Water leaking out from under washing machine
NOTE. PLEASE UN-PLUG THE UNIT FROM THE ELECTRICITY SUPPLY BEFORE ATTEMPTING THE FOLLOWING JUST TO BE SAFE:-
Problem may be due to a blocked dispenser hole. Completely remove the dispenser unit and check for blockages in the hole where the water goes in. If you cant see anything immediate, take the top off. (Remove the 2 self tapping screws on the back holding the top on). Looking at the unit from the front. look inside where you took the top off and locate the rubber hose that connects the dispenser unit to the drum (it's a tight space, but if you look inside , front left you will see where the hose connects to the drum). Remove the hose and check for blockages. (The hose just pushes into the drum). Let me know. I had a similar problem and found that somebody had shoved a sock and pair of knickers down the water dispenser hole. This was also causing the machine to make a loud noise when spinning. Have you also checked the filter in the bottom right hand corner of the unit ? You have to remove the kick panel to get access to it.
Jan 20, 2010 | Ariston Technologies Washing Machines
It is leaking under the washer tub
Leaking water from a washing machine usually comes from hoses or connections. Be sure that water appearing to be a
leak isn’t drain water from a backed-up standpipe. To prevent potential flood damage, which can occur if washing
machine supply hoses burst, be sure to install “no-burst” stainless-steel mesh hoses and lever-type shutoff valves,
as shown below. With these, you can easily turn off the levers for both hot and cold water between wash days.
1) Check the fittings where the hoses connect to the faucets and to the back of the washing machine. Also look for
worn or leaky hoses. Tighten couplings or hose clamps if needed, or replace the hoses altogether. Be sure to turn
the water off before removing the hoses, and drain them into a bucket after disconnecting them.
2) Determine whether the machine is oversudsing, which can cause the machine to overflow. Reduce suds by pouring 1/2
cup white vinegar in 1 quart water into the washer. Then switch to either less detergent or a low-sudsing variety.
3) The machine may have a faulty basket gasket or tub seal and bearing that must be replaced; in this case, call an
appliance repairperson.
Thank You for contacting fixya.com
Oct 12, 2009 | Washing Machines
WATER LEAKING FROM UNDER THE WASHING MACHINE
follow the hose from where it connects into the washer.. take off that panel and pinpoint leak. more than likely a hose is unattached
Apr 15, 2009 | GE WWSE5200B Top Load Washer
Water leaks under machine
Hi, * Inspect the water supply connections * Inspect the drain hose * Inspect the water pump * Inspect outer tub for cracks or corrosion * Inspect the tub seal * Inspect the tub bearing Pls rate my solution...
Mar 02, 2009 | Admiral AW22 Top Load Washer
Washing machine is leaking water and leaking oil.
1. Find out where the leak is coming from. Does it leak constantly or during one part of the cycle?
A constant leak means the leak is in the valve where the hoses hook to the washer, the supply valves, or the lines to the washer from the water supply.
The other two options are when the washer is agitating or pumping the water out between cycles.
2. See if it leaks during both cycles and the test there would be to lift the lid just as it starts to drain and wait to see if the water stops leaking.
If it doesn't, then run the drain cycle to see if it gets worse or better.
Results may not be immediate as it would take a few minutes for whatever water there to finish dripping.
3. Wait until the water has been pumped out, lift the lid and check the drip again.
When the location of the leak has been determined, unless the washer has been frozen, most leaks can be fixed without parts and just using hand tools.
If you have an older, top load washer, the back or front will come off so you can observe where the leak is coming from.
WARNING. You are working with a moving, electrically hot machine that could flood.
You must take your time and not put your hand or hair in somewhere that can catch you.
You should not have to get into the upper control center, thus reducing the shock hazard.
4. Before turning the machine on, remove a cover. On some washers, there are two screws on the bottom L & R front corners that take the front panel loose.
Once the screws are removed, the front cover is hinged at the top and you simply pull the bottom away from the machine until it comes un-hooked, and set the cover aside.
There shouldn't be many exposed wires or ends, but a few. Don't touch the terminals or lay something metal in the machine that could fall on the terminals.
5. Take a flashlight, look for obvious leaks or better, water stains around nuts, hose clamps, etc.
Most likely you'll see some water residue here and there and that would be normal as a washer is wet. Look for puddles, long white streaks, calcium deposits.
Most likely, you won't find standing water, but some clues of where you should look when the machine is running.
Unless this leak is so obivous you can see what's wrong, you don't need to start it and you should repair the problem.
Once possible areas have been identified, you should start the machine as if you had a load in it and start to watch for the leak.
WARNING- Make sure you have no tools laying in the machine and you are out of the way. There are spinning parts and live wires once you turn the machine on.
Stay clear, and watch your hair and hands.
Once the machine is full and starts its cycle, look for leaks.
Let the machine do its cycle and as it goes into each part of the cycle, look for the leak.
Once you find a drip, stop the machine by lifting the lid or pulling out on the control knob, and now observe more closely.
Remember, water runs down; where it drips is not necessarily the place of origin.
6 Find the leak and make the needed adjustment (which will be all that is necessary most of the time).
If it is a part you need, get the make, model number and serial number of the washer and call an appliance parts dealer or repair service if you don't think you can repair the problem.
If the washing machine leaks water while it is filling, pull it away from the wall and see if the water drips from the inlet hoses or valves as the unit fills.
If it does, tighten the faucet packing nuts. Then, inspect the hoses and replace them if they have become cracked.
Also look for cracks in the casing of the inlet valves. Unplug the unit and lift the top to better inspect the valves.
Replace any valves that are cracked.
Valves usually crack when the hot water in the house water supply is heated to greater than 170 degrees.
They also crack if the house is left cold during the water and water is not drained from the unit. A cracked inlet nozzle can leak during fill.
The leaking water will drip down the outside of the tub and collect under the unit. Be sure that the hose connected to the inlet nozzle is tightly clamped.
Replace the nozzle if you find cracks in it.
If the leaking occurs at some time during the wash sequence other than when the machine is filling with water, unplug the unit, remove the back panel and examine the parts under the machine.
You can make a closer inspection by tipping the unit over onto it's front or side.
Tighten hose clamps that have become loose. If water is leaking from the pump, replace the pump.
The gasket between the tub and the splash guard may wear out and leak. To check the gasket, lift the top and remove the snubber and splash guard.
Replace a worn gasket. A hole in the bottom of the tub can develop.
If the hole is less than 1/4 inch in diameter, remove the agitator and basket and seal the hole.
If the hole is larger, replace the washing machine or tub.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 03, 2009 | Kenmore 98702 Stacked Washer/Dryer
Washing machine is leaking!
First check your supply hose for cracks or splits. If cracks are apparent the hose must be replaced. If none are apparent I would suggest taking apart the connection and checking the gasket or washer inside the fitting. If it has decayed or cracked this could be the culprit. Replace the gasket or washer with the same size. these are availiable at any hardware or home improvement store.
Jan 13, 2008 | GE WSM2700W Unitized Spacemaker Washer and...
Whirlpool Calypso GVW9959K Top Load Washer Logo
140 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
