Question about Kenmore 43052 Front Load Washer
WE HAVE A FRONT LOAD WASHER "KENMORE" 8 YEARS OLD. RECENTLY IT'S MAKING A VERY LOUD NOISE WHEN SPINNING AND BROWN OILY RESIDUE COMES OUT OF THE DRUM STRAIGHT ON THE LAUNDRY. WE TOOK THE WASHERS APART AND WHEN WE GOT TO THE POINT OF PULLING THE AXEL FROM THE BEARING , LOOKS LIKE IT IS IMPOSSIBLE TO DO IT. QUESTION: IS THERE ANY WAY THIS CAN BE DONE, ANY METHOD OF DOING IT MORE EASILY ? thank you, CHRIS
  • 640 Answers
The water swelled the shaft of the spin surport..you should have recieved the wash basket under warranty,,,the back tub bearing you have to by,,even and you can knock the basket out,,it wont do you any good because the tub seal its in that back bearing tub and it had a leak,,,but if you have to..set the plastic tub on the edge of a solid table,,,shoot your wd 40 duwn the shaft,,cover spin end of shaft with wood,,,and hit down slow and steady..onthejob
Posted on Jan 17, 2009
Makes noise in spin cycle and now it started smoking. Tub seems to spin more easy but i don't hear anything like a bearing.
LG WM2688H Front Load Washer Smoking power ... - Fixya
www.fixya.com > ... > LG > WM > LG WM2688H Front Load Washer
LG WM2688H Front Load Washer, smoking power related issues. ... is it worth trying to fix drum loud and rattles when on spin cycle, then smoke started pouring out of ...hi working till smoke came out the back and now no power - Unplug it. ... washer makenoise doing spin cycle smell smoke make the power cord warm to ...
LG 4280FR4048L Bearing - AppliancePartsPros.com
www.appliancepartspros.com > ... > Washer > Kenmore Washer Parts
Rating: 5 - ‎189 reviews - ‎$32.19
Burnt rubber smell at end of cycle from 11 yr old lg wm2277hw front load washer i hand spun inner drum it was ... Appliance: LG Washer WM2277HW ... Our LG "Tromm"washer (a.k.a. "Trommy Baby") started making a horrible ... The bearings were worn and made very loud noise in the spin cycle John A. • Punta Gorda, FL.
LG WM2455HW washing machine problem - YouTube
? 10:29
https://www.youtube.com/watch?v=__abhTwmi1I
Sep 15, 2010 - Uploaded by djmcarter
I also have an LG refrigerator, which makes a loud sound (it's the.... I am watching your video while mopping up water underneath the exact same machine right now. ... How to Fix an LG Front load washer machine that wont spin - Duration: 5:32. ...
Jan 19, 2016 | LG WM2277H Front Load Washer
Kenmore front loading washer drum is loose and makes loud noise when spinning?
sounds like support springs for the drum have become detached or broken. Do not use, suggest new machine as old ones not worth the investment.
Oct 01, 2012 | Kenmore Washing Machines
We bought a kenmore front loading heavy duty washing machine with 2-way tumble in Feb 2003. Recently two problems have become evident. First, our clothes have started to have black marks (streaks and...
Likely the cause is grease from a failing rear bearing.
Unfortunately, it's cheaper to buy a new washer than to fix this one. That's pathetic for a washer that's only 8 years old, and completely negates any environmental and economic benefits of buying a front loader.
Jan 29, 2011 | Kenmore 44102 Front Load Washer
Front load duet whirlpool makes loud roar when it spins - no error code. Machine is only about 1 year old and just started making this noise recently
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Oct 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
LG washer - loud noises & brown spots on clothes.
The drum bearing has perished this wild cause the noise and the brown spots on your clothes is probably the grease from the bearing
May 05, 2017 | LG WM2077CW Laundry XL Front Load...
Loud jet noise in spin cycle on Kenmore stackable top load washer
it is the drum bearing seal and it has gone out and ruined the bearings,you would need a lip seal kit and appropriate bearings for that particular unit,i do a lot of maytag front loads and it can take anywhere from 2 hours up to 8 hours depending how the old bearings come out and the damage to the bearing and seal surfaces,the sooner you get to it the less chance of severe damage it will cause,because water will kep on destroying bearings till they lock up and destroy the drive pulley
Mar 05, 2010 | Kenmore 44042 Front Load Washer
Have a g/e front loader and makes a loud noise when spinning,machine is 2 years old or so
Could be a few things including worn drum bearings,, Does inner drum have adverse play?
Feb 22, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Front load washer model 3 970-c29042-00 The washer is making a loud noise and shakes like something is loose when the drum is turning..
I have a kenmore front load washer, model: 417 42042100
It makes loud noise and becomes louder during the spin cycle.
The drum is loose when I inspected through the front door.
My problem is how to open the cabinet and replace any broken parts.
Thanks.
Aug 04, 2008 | Kenmore 46462 Front Load Washer
Kenmore front load washer
My Kenmore front-load washer starts to make the huge noise. The noise happens during the wash cycle, but is mild. During the spin cycle, the noise becomes really loud. It looks like the drum is getting loose and hitting other part of the machine.
I checked the drum, and I can sway the drum easily with my hand. So it looks some supporting structure is broken. I don't know if it is easy to open the washer to check what has been broken.
May 20, 2008 | Kenmore 44072 Front Load Washer
Noise during spin cycles
GE WPXH214ACC Washer drum makes loud noise when spinning sometimes. We've had it since 2005 & never had this happen before. Washer is level, must stop & redistribute clothes to correct. Just started happening now.
Oct 12, 2007 | Washing Machines
Kenmore 43052 Front Load Washer Logo
265 people viewed this question
Sal De
fordexpert
Robert Rankin
