Question about Linksys WRT160N Wireless Router
Keep losing internet connection on the desktop
Hi joe just picked up a linksys wrt160n and i seem to have a good wireless
connection to my ps3 but the wired connection to my pc keeps coming up
as internet explorer not found or unavailable on occasion. It will be up as it is right now for a bit but will then go down. Not to familiar with routers so not sure what to do to fix the problem. Thanks for any help you can give me.
Chris
  • mpodhola Jan 23, 2009
    Same Problem - Everytime I let Internet Explorerer sit idle for only a few minutes it won't connect and I have to have to go to the Linksys page and ping every time to get it to work. Tried the solution but it is still doing the same thing.
I solved this by returning it and getting the Netgear which was cheaper. So far not a problem!
Posted on Jan 26, 2009
  • 258 Answers
First you need to find a Windows wired or wireless device already connected to the network in order to find out the required settings
Windows XP
1. Click start --> (sometimes settings) --> Control Panel --> Network Connections
2. Double click on the active connection which will say connected underneath
3. Click Support
4. Click Details
5. Now the IP Address, Subnet Mask, Default Gateway, Primary DNS and Alternate DNS which are displayed should be noted.
Note these down and set these values on your PC by doing the following:-
Start --> Control Panel --> Network Connections --> right click on Local Area Connection --> click Properties
In the small middle box scroll down to Internet Protocol TCP/IP
and click to highlight
Click properties button and enter the values
Click OK
Click Close or OK
2 other things can also stop your wireless connection from dropping:-
Change the Channel transmitted in Wireless Settings
Defrag your hard disk
Posted on Jan 20, 2009
Internet lose on my wrt54g2
please reset the router
configure the router type ip address on the browser
may be 192.168.1.1
Oct 29, 2009 | Linksys WRT54G2 Wireless Router
Linksys WRT160N Connection Issues.
Sadly, this router has horrible reviews and is known for this problem:
http://www.newegg.com/Product/ProductReview.aspx?Item=N82E16833124277
Can you return it for another model?
Can you getLinksys to replace it?
the best one is the LINKSYS WRT54GL, but if you are stuck with the one you have...
If you have tried all these things and you are very brave (or don't care if you need to buy another router) why not try flashing it with an after market O/S?
1) http://www.coderetard.com/2008/05/30/install-dd-wrt-firmware-on-linksys-wrt150n-wrt160n-wireless-routers/
2) http://www.dd-wrt.com/phpBB2/viewtopic.php?t=32576&highlight=wrt160n
Oct 13, 2009 | Linksys WRT160N Wireless Router
Linksys wrt160N router inconsistant internet connection
Check on your cables makes sure they are inserted properly and the cord should be free of kinks, scrapes or loose connections......Also check the back of your computer make sure your ethernet card (the one that has the green lights/LED's) is seated properly (not loose)....
Good Luck.....hope this helps...if not let us know....cheers
Apr 13, 2009 | Linksys WRT160N Wireless Router
LInksys wrt160n v2 wireless router not connecting to internet
Most cable companies will only allow 1 active device at a time conneceted to the cable modem. When ever you change what is connected to the cable modem you must always cycle the power/reset your cable modem.
When you are reseting the units, always rset the cable modem first, wait until it boots back up then reset the router. If that doesn't fix the poblem then it may be a configuration problem.
I forgot to ask if you are cable or DSL.
Hope this helps
Apr 09, 2009 | Linksys WRT160N Wireless Router
Lost internet connection
Change the wireless channel of the router to channel 1, 9 or 11. Usually other routers use channel 6. If there are other wireless devices on your area like a wireless cellphone, microwave, try to relocate them or the router itself. Place your router on a higher location so that you will be able to get a better signal.
Feb 09, 2009 | Linksys WRT160N Wireless Router
Problems connecting my desktop
Press and hold the reset button on the router for 30 seconds. than turn the router OFF and turn it back On after 5seconds.
Than Restart the computer.
Please keep the post updated.
Jan 10, 2009 | Linksys WRT160N Wireless Router
Just got a gateway gm5084 for my children... wireless not working
You have driver issue. Keep it simple and just go out and get a wireless usb adapter that works with your OS and you are good to go.
Aug 31, 2017 | Gateway GM5084 PC Desktop
Connecting new Linksys WRT160n to existing modem Westell 7500
You have to call your internet provider and ask them to help you put the Westell modem in "Bridged ethernet" mode. This will by-pass the Westell modem and use your linksys as the wireless.
For AT&T:
http://www.dslreports.com/faq/6405
Site with good info:
http://www.voip.com/help/Residential/Installation/Networking/bridged_westell.aspx
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Dec 15, 2008 | Linksys WRT160N Wireless Router
Limited or no connectivity to the internet. my setup: the telephone port is approx 30m from where i need internet access. Originally I had a dlink wireless router set up but was connected via cable, now...
On which port of the D-link router did you plug the WRT160N router?
Do this setup.
Disconnect the WRT160N from D-link.
Connect a computer to port 1 of the WRT160N. Access the setup page by typing 192.168.1.1 on the address bar. you may need to type in the username and password for WRT160N. on the setup page Change the LAN IP address from 192.168.1.1 to 192.168.2.1. save the settings.
Connect a cable from port 1,2,3 or 4 of the D-link router to the Internet port of the WRT160N. turn off everything then turn them on starting from cable modem>D-link >WRT160N then computer.
You should be able to access the internet.
Oct 08, 2008 | Computers & Internet
Linksys WRT160N Wireless Router  Logo
385 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
