To much flame with my Mr Heater. What do I do?
What do I do to reduce flame. flame is blue with yellow tip
  • Heating & Co... Master
  • 2,899 Answers
Reduce the air to burn on the burner you should be able to do this where the burner fits on to the injector
Posted on Jan 17, 2009
2 Suggested Answers
keith91gmc
  • 52 Answers
SOURCE: my blue flame heater has yellow tipped flames?
yes air to fuel ratio is off
Posted on Dec 19, 2009
My Mr. Heater 10,000 BTU Natural Gas Blue Flame Vent Free Heater #VF10KBLUENG keeps going out soon after it is lit.
Yellow flame indicates insufficient air is being injected into the mixing chamber - air hole blocked or restricted maybe.
Yellow flames indicate a general lack of oxygen and also a yellow flame is dangerous as it is producing high levels of carbon monoxide.
Dec 26, 2017 | Mr. Heater Heating & Cooling
My delonghi blue flame heater has a continuous yellow flame is this normal and should it have ceramic panels
Yello is bad. The tips of the flame must be blue for proper combustion . There is an air mixture adjustment that must be made to decrease the amount of carbon monoxide. On the burner, there is a metal part that has slots on it and a screw holding it in place. Loosen the screw and , with the heater flame on, rotate that metal part until blue flame tips are seen.
Oct 30, 2016 | DeLonghi Heating & Cooling
I have a Mr Heater infra red propane wall heater. My problem is it turns itself off (pilot light) after running for an hour or two. I have no problem getting it turned back on but for some reason it d
Your pilot flame should be blue with a small yellow tip, and it should cover the thermocouple (a small rod in front of the pilot light). If the flame is too small and doesn't cover the thermocouple, it may be adjusted too low, or you have low gas pressure or you have a leak in your gas line coming in to the heater. If the flame looks like a lazy yellow flame, you are probably not getting enough air to the flame. Check that your air openings around the pilot are not clogged up. If the flame looks like a waving blue flame then you probably have excessive draft at the pilot. If the pilot flame looks good and covers the thermocouple, then the thermocouple might be bad. Best of luck. I hope I have helped.
Nov 23, 2013 | Heating & Cooling
Heater will not stay lite
It can either be your pilot orifice is dirty and not sufficiently heating the thermocouple or your thermocouple is defective and needs to be replaced. Is your pilot flame yellow or blue? It should be a strong blue flame impinging directly on the thermocouple. If it's not, shut it down, take a can of compressed air and blow out the dust, spider web or whatever is inside the pilot assembly where the pilot flame is. Then try relighting it and see if that improves the flame and keeps it lit. Otherwise, just replace the thermocouple. Douglas
Sep 30, 2010 | Mr. Heater (F274825)
My blue flame heater has yellow tipped flames?
yes - it needs to be serviced on a regular basis. It will have an accumulation of dust in or around the burner
Dec 02, 2009 | Procom ML300HGA Heater
Orange flame color
Blue with orange tips should be fine yellow is 02 starved need to vent [good air movement]
Please rate. Thank you. jj505
Mar 27, 2009 | Whirlpool Water Heaters
Propane convection heater won't maintain full flame
Seems like the valve is not opening up fully or the adjustment is out of adjustment. Try adjusting the flame.
Feb 15, 2009 | Mr. Heater Mr Heater Portable Buddy...
Vulcan Oil Heater
move the collar away from the orifice for a blue flame. too little air causes incomplete combustion so you get the yellow tinging
May 18, 2008 | Heating & Cooling
Heating & Cooling Logo
212 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
