Question about Canon PC-950 Black and White Copier
Copier Not Initialising properly
Problem Details. 1. Scanner not initialising completely, 2. Scanner Lamp not on 3. Error Codes "E2 & 20" on Copy 4. Paper is fed partially, I have check the Lamp and it is not blown (10 Ohms) I have visually check the Paper pickup clutch, looks OK. ( I didn't strip it). I have visually inspected all the components on the Main Board, All look OK. No Burnt or Damaged components. *** I am suspecting the Main Board. *** Please Advise me of a Solution.
  • 186 Answers
Sounds like you have a fuser failure. Check the heater lamp, thermal fuse and thermistor. One is probably bad.
Posted on Jun 21, 2007
SOURCE:
How do I clear the 'L' error on my bathroom Salter scale. I have changed the battery but I cannot get the error to clear.
new batteries? or one's that have been sitting around.
they may be low.
what they say to do...
1.
Open the battery compartment on the scale underside.
2.
Remove isolating tab from beneath the battery (if fitted) or insert batteries OBSERVING the polarity signs (+ and -) inside the battery compartment.
3.Close the battery compartment.
4. Select kg, st or lb weight mode by the switch on the
underside of the scale.
5.For use on carpet attach enclosed carpet feet.
6.Position scale on a firm flat surface. next......
INITIALISING YOUR SCALE
1. Press the platform centre and remove your foot.
2.'0.0' will be displayed.
3.The scale will switch off and is now ready for use.
This initialisation process MUST be repeated if the scale is moved. ie battery replacement.
Feb 14, 2018 | Salter Health & Beauty
How do i initialise black toner for 2051c
No need to initialise toner.
When toner low, just replace the toner via the control panel.
Mar 27, 2014 | Toshiba e-Studio 2051C Multifunction...
Minolta ep4000 error code c0400
C0400 -Exposure lamp failure to turn ON
C0410 -Exposure lamp turning on at abnormal timing
Turn OFF the copier,remove the glass,Work a screwdriver trough the hole in the frame at the left front side of the copier and remove the screw that secures the scanner unit.Move the scanner to rhe right hand side of the copier.Remove 3 screws to free the scanner.(To remove the scanner turn it counterclockwise).Remove 1 screw and the wire guide,remove 1 screw and the ground wire.Unplug the exposure lamp terminal connector,unplug the thermal fuse connector.Remove the scanner from the copier.Verify the continuity of the exposure lamp and thermal fuser.If is defective change.
Jan 02, 2013 | Minolta EP4000/5000 CS/PRO Copier
I am unable to make a call or send text messages. When I click on the messages icom it says "sms initialising"
sim needs initialising for 2 min since phone switched on also the contacts lists,
sms initialising error comes if you can delete empty the message sent, inbox, mms stored on your phone due to fulled memory
Jun 16, 2011 | Cell Phones
All service codes for ricoh aficio 1075 are required urgently.
RICOH ERROR CODES
Error Code Description
SC184 CIS Transmission Error
SC191 Bar Code Scanning Error SC192 Automated SBU Adjustment Error/Bar
Code Number is Different SC193 Image Transfer Error/IDU Error
SC194 SBU White Level Detection Error SC195 DF Gate Assert Error/Serial Number Error
Error SC196 DF Gate Negate Error
Code Description
SC197 DF Gate Error SC101 Exposure Lamp Error
SC198 Memory Address Error SC107 Scanner Lamp Regulator Malfunction
SC199 DF Scanning Finish Error SC120 Scanner Home Position Error 1
SC201: Polygon Motor Error HP Sensor Abnormal-Stays Off
SC220 Laser Synchronization Detection Error SC121 Scanner Home Position Error 2
SC221 Scan Length Detection Error HP Sensor Abnormal-Stays On
SC230 BCU Received no Feedback from LD SC122 Scanner Home Position Error 3
F- Gate Error SC123 Scanner Home position Error 4
SC231 Laser Beam Feedback Signal Error SC124 Scanner Motor Encoder Signal Error
F- Gate Timeout SC125 Scanner Motor Speed Error 1
SC240 LD Power Supply Excessive SC126 Scanner Motor Speed Error 2
SC260 HP Sensor Error SC127 Scanner Motor Encoder Rotating Direction
SC261 HP Sensor Not Turning Off Error
SC285 Line Position Error SC128 Scanner Motor Start Error
SC300 Charge Corona Output Error 1 SC129 Scanner Motor Speed Control Error
SC301 Charge Corona Output Error 2 SC130 SBU defective Error/Scanner Start
Charge Current Leak Abnormal
SC302 Charge Corona Output Error 3 SC131 F-Gate Asserted During Shading
Grid Voltage Error Charge Roller Current Leak
SC142: White level detection error. SC303 Charge Corona Output Error 4
SC143 SBU Auto Adjust Error Grid Leak
SC144 SBU Connection Error Charge Cleaner Motor Error SC150 Scanner ROM Mismatch SC304 Charge Roller Current Correction Error SC170 Scanner DA1 Abnormal/Video Processing SC305 Charge Corona Wire Cleaner Error 1
Error 1 SC306 Charge Corona Wire Cleaner Error 2
SC171 Scanner DA2 Abnormal/Video Processing Charge Roller Home Position Error Error 2
SC310 Potential Sensor Calibration Error 1 SC172 Scanner DA3 Abnormal/Video Processing
SC311 Potential Sensor Calibration Error 2 Error 3
SC312 Potential Sensor Calibration Error 3 SC173 Scanner Lamp Regulator Adjustment Error
SC314 Potential Sensor Calibration Error 4 SC174 Scanner DA2 Abnormal
SC315 Potential Sensor Calibration Error 5 SC181 CIS Lamp Abnormal
SC316 Potential Sensor Calibration Error 6 SC183 CIS Auto Adjust Error
SC317 Potential Sensor Calibration Error 7
www.smilecopy.com
Aug 11, 2010 | Ricoh Aficio 450 Copier
Scanner 7580 error P00
Clean the Scanner thoroughly and start doing your work with scanner.
Jan 15, 2009 | Canon DR-7580
Scanner error 6
most likely dust on the scanner optics causing scanner to be unable to go to home position. Solution would be to disassemble scanner assy and clean optics or replace scanner assembly.Note HP service manual says to replace scanner assy.
Dec 16, 2008 | HP LaserJet 3055 All-In-One Printer
Not initialising
Most likely needs firmware update:
You can download it from Transcend's own website:
http://www.transcendusa.com/Support/DLCenter/index.asp
May 19, 2008 | Transcend T.sonic 610 MP3 Player
Open Questions:
See all Canon PC-950 Black and White Copier Questions
Canon PC-950 Black and White Copier Logo
63 people viewed this question
Clive
Clive
old marine
old marine
Ekse
