Question about Philips 42PF7320A 42 in. Plasma HDTV
Lot of color dots with bars
I am thinking it might a ssb board but not really sure
  • twinpack2299 Jan 17, 2009
    so how do i get into the service menu what should i look for thanks
    So how do i do hard reset
  • 11,896 Answers
The TV may have become over-volted from the factory and the voltage settings have to be reduced for the dots to go away.
If you have speakers by the TV it will do the same thing.
You may also have what we call "burn-in" they are ghost-images that appear as bars on your screen
Try Adjust the CONTRAST setting at or below 50%
Most home theater professionals advise that you wash out your screen with your television's anti-burn in calibration after the first 100 hours.You will have to check your owners manual.
My first solution is: Make sure you leave TV unplugged for 4 hours or overnight. You may have to do a couple of resets.
If you get a wide vertical strip it is very rare; it means the horizontal deflection system is weak - but strong enough to produce the high voltage.
I think the full, hard reset will solve your problem. In the worst case, you may have to go into the service mode and readjust some of the settings.
Posted on Jan 17, 2009
  • Nate Stansfield
    Nate Stansfield Jan 17, 2009
    A hard reset is when youunblug thetv for at least 4 hrs. The processor inside resets itself.
    I unfortunately have yet to find a free manual online. I will spend alot more time today searching for one and will let you know if I find one.
    If you would like to purchase one, you can either go to the philips website
    or
    You can go tohttp://www.servicemanuals.net
  • Nate Stansfield
    I believe If you hit your menu button twice
    or go to menu and there should be a picture menu that has:
    brightness
    color
    contrast
    sharpness
Good day. Im getting dots that fill up the tv picture. If I click the menu for the tv the picture gets a lot clearer but the dots fill up again right after I exit the menu. Also on the right side of the tv...
Try replacing the tcon board, below is a link to what I think is the right board but take the back off and make sure that is the right number before ordering as any model set can have multiple boards
Samsung LJ94 03334J BN81 04159A TCon Board 03334J S120APM4C4LV0 4...
Feb 07, 2018 | Samsung Televison & Video
LCD Turns Off after colors go crazy (inverted colors)
If the 5V are 3.3V then either
1) You are not measuring it right
or
2) The problem is at the power board, not the SSB; swollen caps on the power should be seen with ***** eye if that's the case
or
3) The problem is on the SSB board where the 5V are used for bunch of things, including step-down conversion to 3.3V used by bunch of the main processing ICs and likely a step-up conversion needed by the video decoder. Any one of those could be overloading and causing the drop.
But everyone with pro skills with a 2 channel scope should already know all that, wouldn't they?
Sep 24, 2012 | Philips 32PF9830 32 in. HD-Ready LCD...
We have a model HL R4667W--Our picture just went
Hi,Yes your problem sounds like the DMD board.This is how it works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens. Here's a video that will help you find where the DMd chip is located : http://www.youtube.com/watch?v=0jr_9A5Xd2Q Have a blessed one!
May 03, 2010 | Samsung HL-P4667W 46" Rear Projection HDTV
White dots on screen
Hi,Yes your problem sounds like the DMD board.This is how it works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screen. Here's a video that will help you find where the DMd chip is located : http://www.youtube.com/watch?v=0jr_9A5Xd2Q Have a blessed one!
Apr 27, 2010 | Samsung HLS4266 TV
Magnavox projection TV - Sound cuts off when changing channels.
Yea. Your model FP5210 is much older than one with digital SSB board. Still would think that the mute is being activated; probably by the ucontroller/cpu IC.
Apr 14, 2010 | Televison & Video
Whites are real bright and has an orange color
Hi my name is Eric,
I can help you with your issue ,
 This philips TV could have a number off issues, fluid leaking from a CRT,
or the SSB or SSM boards are bad.
I tech will charge you over $350 to replace a board.
There are color adjusters in the back inside the TV , red blue green screen controls, it wouldn't solve your issue , but lowering on may make it watchable for now
If I have helped you with your issue please click accept.
If you have more questions you can still respond
I will reply asap
Thanks
Eric
Oct 07, 2009 | Philips 60PP9202 60" Rear Projection...
Color of picture is bad assume we have to change a bulb. wonder how I was watching a show and girls dress was brown I went upstairs and same show was on and girls dress was actually purple. Football fields...
That is an ATC 222 Chassis and I would highly suspect the problem is in the Ssb rather than a lamp problem. In fact I think you could rule out the lamp all together... The Ssb (small signal board) is p/n# 258761 and takes care of all the color signal decoding. It has also a higher than normal failure rate.
William Rayburn, CET
Premium Technologies
Oct 05, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
42PF5321D/37
Measure the connector from the logic board to the power supply the second pin from the left it will say Vs_ On if the set has 3.1 volts the problem is the SSB or the logic board. On the logic board there should be a solid led and a flashing led that shown that data id flowing and the problem is the SSB. The SSB is easy to replace just remember what you tokk loose and from where. You probely will save money that way. If the set is in warranty or just out of warranty contact Philips 1-888-744-5477 and see what they can do first.
Jun 23, 2008 | Philips 50PFP5332D 50 in. Plasma...
Screen black after big storm...
The set has sound and no picture.If you the SSB could be the issue but the tiny red dots on a black screen will need the panle replaced also. There is a way troble shooting can be done to determine if you will need the SSB or the SSB and the panel.
May 19, 2008 | Philips 42PF9630A 42 in. Plasma Television
Philips 42PF7320A 42 in. Plasma HDTV Logo
144 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
