Question about SanDisk Sansa e250 MP3 Player
NOT working the mp3 is wierd cause everytime i press up it goes down and it turned different colours like white i got it for christmas
  • 8,596 Answers
Call Sandisk the manufacturer to see if it is still in warranty. It sounds like a definite hardware issue to me - if it was just a white screen, I would say LCD controller, but the up/down issue means that it has a serious wiring or other malfunction. You can try my "soft" soultions, but they probably won't work in your case:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jan 17, 2009
Can you fix the colours of the pictures on the screen of my Toshiba Satellite pro P300. It looks like the negative of a colour photograph. Light colours are dark and black is white. Red appears as blue...
In windows 7 , -
1 Go to the ease of access column in the control panel
2 Then go to the link "Turn on high contrast..."
3 Deselect it if it is selected
If it doesnt work then-
1 press Alt+Ctrl+Del
2 On the lower left corner their would be a button to Ease of Access
3 press it and deselect "Turn on high contrast "
This should work cause i tried it on my own computer
Mar 27, 2013 | Toshiba Satellite Computers & Internet
Alba 16inch tv and dvd combi has turned black and white how can i change it back to coulor
Make sure the source is on TV
Press "menu"
quickly type "4725"
select "diagnostic"
choose "factory reset"
If this doesnt get colour back then its broken
Jan 07, 2012 | Alba Televison & Video
Hi i have a 2001 seat ibiza i replaced my standard stereo with a jvc,wierd it all up and switched it on.it stays on for about 30 seconds then turns off and does so everytime i switch it back on.i know the...
Have you checked the switched positive and battery feeds, they can be on different colours in different cars, sometimes they are marked up and are on **** plugs so you can swap them.
Normally Red and Yellow wires, with a fuse connector on each wire.
Let me know if this works.
Oct 17, 2010 | Car Audio & Video
My ipod screen just stays White. My daughter can play Music on the chargeable station. But i turned it off and on and it goes to Clear White Screen everytime.
Try to reset the ipod:
- iPod Classic: Press Menu & Center button at the same time for at least ten seconds
- iPod Touch: Press Center button & top button at the same time for at least ten seconds
Apple logo will appear, and the iPod will be reset (you won't loose your music)
Oct 08, 2009 | Apple iPod touch
Goes white when turned on
try turning it on and leaving that way until the battery is fully discharged.
After that, try connecting it again.
Good luck
Jun 21, 2009 | Philips GoGear SA3125/37 MP3 Player
My sansa is not working
You can try to reset the device by pressing the power button for about 15 to 20 seconds..if that doesnt work I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Dec 21, 2008 | SanDisk Sansa m240 MP3 Player
"Decrypt Error"
Try to re-set. press on/off for more than 10 seconds.
link for manual
Hard drive update downloads
Mar 30, 2008 | RCA H125 MP3 Player
Bright White Screen
just turn of the player pressing the power button for 15 seconds, then turn the hold button on and off; turn it on and it's ready to continue watching
Jan 19, 2008 | SanDisk Sansa e250 MP3 Player
Wierd colours on LCD screen.
Check LCD ribbon cable. 99% LCD ribbon cable is defective. Replace LCD ribbon cable.
Nov 09, 2006 | Panasonic PV-GS31 Mini DV Digital...
SanDisk Sansa e250 MP3 Player Logo
23 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
