Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
I have a new Gallery series Fridigaire side by side refrigerator; the unit works fine, and the water dispenser works fine but the ice maker won't start. Any suggestions?
  • 700 Answers
Turn down the temperature inside of the freezer compartment to -2 degrees /. also make sure that the arm is in the down position.
Posted on Jan 21, 2009
Frigidaire gallery side by side won't send water to ice maker tray, but will to water dispenser
Hello Jim czyryca - From what you are describing if the ice maker is not making ice but is dispensing water, sounds like the refrigerator has a frozen water line, faulty ice maker valve or bad component that sends power to the ice maker valve when needed. The ice maker cycles internally to call for water so I strongly suggest contacting a professional to move forward accurately to assist with the repairs.
Jan 24, 2013 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire Gallery Professionaly series broken ice maker
If you hook up the water to the fridge, that means you connected the water line to the 'Water Inlet Valve' of the machine. There should be a two wire harness connected to the water valve back. Look for that....
But please note following...
Some water valves in fridges are complicated with one harness for water dispenser line valve and another harness for ice maker water line.
Also seeing a disconnected wire harness does not mean it is for the water valve. May be most likely. But be careful sometime there are test wire harness for technicians to get power readings for components.
Oct 25, 2017 | Frigidaire Professional Side By Side...
Chilled Water supplycomes out very slow. Ice maker
Its time for a new filter, the water filter will be in the upper right hand section of the freshfood section, or in the kickplate at the bottom
Jul 15, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
No ice
you can feel for water in ice maker. if not then verify inlet valve function. water inlet valve for ice maker side could be seized up
Jun 22, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire Side by Side Gallery Model Refrigerator
yes where thr water go\es into the ice maker is where the problem lies, take the ice maker out and then you'll see the tuding where the water goes into the ice maker. Then take a hair drier or a shop vac reversed and thae out the utde and the water will flow after it is thawed.
Jan 30, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Water dispenser and ice maker not working
Hi!! tony , yes you have a bad water valve its located on the bottom back of your frig..Replace your water valve..Good luck..
Jan 03, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Sep 25, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Ice maker
Please go into fixya.com and give me a rating,Solution solved ,etc..
Neil
Jul 13, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Side by side gallery ...water leak
  • it sounds like the water valve is not closing fast enough.
  •  this will cause the ice-maker to overflow a little.
  •  your ice-maker may have an adjustment on it to control how long it keeps the water valve on.
  • it should be a screw with a + and - sing on it. it may be under the ice-maker plastic cover.
  • if it keeps doing it then you may need a new water valve.
Jun 29, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
300 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
