Question about Acer Aspire 3610 Notebook
Laptop stalling / CPU overload
My laptop is currently stalling and freezing temporarily, mainly because it seems like the CPU is running at 100% or thereabouts when actually nothing is going on.
I've seen this happen before when a rogue application starts using up all of the CPU. However, what Task Manager says is responsible for the usage is simple applications like Explorer, my antivirus (McAfee), or Task Manager itself.
After turning the computer off for a long while, it seems to operate fine, but then it just happens again after being active for a while.
I've tried searching for adware and spyware, as well as running antivirus searches over and over again.
Any ideas?
    President:
  • 2,692 Answers
Sometimes the best solution is to save to disk the important things and just reinstall everything.
Posted on Jan 17, 2009
Every thing i click on on my desktop starts then
I played around with W8 on an Asus notebook with a 1GHz CPU and found that each programme will open over the top of another.You could have many trying to run and causing the CPU to overload and freeze.
Waiting for the activity to slow from startup by observing the LED activity of the hard drive usually means all startup programmes have loaded and there is less draw on the CPU resources.Trying to access other software while startup is incomplete will compound sluggishness especially if the laptop is a netbook or has a low speed CPU.
If you experience the issue again please wait a few minutes before trying to access or cancel any programme to see if will work through any bottleneck created.
Sep 03, 2014 | Computers & Internet
Overloading CPU
spyware on your system. Download and run superantispyware application on your system in safemode. this is free app found on filehippo.
Jan 23, 2014 | OCZ Pelco Dssrv-090Dvd-Us Ds Nvr W/Dvd Us...
Frozen cursor
The only reason your cursor would "freeze" is your CPU is running at 100%. Press "control-alt-delete" keys at the same time and find the process that overloading the CPU and close it.
If you cursor never moves, your glidepad is broken. Do you have a "stick" to move your cursor? Many Thinkpads do. Usually have a red cap on it and is located near the b g h keys. If the stick doesn't work either, it's the overloaded CPU problem.
Oct 24, 2013 | IBM ThinkPad T42 Notebook
My laptops works perfectly until I want to use the internet. I can connect to the internet fine but internet explorer keeps crashing and runs very slowly. I downloaded Google chrome and the same thing...
It would be great to know how much memory does the laptop has. Usually browsers do take a lot of memory, so if you have limited amount of memory, of course your laptop will slow down and freeze.
I suppose you are running windows.
But you can also monitor and check if the cpu use 100% of it and will also let you know what is causing the cpu to use 100%.
Just search Why is my laptop using 100% cpu
Jun 28, 2017 | Samsung RV520 Laptop
Hp pavilion dv5 1113us overheats and shuts down
OverheatingWhen the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Jul 22, 2012 | HP Pavilion dv5-1113us 15.4" Widescreen...
Freezes almost everyday .wont even turn off.always have to let battery run out then restart next day
When the computer freezes, you can remove the battery physically instead of having to wait the few hours for it to run down. Underneath the laptop are two tabs holding the battery in, just release them and pull it out.
Are you using the machine on a soft surface (bed, couch?) that would allow it to overheat and malfunction when it freezes? Are you overloading the CPU with too many overbearing programs? Perhaps you've got a virus?
You'll need to be more specific about what you are doing when the freezing occurs. This could be anything ranging from software to hardware faults.
May 11, 2011 | Acer Aspire One PC Notebook
My fujitsu laptop wont run on battery
Could you tell us more information. A laptop can't work, A computer does not work for a number of reasons. Not just the battery issue.
Apr 23, 2010 | Fujitsu Siemens AMILO Pro V1000 Notebook
Froze. very slow. very hot
Sounds to me like the cpu fan,has died and the cpu is overheating causing the freeze, the slow running, and the excessive heat. the cpu is probably fried.
Jul 12, 2009 | HP Pavilion dv6000z Notebook
My laptop is freezing for hours at a time.then i shut it down,and retart but it also takes for ever,some times all day is this due to the freezing or is this another problem .and can it also be ovet...
you need do some thing follow:
1) clean the cpu fan and sink(around there dirdy)
2) check the cpu fan is running and stop ok when power on if running go next
3) check the cpu fan, is there any running and stop then see it run again before the laptop freezen?
4) if the fan not running again before freezen that your fan control circuit out of work on the motherboard need to repair
5) if the fan running control ok that the fan can run and stop and run again. you have to add a EXT cooling base under the laptop
hope to help you solve it
May 09, 2009 | Dell Latitude D600 Notebook
Laptop freezing
Check the system status go to the Task Manager and check which are the services running check for CPU speed if it reached 100% then you need to kill some services which is not running , sometimes it happes due to a virus attach , run antivirus and check for space and clear temp files and at last defrag the drive.
Dec 16, 2008 | HP Pavilion dv6000z Notebook
Acer Aspire 3610 Notebook Logo
133 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
