Question about Apple iPod MA446LL/A MP3 Player
My ipod says www.apple.com/support/ipod My computer locked up and so my ipod disconnected before ejecting. At first it locked up bur I reset it. Now it shows a cross and tells me to go to apple.com/support/ipod. Please help, Jen My ipod says [Do not disconnect] It wont power up or power down? Help!!!!
    Problem Solver:
  • 5 Answers
Im not sure if this will work, but, hold the menu button and the select button for about 8 seconds, or until the screen turns off, then u will get the ipod logo, and then it should boot up like normal
Posted on Jan 31, 2009
Unlock
Unlock an iPod Model A1199
Although the second generation iPod Nano (also known as 2G) uses a four-digit pass code that prevents unauthorized access to your iPod by locking the screen, you can also unlock the device by plugging it into your computer's USB 2.0 port.
When the 2G iPod Nano is connected to the computer it is synchronized, and automatically unlocks the screen according to the official Apple site.
In order to successfully unlock the Nano it must be plugged into the primary computer used for synchronizing content.
Click "Start," "All Programs" and "iTunes" on your PC's desktop, or click "iTunes" on the Macintosh's desktop dock.
Plug the iPod Nano's cable into the docking port on the iPod Nano.
Plug the other end into the USB port on the computer to open iTunes.
Click "Controls" at the top of the iTunes' menu, and select "Eject iPod."
The iPod Nano's screen will be unlocked once it is ejected from your computer.
Manual Guide download
http://manuals.info.apple.com/en_US/iPod_nano_2nd_Gen_Features_Guide.pdf
Unlock an iPod Nano Code
With the latest iPod Nano model, you can set a four-digit code and lock all intruders from accessing your iPod.
In order to use the device's functions again, you need to enter the correct code.
However, if you happen to lose or forget the code, you will need to find another way to unlock your iPod Nano.
Plug the iPod USB cable into the bottom of your iPod Nano.
Plug the other end of the USB cable into a free USB port on your Mac or PC computer.
Open the iTunes program by using the Dock on a Mac or the Start menu on a PC.
Select your iPod Nano from the "Devices" list in the main iTunes window.
Click on the "Sync" button to make a connection between your computer and your iPod Nano.
Click on the "Eject" symbol once the syncing process is complete.
Remove your iPod Nano from the USB cable.
The iPod's lock code will now be reset and you will be able to access all features again.
Navigate to the "Screen Lock" option in the iPod menu to lock your iPod's screen again.
Since your iPod's lock code was just reset, you will be prompted to select a new four-digit code.
iPod Support
http://www.apple.com/support/ipod/
Jul 24, 2013 | Apple iPod nano
Ipod is locked on disconnect before ejecting
You just need to reset it, hold down the middle button and the "Menu" button for about 7-8 seconds or until you see the Apple logo.
Hope this helps.
Nov 24, 2009 | Apple iPod nano
Forgot the lock code?is their a bypass code!
I have figured out a stupidly easy way to bypass the screen lock on an iPod. Here's how the feature is supposed to work: You set a combination lock to keep someone from viewing your personal contacts and changing the song. This lock survives a reboot, and can only be reset if you dial in the lock code or plug it into the home computer to which the library is synchronized.
How do you bypass this in case you forgot? Quite simple. Just get another PC or Macintosh. If your iPod Nano is mac formatted, you'll need a copy of MacDrive to view the disk. Ensure that your system is set to view hidden files and folders; this is accomplished much more easily on a windows machine (explorer: tools > options > view > show hidden files)
Steps:
Mount the nano (plug it in)
Navigate to X:\iPod_Control\Device\ (where X is the drive letter of the iPod)
Find the file called "_locked" and open it with Notepad or TextEdit
There's your code.
OR... rename the file to _unlocked
Close Textedit/Notepad, and eject iPod from computer
Jul 17, 2009 | Apple iPod MA446LL/A MP3 Player
Failed to eject before rebooting computer, now USB port says it doesnt recognize the ipod and my ipod is frozen on "Connected-eject before disconnecting"
Actually this issue shouldn't really be that difficult to resolve. :) A simple reset should take care of it being frozen on the connected screen. Below I have posted a step by step on resetting an iPod.
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
As soon as you see the apple icon appear disconnect the iPod from your computer. After the iPod completely loads. reconnect it to make sure it is connecting and loading correctly. If this does not resolve your issue for any reason please do let me know. I have a few other options we could attempt. :) and the feed back is always good. It lets me know if I am actually helping people with they're issue's or not.
May 16, 2009 | Apple iPod nano
I have a nano 8GB- How do I load pictures onto it?
1. To load pictures onto your ipod, you need the itunes software which will easily allow you to put photos onto your ipod.
2. When you get the itunes software, it will have an option in the list where your ipod will be listed for you to eject your ipod. It will be a symbol that looks just like any regular eject button. You could also eject your ipod by going to my computer and right clicking on it, and in the list, select eject.
To get the itunes software, you can go to this website and download it: http://www.apple.com/itunes/download/
Dec 30, 2008 | Apple iPod nano
4GB IPOD locked up
Hey,
have a look here
http://www.fixya.com/support/r561879-code_forgot_code
if that doesn't solve it then look here
http://www.fixya.com/support/r561901-ipod_problems_start_5_solutions
Let me know if you need anything else.
Thanks,
Ekse
Sep 13, 2008 | Apple iPod nano
My ipod says www.apple.com/support/ipod My computer locked up and so my ipod disconnected before ejecting. At first it locked up bur I reset it. Now it shows a cross and tells me to go to...
had a faulty ipod20gb,had a sad ipod face and the web address 4 ipod support,try 2 bang the bottom of ipod.it might have a loose wire.bang it with a table remember 2 but a soft book between the ipod and table,it work on my ipod
Aug 07, 2008 | Audio Players & Recorders
3rd gen nano 4gb
try a reset
To reset your iPod:
  • 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  • 2. Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
read more here
Jun 01, 2008 | Apple iPod nano
My Ipod is frozen
OK what you need to do is reset it. To do this you will need to hold down the menu and select buttons simultaneously for approx 6 seconds until the apple logo appears on the screen. This should reset and un freeze your ipod.
Try this and let me know how you get on.
May 12, 2008 | Apple Mini IPod
My Ipod is frozen
hi there did you try to reset the iPod by holding the MENU and center button?
to do that first lock the itune then press and Hold MENU and Center Button by 7sec. then apple loge appears means the ipod had been reset. ok!
peace!
Dec 15, 2007 | Apple iPod MA446LL/A MP3 Player
Apple iPod MA446LL/A MP3 Player Logo
78 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
