Question about Coleman Propane Forced Air Heater w/Electronic Ignition (50,000-80,000 BTU)
NO HOT WATER ONLY COLD
I have no hotwater flow only cold. i dont knw y...can someone help!!!
  • williamjuani Jan 17, 2009
    I have a coleman evcon dgu08016 i have cold water flow and no hotwater flow(water coming through the pipe). I have an electric hotwater heater and the pilot light is on, it does not fire when we turn on anyhotwater valve in the house. I dont knw what is going on. It has been very cold here in PA the last few days but i do have cold water so no frozen pipes HELPPPP! the furnace is propane forced air....!
  • Allen Neal
    Allen Neal May 11, 2010
    what kind of w/h gas electric or oil, and type if you know
First check to see if your temp. dial is not set on vacation or pilot and set it to hot or very hot which you prefer and it should fire rite-up if not, call a plumber 'cos you have a bigger problem...lazgo
Posted on Jan 20, 2009
  • lazgo Jan 20, 2009
    I was looking at your prob and noticed that w/h is elect.In this case check your breaker box -look for a double breker say 30amp or larger to see if it is tripped-reset if it trips again call a plumber 'cos you have short in the ciucuit---Lazgo
I have a tf325 bosch hotwater heater , problem is the flame will not stop when hotwater is turned off ?? Why and how to fix
After hot water has been drawn, the refill contents have to be heated to a set temperature in anticipation of the next demand. Otherwise, there would be a rush of cold or lukewarm water instead of hot.
Jan 27, 2015 | Bosch Water Heaters
Can i connect hotpolnt aquatic to hot water feed thanks
Yes you could, but the machine is not built for it.
The other problem I see time to time is that the water valve gets stuck due to the heat. Its a cold water valve, not desiged for hot water. (internal gaskets and o-rings dont like heat).
And, your tap hotwater is about 65-80 degrees celsius. Do you want that for all your clothing? I dont think so
May 18, 2014 | Hotpoint Washing Machines
I have an instant hotwater system with the futher most bathroom about 45' away. I am looking at adding a recirculating pump on a timer at the furthermost bathroom to get hotwater quickly in the...
Maybe I am not understanding your problem exactly, but if you have the instant hotwater system installed it should be measuring the temperature of the water in the hot water line and if it drops below the set level it should open the hot water side until the temperature is reached. If it was installed correctly it puts the hot water back into the cold water line so it isn't wasted.
Sep 18, 2011 | Grundfos RCP-96 Recirculation Pump for...
Only get cold water entering washer ... no warm or hot
1. Close hot water valve behind washer.
2. Remove hot water line from washer side and place it in the drain.
3. Open hot water valve to ensure pressure and hotwater is ok in your drain.
4. If not, problem is home related.
5. If pressure and hotwater are ok, then see if your fill valve filter is clogged where you disconnected the hotwater hose attached to the machine.. Its called a fill valve. Sometimes they get clogged.
6. If the hot water side of fill valve looks ok with no blockage, then you might be looking at a new fill valve.
Feb 11, 2010 | Washing Machines
We have a second hand Creda Simplicity W100 washing machine and want to know if it needs to be connected to both the hot and cold water supply or if just the cold can be connected
yes you can just connect the cold water side however you will need to cap off! the hotwater side due to a reverse flow issue when the tub is filling
Jan 17, 2010 | Creda W100FW Front Load Washer
Hot water use on a cold /cold cycle
I bleive hot water in introducted @ begaining of cyle to disolve deterant call whirlpool 800 number .
Oct 26, 2009 | Kenmore 43142 Front Load Washer
We have a customer that has a 751od who says at times thier water gets cold for a few seconds. No error codes on the remote. They claim it does it at different fixtures. Everything checks out from water...
A few things you should check:
1. Cross Connections - this occurs when cold water leaks into the hot water system through a fixture. In order to check for a cross connection: 1) turn off the cold water to the tankless 2) open up hot water fixtures in the home. The water should shut off at all hot water fixtures; if there is a continuous flow of cold water, then you have a cross connection. The most common place to find a cross connection is on old shower cartridges.
2. Ask the customer to check to see if the burner indicator is continuously lit during operation.
3. When the water goes cold at one fixture, try another near by fixture to confirm it is also cold there. If its hot at one fixture but not the other, then you have some issue with you plumbing. Tankless heaters can't pick and choose which fixtures to deliver hot water to.
4. Tankless water heaters all have a minimum flow rate that must be maintained in order to continually fire (.5 gpm for Noritz). Ensure their hot water fixtures flow at least this amount, or that the customer isn't mixing too little hot water at their fixture.
5. If they see the cold spurt during initial firing, they may be experiencing a cold water sandwich. When the heater moves from a standing state to a firing state it takes a short period to ignite and heat water. During this time it will be passing cold water through the system. Usually this cold water mixes with hot water in the line as it travels through the plumbing system, but if their fixture is very close to the heater, there won't be enough time to mix.
6. If debris has gotten into the flow sensor, this can prevent the unit from registering flow and cause intermittent firing.
Aug 27, 2009 | Noritz 7.1 Gpm Natural Ng Gas Tankless Hot...
Fdw20 hotpoint
run the water at the sink till its hot before starting the washer some lines will run cold for about a gallon before the hot water gets to the outlet depending on how far away the hotwater tank is
Feb 15, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Heating & Cooling Logo
43 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
