Question about Sony DCR-HC32E DV Digital Camcorder
Blank Screen I'm having a Sony DCR-HC32E PAL, but its LCD being blank screen immediately. I have no trouble while using an AV cable through TV. I don't know what the problem is.
  • 169 Answers
Flex wire has been cut on the lcd monitor that why you do not see an image..go to the sony service for replacing the flex wire...
Posted on Aug 14, 2007
SOURCE:
Dcr-hc32e no picture on side screen, any solutions ?
There is flexible ribbon wired between lcd board and camcorder board, it seems broken so no image on side lcd screen.
Replace flexible ribbon wire by local camera repair shop because camcorder will take apart for that.
Thanks.
Nov 19, 2010 | Sony Handycam DCR-HC42 Mini DV Digital...
Touch screen dosnot work when I push the key on the monitor and only recording and display
If you still have an image in the LCD but the touchscreen doesn't work, you most likely have a bad LCD flex cable. This would need to be repaired by an experienced technician.
www.austintelstarservices.com
Sep 02, 2010 | Sony DCR-HC32E DV Digital Camcorder
Sir I have digital video camera recorder DCR-TRV265E pal. How can i Download my saved video on my labtop my window is vista . i need a softwear or driver
http://www.sony.co.uk/product/sdh-digital-8/dcr-trv265e
This model seem to have Firewire Port built in.
Then the solution is simple-use Firewire cable to capture video into your laptop.This is the standard hardware set recognized by any OS and most Video Editing software.Simply plug in your cam to your computer via the cable.Your laptop should immediately "see" your cam.The rest is then easy.
Oops...forgot to ask the make&model of your laptop.If it does not have that firewire port built-in.Then you've got quite a trouble...
Jul 04, 2010 | E.Digital Sony DCR-TRV265E camcorder Pal
My Handycam shows a bluish screen(DCR-HC32E)
did you happen to drop the cam? there could be a technical error with the LCD screen. take it to the nearest Sony service center and have them take a look at it. you can try resetting the cam and see if it changes anything.
Jun 11, 2010 | Sony Handycam DCR-HC32 Mini DV Digital...
Touch screen doesn't work
Had the same problem. It's ainternal flex wire connecting LCD with camcorder. Got from the repair shop did it by miself and it's like knew.
It's a common problem as this cable is bend each time when we open the LCD screen, so the cable become faulty. Good luck
Sep 28, 2009 | Sony DCR-HC32E DV Digital Camcorder
LCD gives along with the recording video a lot of red and blue
if your not afraid to work on. first open cam take battery off once the tape loader is open. reseat all the ribbon cables gonig to the lcd.
Jun 01, 2009 | Sony DCR-HC23E DV Digital Camcorder
When connected DCR-SR42 to TV, video and images showing in B&W
yes ur TV might be set to color system PAL /NTSC and ur cam corder in opposite format there is color system changing button on every tv remote just try changing it to PAL or NTSC see if colors work and let me know and pls rate me if i fixed ur problem
Feb 25, 2009 | Sony Handycam DCR-SR40 Camcorder
Sony lcd dcr-hc21e
SONY DCR-HC21E PAL - need copy of original Sony transfer CD. Have uninstalled and lost the disc. Please can anyone help with disc image file?
Sep 26, 2008 | Samsung SONY Handycam DCR-HC21E MiniDV...
Sony DCR-HC32E DV Digital Camcorder Logo
273 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Parshiv Luthra
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
