Question about Linksys EtherFast 10/100 5-Port Auto Sensing Switch [ EZXS55W ] (104835)
Can't get two computes to run internet at the same time
I purchased a Linksys 10/100 5-port workgroup switch EZXS55W. How do I get both systems connected to the internet at the same time?
  • Lyle swartout Feb 06, 2009
    my problem is similar other than i am trying to connect an xbox and a computer but can only run one at a time and thats only after i restart computer or if i want xbox live i need to reset switch box & modem
  • Kevin Shafer
    Kevin Shafer May 11, 2010
    You bought the wrong hardware. What you need is a router, not a switch. A switch will connect all the computers together whereas a router does that and connects them all to the internet.
  • 827 Answers
If you login to your router and make sure DCHP is enabled, and then go to Services (services.msc) on your computers and make sure that the DCHP Client is running, it'll automatically assign IP addresses for your computers and they'll both connect okay.
Hope this helps
Chris (ziraffa)
Posted on Jan 17, 2009
How do i connect two computers so they both have the same ip address i have a linksys 5-port workgroup switch will that work ? also i had hooked it up but only one of my computers had internet
They cannot have the same IP address due to the mechanics of DHCP. Buying a cheap 50$ router (not switch) will fix your problem as your internet service provider will see that device as a single unit that it will assign an IP and then the router will give out internal ip addresses so that they can get online. The switch does not have this functionality.
Feb 16, 2011 | Linksys EZXS55W EtherFast 10/100 5-Port...
I have a linksys cable/dsl router with 4 port switch and also a linksys 16 port workgroup switch. I want to connect 10 computers to the internet with all automatically getting the dumby ip address. Can you...
When your 10 computers are connected to the switch, just make sure your ethernet cable is plugged into the ethernet port. The computers should then have a internet connection
Mar 03, 2018 | Linksys EtherFast 10/100 16-Port Workgroup...
I want to add a LINKSYS workgroup switch EZXS55W behind my wireless routher LINKSYS BEFW11S4 v2 via uplink cable connection. When hardwiring my anything to the switch port 1-4 does not get internet access
Are those 4 ports in different Vlan ?
If you connect your wireless access point to the 1st port are you able to access the internet through 2nd port or 3rd port ?
Are the ports 1-4 admin down ?
Dec 23, 2010 | Linksys Bundle: BEFW11S4 802.11b Wireless...
I have a Linksys 5-port switch connected to a cox cable modem and I'm trying to use it to connect two computers at the same time. Only one works at a time and I have to reset the switch and modem to get...
Because the cox cable modem will only bind to one mac address (computer). You need to purchase a router, any router linksys, dlink, will do, get a wireless one so you can setup wifi as well. Plug your cox cable modem into the wan port on the router, plug your pc into one of the ethernet switch ports, you can use your web browser IE to login to the router and secure your wifi signal, power cycle your modem to make it bind to the new router. Most linksys dlink are programmed for a class c network, you could in theory put 254 devices, computers on your connection now.
Aug 27, 2010 | Linksys EZXS55W EtherFast 10/100 5-Port...
Xbox and laptop cant connect at the same time
your ethernet cable from comcast gets plugged into the wan port of the linksys switch. plug the xbox and laptop to one of the lan ports. the comcast box is a modem/router? without the router it won't assign dhcp addresses
Aug 19, 2017 | Linksys EtherFast EZXS55W 5x10/100 Mbps...
Ps3 and computer wont go online at same time
upgrade the firmwae if it is of old version...!!!
and give static ips to both in your network address range sio that each one can pass through gateway!!
May 27, 2010 | Linksys EZXS55W EtherFast 10/100 5-Port...
How can i use my PS3 and computer at the same time?
plug in your ethernet cables to the 5 port switch
set the ip addess's up too and it should be able to go
on the internet at the same time,
Can u help me retrieve my wifi password?
You need to do a factory reset of your wireless router. This should clear the password in it. There is no password for your 5-port switch.
Nov 18, 2009 | Linksys EZXS55W EtherFast 10/100 5-Port...
EZXS55W 5-Port Workgroup Switch
This is a wired network switch your inquiring about. Is this plugged into a wireless router?
If so what brand is the router.
Jun 10, 2008 | Linksys EtherFast 10/100 5-Port Auto...
Linksys EtherFast 10/100 5-Port Auto Sensing Switch [ EZXS55W ] (104835) Logo
419 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
