Question about HP Officejet 6310 All-In-One InkJet Printer
MAKER PAPER IS JAMED IN PIECES HOW CAN I FIX IT
  • HP Master
  • 13,433 Answers
Try this, its probably a small part of jammed paper or then theres a problem with the pickup, try cleaning it.
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine. ..
Posted on Jun 03, 2009
2 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: paper jamed in fax machine, unabble to retrive
CLICK HERE - about halfway down is how to check the xbias spring, and the whole document is about checking the carriage.
If the small plastic tab in the carriage chute is broken, the x-bias sprint might be dislodged. The broken tab might be in either of the carriage chutes, so check both. 1ef66bf.gif
Thanks for using FixYa!!
Posted on Mar 21, 2009
It says my printer has a paper jam but i dont see no paper jamed and i refill it and it says say thing like it would let it go like its going to print then says jamed paper
Try and see if you can locate a small piece of paper that might be causing your printer to jam. Turn the rollers and see if you can see any small pieces of paper stuck in between the rollers.
Mar 02, 2011 | Canon Pixma iP2600 Photo InkJet Printer
My canon D761 copier does not feed paper. message says "paper jamed" but there isno paper jamed.How do I fix this
paper jam lit when jammed or feeding does not occurs, try cleaning the feed rollers and look if the feed rollers rotates when you copy
Mar 19, 2010 | Canon imageCLASS D761 Copier
After each copie the lights of jamed paper and the first bac of paper are display and i can'tcopie whithout clearing them
1-please check the paper path for any foreign objects droped inside(like pins)or any small pieces of torn paper.
2-check all paper detecting switches for free actuation and nothing prevent it from paper detection.
Nov 28, 2009 | Sharp AR-M205 Copier
Paper jamed
Hi
Thanks for using FixYa. Perform the steps below in order to solve this incidence:
  1. Disconnect the power cord or power supply adaptor from the rear of the HP All-in-One product.
  2. Remove the paper pack remaining in the input tray.
WARNING - Do not try to remove the jammed paper sheet yet. Trying to clear a paper jam from the front of the device can damage the print mechanism. Always clear paper jams through the rear access door.
  1. Open the rear access door or the two-sided printing accessory.
  2. Gently pull the jammed paper sheet out of the rollers.
  3. If the paper tore when it was being removed from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the device. If not all the pieces of paper are removed from the device, paper jams are likely to occur again later.
  4. Replace the rear access door or the two-sided printing accessory.
  5. Restart the printer to continue the current job.
Please seee this link for more details--
HP Photosmart C5280 Paper jam error
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 14, 2009 | HP Photosmart C5280 InkJet Printer
Paper jam
Remove the toner, and try to gently pull out the paper jam.. If the page gets torn, or ripped, make sure you have all the pieces of the paper removed. Then re-start the printer. Print a test page to make sure the paper path is clear..
Nov 21, 2008 | HP LaserJet 4L Printer
Paper jam
hi loadpacker-
sometimes printers have testy sensors that think there are paper jams when there are none. other times products can have tiny pieces of paper in hidden spots that take some finding to fix. here are a couple links that might help.
dealing with general paper jams:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=bud09189&dlc=en&product=304535
general info for your model:
http://h10025.www1.hp.com/ewfrf/wc/product?product=304535&lc=en&cc=us&dlc=en&lang=en&cc=us
general support docs (HP's support site) for your model:
http://h10025.www1.hp.com/ewfrf/wc/solveCategory?lc=en&dlc=en&cc=us&product=304535&lang=en
hope this helps. I usually found that cleaning sensors helped, and using a good grade of paper. some cheaper paper is dusty and sensors are sensitive to running it. hope this helps a little.
-JW50
Nov 04, 2008 | HP DeskJet 3650 InkJet Printer
Panasonic FP-7750 will not feed paper through machine correctly
Look where you remove the last jamed piece of paper closest to the fixing unit. Dose it jame when you make one copy? If it dose jam in the same place, I would have to say the problem is in the fixing unit. Look, in the unit for any pieces of paer jamed and remove them. Also, is it only happen with one paper tray and not the other. If so make sure you haze the tray and paper are set correctly.... Really need some more info.
Aug 05, 2008 | Panasonic FP-7750 Black and White Copier
Paper
Note: Turn Off the machine for Safety Used.
- Check the Fuser Assembly if they have a pieces of paper stuck.
- Reinsert properly the Toner Cartridge Assembly.
- Check all sensor if they have a pieces of paper stuck or dust.
- All assembly and door covers needs to properly inserted.
Let me know if the machine is working?
Jun 17, 2008 | Sharp AL-1655CS Copier
Paper jam
hi this is some small pieces of paper which had gone inside in ur printer when u prints. this one have to contact printer engineer to clean the printer
Mar 02, 2008 | Lexmark X8350 Print, Scan, Copy and Fax...
HP Officejet 6310 All-In-One InkJet Printer Logo
100 people viewed this question
Ben Johnson
