Question about Toshiba Satellite M35X-S161 Notebook
Will not boot
When I turn it on, I hear a series of beep (error code), as follows;
beep.... beep, beep, beep.... beep, beep, beep.... beep (1, 3, 3, 1 beeps)
This happens with or without the battery in place.
Doesn't really matter, I'm down to just wanting to remove the hard drive with the hopes of copying some data off it.
I have googled, etc for weeks to find some kind of diagram and/or instruction on how to get to and remove the hard drive in this guy.
Any direction you may be able to provide would be most welcome.
Regards (and thanks, either way), Mike
    Novelist:
  • 137 Answers
You can find an error code key but if all you want is the hard drive, why not follow these take apart directions.
It looks like it's a normal process: one screw on the bottom and then pulling the drive tray out. If you find that this isn't the case, you might have to take it apart to remove the hard drive. Drop another note here if that doesn't work.
I think the error code you are getting is a memory code. I'm supposing that you haven't tried replacing the memory because you would have mentioned that to save us the hassle of eliminating options you've already tried. I'd try reseating the memory first and then, if that doesn't work, try cleaning the memory chip connections with a pencil eraser to remove oxidization and dirt. Then, if that doesn't work, borrow, steal or beg a matching piece of memory. Sometimes satellites have one piece that you can access under the memory door (on the bottom of the machine) and another piece under the keyboard, so you'll have to look into that.
good lucks.
Posted on Jan 23, 2009
What error is 1 short & 1 long beep on a SR5123WM?
1 long, 1 short BIOS ROM checksum error The contents of the BIOS ROM to not match the expected contents. If possible, reload the BIOS from the PAQ
Welcome to my website
Oct 05, 2014 | Computers & Internet
Why does my computer light come on but want boot and want show a screen and making a beeping sound
In simple terms, you have a hardware failure, probably in your motherboard, hard drive or memory.
The beeps your hearing, are there for a reason. The way it works, is, when you first turn a computer on, it goes through a "Power-on, self test", (know as a POST).
During this period, the BIOS queries the system hardware, such as the hard drive controller, the i/o ports, the memory, etc. and expects to receive back a specific return code which indicates that the specific hardware is running properly.
If it finds a failure in some element of the hardware, it will issue a specific pattern of beeps to tell you which part of the system is failing. (It does this because the system may be unable to display the error on the screen).
Each of the different BIOS manufacturers (BIOS is an acronym for "basic input output system, the hardwired code that talks to the actual hardware), have their own series of short and long beeps, for the different type of failures. So to know where the failure is, you must first know what BIOS manufacture you have in your computer.
Some of the more popular manufacturers are: AMI, Award, IBM, Phoenix, Macintosh, etc.
When you first turn on our computer, the display will report which brand of BIOS you have, and its version.
Once you determine the brand, you can go to any number of web pages that have a cross-reference for the beeps for each brand on BIOS.
I think most adhere to the old IBM PC beep codes as follows:
No beeps: no power, bad CPU,
1 beep: normal
2 beeps: POST/CMOS error
1 long beep, 1-short beep: motherboard problem
1 long beep, 2-short beeps: video problem
1 long beep, 3-short beeps: video problem
3 long beeps: keyboard error
Several long beeps: memory failure (most common fault)
Continuous hi-lo beeps: CPU overheating
You can check with the following websites to get an idea of what's going wrong.
Computer POST and beep codes
How to Diagnose Computer Beeps eHow
Often times a SIMM has come loose in its slot (or corrosion on the connector tabs). If your getting a memory error, you can try opening the box and try re-seating each of the memory Simms to see it that might be the problem. (When you have them out, look at the row of pins along the bottom and see if any look corroded.)
Aug 25, 2014 | E-Machines eMachines Desktop PC
Why does my dell inspiron m5030 laptop give me a series of 5 beeps and wont boot when I try to turn it on?
Please read this:
DELL BEEP CODES
Beep Codes Beep Code Description Failure Coverage 1 System Board: BIOS ROM failure System Board, covers BIOS corruption or ROM error 2 Memory No Memory / RAM detected 3 Chipset Error (North and South Bridge Chipset DMA/IMR/ Timer Error for Intel platform); Chipset Error System Board Chipset Failure Time-Of-Day Clock test failure. Gate A20 failure Super I/O chip failure Keyboard controller test failure. 4 RAM Read/Write failure Memory failure 5 RTC Power Fail. CMOS battery failure 6 Video BIOS Test Failure Video card / chip failure 7 CPU Cache Test Failure CPU failure 8 LCD LCD failure
Jan 12, 2013 | Dell Inspiron M5030 Laptop
When I turn on my dell 9200, a beeping sound starts from the CPU and nothing comes up on the screen
how many beeps you have?if three short beeps its you RAM failure..try to reinsert you RAM or replaced it a new RAM..if theres a long beep..its your video card..
Jul 27, 2011 | Dell Dimension 9200 PC Desktop
Hi there, So, my problem is the following: My pc worked well until i changed my cpu cooler, it didint turn on, i hear only two short bips after i pushed the turn on button (during this the leds are...
Sounds like the CPU may not be seated properly, did you remove the processor when you replaced the cooler (Heatsync I assume you mean)?
Try powering down and unplugging. removing the heat sync removing the processor. Re-seating the processor making sure it falls into place. then re add the thermal paste(if needed) and heat sync. Check the memory and video card to make sure they are firmly in and then power back on and see if it will boot.
Another thing you can do is check your motherboards manual or website and there is a description of "beep codes" that you can listen for yours and see exactly what its telling you is wrong.
Good luck
Jan 24, 2011 | Gigabyte Core 2 Quad Intel X48 FSB 1600...
Everytime i start up the computer it beeps 3-4 times, and the monitor says vga input not connected...whats could be the problem?
here are the beep codes for your exact dell model. this should give you a starting point on finding out what the problem is.
Beep Codes Your computer might emit a series of beeps during start-up if the monitor cannot display errors or problems. This series of beeps, called a beep code, identifies a problem. One possible beep code (code 1-3-1) consists of one beep, a burst of three beeps, and then one beep. This beep code tells you that the computer encountered a memory problem.
Reseating the memory modules may fix the beep code errors in the following table. If the problem persists, see "Contacting Dell" in your Owner's Manual for instructions on obtaining technical assistance.
Code
Cause
1-3-1 through 2-4-4
Memory not being properly identified or used
4-3-1
Memory failure above address 0FFFFh
If you hear one of the following beep codes, see "Contacting Dell" in your Owner's Manual for instructions on obtaining technical assistance.
Code
Cause
1-1-2
Microprocessor register failure
1-1-3
NVRAM
1-1-4
ROM BIOS checksum failure
1-2-1
Programmable interval timer
1-2-2
DMA initialization failure
1-2-3
DMA page register read/write failure
3-1-1
Slave DMA register failure
3-1-2
Master DMA register failure
3-1-3
Master interrupt mask register failure
3-1-4
Slave interrupt mask register failure
3-2-2
Interrupt vector loading failure
3-2-4
Keyboard Controller Test failure
3-3-1
NVRAM power loss
3-3-2
NVRAM configuration
3-3-4
Video Memory Test failure
3-4-1
Screen initialization failure
3-4-2
Screen retrace failure
3-4-3
Search for video ROM failure
4-2-1
No time tick
4-2-2
Shutdown failure
4-2-3
Gate A20 failure
4-2-4
Unexpected interrupt in protected mode
4-3-3
Timer-chip counter 2 failure
4-3-4
Time-of-day clock stopped
4-4-1
Serial or parallel port test failure
4-4-4
Cache test failure
Jan 01, 2011 | Dell Dimension 4600 PC Desktop
When you turn on the computer it makes a series of stringed beeps for a second also when turning it off, keyboard and mouse does not work
what's the beep pateren it does? here is the basic beep codes:.....
Error Code: Faulty Component:
1 short beep None (Normal Boot)
2 short beeps POST error
Non-stop beep Power supply or system board
1 long beep and 1 short beep System board
1 long beep and 2 short beeps Video card
1 long beep and 3 short beeps Memory
3 long beeps Keyboard
Non-stop short beeps Power supply or system board
(a key on the keyboard might
also be stuck)
None Power supply, system board,
or system case built-in speaker
Oct 01, 2010 | Fujitsu Siemens AMILO Pro V2010 Notebook
I was previously surfing the net using Chrome and I had opened many many tabs.. My laptop (Fujitsu Lifebook S Series - S6420) then hung/hannged and I couldn't do anything so I held down the power button to...
Your beep codes are..
1 short beep System is OK
2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem
1 long, 1 short beep System board problem
1 long, 2 short beeps Display adapter problem (MDA, CGA)
1 long, 3 short beeps Display adapter problem (EGA)
3 long beeps 3270 keyboard card .
So looks like a display problem, have you tried any of the recovery/restore options available when you press F8 on boot up
Sep 30, 2010 | Intel S6240 Notebook
At start up, before windows loads, a consistent series of annoying beeping occurs....
If they're occurring right as you turn the computer on, it's your Power On Self Test (aka POST) letting you know. Since I can't be more specific, here's a synopsis of POST beeps:
One single beep followed by three, four, or five beeps -- System-board problems, possibly with DMA, CMOS setup chip, timer, or system bus. The computer usually won't boot when this is the problem.
Two beeps -- The POST numeric code is displayed on the monitor, usually nothing to be concerned about, but you might google the code on another computer and see what you get.
Two beeps followed be three, four, or five beeps -- First 64K of RAM has errors. Solution is to replace RAM.
Three beeps followed by three, four, or five beeps -- Keyboard controller failed or video controller failed. Either you won't be able to see or type with this error.
Four beeps followed by three, four, or five beeps -- Problem with serial or parallel ports, system timer, or time of day. Check your BIOS settings (usually F2 at start up) to make sure everything is correct.
Continuous beeps - problem with power supply. Probably won't do much with this error. At the very best, your computer will boot and run very, very slowly.
Hope that helped.
Sep 01, 2009 | Compaq Computers & Internet
SOLTEK SL-65K2-CT Motherboard
The beep pattern is a beep code and is how the motherboard communicates errors during the early booting process otherwise known as the POST (Power On Self-Test). List restart the computer and listen for the pattern of short and long beeps. Soltek does not list the beep codes in their manual, instead they refer to Phoenix who manufacturers the AwardBIOS on your motherboard. There are only two POST beep codes; a single long beep followed by two short beeps (Video error) and anything else. Apparently anything else you hear *probably* refers to RAM problems. Since you?ve already tested both one of the remaining options is to install a *POST* card (about $30 to $50), boot the PC and read the hexadecimal error code for a more detailed clue to what failed. If you ask around you might find someone who has one and may be willing to loan it to you. Another option is to write off the motherboard since the cost of the test equipment it about 1/3 the cost of a new board. Let us know if you have any other questions and please don?t forget to rate the posing.
Jan 06, 2007 | Soltek SL-65KV2-T Motherboard
Toshiba Satellite M35X-S161 Notebook Logo
396 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
