Question about Electronics - Others
Problems adding memory to e250r
I have a sansa e250r with 2g memory. I bought a kingston 8g micro sd chip and my player will not pick it up or read it at all.
  • 948 Answers
If your firmware is version 1, the largest you can use is a 4Gb card. You need version 3 firmware to use cards up to 16Gb. To check your firmware version, go to Settings>Info.
Posted on Jan 18, 2009
I added a 2gb mirco SD card to my Sansa e270 6.0gb player, but the memory is still only showing 10mb of the original 6.0 gb available for use. How do I get the Sansa to recognize and use the 2 gb mirco SD...
Hi,when you purchase a new micro SD card before use, youwill need to format the memory card so that you will be able to know the actual size of the Micro SD card by checking the details after formatting it.
After formatting the micro SD card and checking the details, if you still do not see the accurate size which is about 1.88mb or the about, that means the micro SD card you bought needs to be replaced. Not a good one.
Have a nice day.
Feb 18, 2011 | SanDisk Sansa e270 MP3 Player
E250r+sd only shows about half of songs from both
Having received no response in over a month, I assume this is no longer a problem.
Jun 08, 2010 | SanDisk Sansa e250 MP3 Player
My sansa fuse reads my micro sd 4g as a 2g how can I fix this
is the micro sd card new? does it hold any information what you can do is find a computer that can hold a sd card and check all folders of the card
Jul 27, 2009 | SanDisk Sansa Fuze MP3 Player
Added 2gb micro card
The player can read the card, but it is not going to add more memory space to the player. The function of the card reader is to enable your player to play songs that you otherwise couldn't play because the hard drive is full.
-Tha Mp3 Doctor
Dec 27, 2008 | SanDisk Sansa e250 MP3 Player
Adding a 8GB MICRO SD card to the Sansa e260
I read somewhere that a 4 GB Micro SD card is the largest you can put in the SanDisk Sansa E260 expansion slot. It's maximum capacity is 8 GB, with internal + external memory put together. This is from what I've read. Hope this helps.
Sep 20, 2008 | SanDisk Sansa e260 MP3 Player
Micro sd 4gb card problems.
Check the Sansa tutorials at
to make sure you have followed all the steps first.
In my experience, every mp3 player/photo frame/etc with a card reader has a MAXIMUM memory limit for the type of card that it can read. It is possible that the Sansa player can only read 2GB Micro SD cards or smaller - and thisi nformation may not have been available when they printed the manual. If you have followed all instructions, and it still will not read the card, try switching to a 2GB Micro SD card.
Mar 22, 2008 | SanDisk Sansa e250 MP3 Player
Memory stick not identified.
The memory stick probably is not the right type. The Sansa only takes SD Micro chips. However, IIRC Micro only goes up to 2GB. So, if you have a 4GB chip is must be a SD HC (High Capacity). Unfortunately, these do not work in the Sansa.
Feb 28, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
4 GB micro sd and the Sandisk Sansa e250R...
If the 4gb micro SD is a high capacity SD (it will say micro SDHC on it) your player may not be able to read SDHC cards, my sansa can't because it's the 'older version' it will read 2gb and below micro SD cards though (it sucked when I found out because I had just bought a 6gb micro SDHC)
Nov 22, 2007 | SanDisk Sansa e250 MP3 Player
Switching USB modes to get to micro sd slot...
You have the newest version, indicated by a V2 on the back of the unit. You do not have the MODE option on your device.
The memory card shows up as part of the total memory, you cannot access it separately.
If you mean on the PC, it does not show up in Windows Media Player 10, but it does in WMP 11. If you are using Rhapsody, it does not show. It also shows up in My Computer as a Sansa e250R, right next to the device.
Best of Luck.
Please RATE my solution BELOW.
Nov 21, 2007 | SanDisk Sansa e250 MP3 Player
4GB micro sd card.
According to what I've read, you can double the original memory, but no more than that, so the max you can have on a Sansa e250 would be 4 GB (2GB internal memory and 2GB external memory). I also read that the micro SD cards holds
music only-no video.
Nov 13, 2007 | SanDisk Sansa e250 MP3 Player
Electronics - Others Logo
144 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
