Question about Autodesk AutoCAD 2002 for PC
Autocad 2002 Fatal Error
Keep getting this message:
Fatal Error Unhandled e06d7363h Exception at 76bfb09eh
    Master:
  • 416 Answers
1Is it on Vista. Try to uninstall the updates
2You can have this error if you use USB drive in previous sessions and dont use it in current. Try to use a USB drive in place, and AuotCad opens fine. It doesn't have to be the same USB drive, Windows just has to have the drive available
Good Luck
Posted on Jan 17, 2009
  • 470 Answers
Almost of you has the same problem,, i have many askers about that problem and they are extremely solve it by looking and analyzing in this blog properly
http://blog.jtbworld.com/2006/12/autocad-error-aborting-fatal-error.html
try to open this blog theres a lot of people who suffering that error, but they are the one who fix it, by sharing there idea's try it,, GO!!
  • Antonio Buenafe Jr.
    Antonio Buenafe Jr. Jan 17, 2009
    this link go with it
    http://blog.jtbworld.com/2006/12/autocad...
    Antonio Buenafe Jr. Jan 22, 2009
    The only way I have found to permanently solve this is to completetly reinstall.
    Novelist:
  • 180 Answers
What were you attempting to do when you get the message?
    President:
  • 2,110 Answers
- If you use AutoCAD's hardware acceleration, please switch it off. Do this
in the AutoCAD Options > System tab > Performance Settings > Manual Tune >
clear the "Enable Hardware acceleration" check box. (Use ... > Performance
Settings > View Tune log to verify the recommendations for your system.)
- Have a look at the entries in Event Viewer to see whether it contains more
details on the error and whether others applications might have problems as
well.
- If you login as Administrator or another user (create a new one and try),
does the error still occurr?
- Reboot the machine in secured mode to see whether the error still occurrs.
If not, make sure your graphic card's and other hardware drivers are using
the latest drivers.
- What other Autodesk products do you have installed (product and version)?
- Is this the only machine with problems? If several, is the hardware
different or the same?
  • 70 Answers
AutoCAD Error Aborting Fatal Error: Unhandled e0434f4dh Exception at 7c81eb33h Solution This error occurs if Autodesk Map Skin is enabled and Microsoft .NET Framework 2.0 is installed on the machine. There are two ways you can correct this issue: At the command prompt, enter MAPSKINMAP to disable the Map Skin. Uninstall .NET Framework 2.0.
  • 6,487 Answers
There is a corrupted file for that software and the best way to resolve that is to uninstall and reinstall the software to your computer...
Find problem in Autocad 2014 while opening a file Fatal error: unhandled delayload "modlr19.dll"Module not found exception at 75bad36fh
Try uninstalling and then run CCleaner to remove any tombstones left over in the registry. Once clean try a fresh install once again.
Nov 25, 2014 | AutoCAD LT 2014 for PC
Fatal error: unhandled e06d7363h exception at 7618c41fh.. What is this and how do I fix it???
Try checking in with the AutoCAD Community for additional visibility and potential solutions.
Philip
AutodeskCare' Community Manager
TW l PI l YT l BLOG
Oct 16, 2012 | Autodesk AutoCAD 2002 for PC
While Removing AutoCad 2006 :FATAL ERROR: Unhandled Delayload "pm8.dll" Module Not Found Exception at 7c81eb33h
This error could be occuring due to the fact that the Application is targetting a dll from an older version.
Uninstall all versions of Revit and Reinstall Revit Architecture 2011 as per the link below:
http://usa.autodesk.com/getdoc/id=TS13712572
I hope this works for you. Kindly reply for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
"Understanding explains better..."
Feb 03, 2011 | Autodesk AutoCAD 2006
Fatal error unhandled c00000fdh exception at 30119435h in autocad 2011
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Fatal-Error-Unhandled-Access-Violation-Reading-0x0000-Exception-at-bcbdad73h.html
Fatal Error while opening AutoCAD Dec 05 2014
Applies to AutoCAD 2009, AutoCAD 2010, AutoCAD 2011, AutoCAD 2012, AutoCAD 2013, AutoCAD 2014, AutoCAD 2015, AutoCAD Architecture 2009, AutoCAD Architecture 2010, AutoCAD Architecture 2011, AutoCAD Architecture 2012, AutoCAD Architecture 2013, AutoCAD Architecture 2014, AutoCAD Architecture 2015, AutoCAD Civil 3D 2009, ...
See More
Issue:
While in the process of starting AutoCAD , a Fatal Error occurs.
Causes:
Fatal errors usually indicate program corruption or a corruption somewhere within the operating system.
Solution:
There are several ways to address the problem: Note: A fatal error can be caused by DisplayLink Core software. If you have this installed on your system, try uninstalling it and then see if this resolves the issue. Additionally, some antivirus or desktop locking programs can cause errors in AutoCAD as they lock the system environment from working. Your antivirus may even need to be uninstalled.
Sep 16, 2010 | Autodesk AutoCAD 2010
When inserting a raster images, receive the "FATAL ERROR Unhandled Access Reading 0x0000 Exception at 10b0961eh" message.
See More
Issue:
Causes:
Solution:
If all of the above solutions fail to resolve the issue, and a full uninstall and reinstall of AutoCAD does not help (see Remove All Products from a Windows System), then you may need to reformat your hard drive and reinstall the operating system.
Article ID: kA230000000tTXu
Sep 15, 2010 | Autodesk AutoCAD 2010
Fatal error
this error points to locked files during startup, only known to me solution is complete removal of autocad from the system, it as well be indication that insufficient or faulty memory in the system.
i would suggest removal of autocad, reboot, install ccleaner, remove of all junk and clean of registry, then clean re-install of autocad,
if you have less than 512mb ram on winxp or less than 1024mb ram on vista, it can be a problem as well.
Jul 26, 2010 | Autodesk AutoCAD 2006
Unhandled e0434f4dh Exception at 7c812a6bh. cannot run AutoCAD software.
Try to uninstall any version of .NET framework installed on the system and install latest version of .NET. You can try to install 3.0 version.
Oct 01, 2009 | Microsoft Windows XP Professional
Autodesk AutoCAD 2002 for PC Logo
3,025 people viewed this question
Top Autodesk Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Clive Gray
Are you an Autodesk Computer and Internet Expert? Answer questions, earn points and help others
