The phone has already attempted to unlock wrong PIN.The phone was asking my Google account and unfortunately I haven't made it yet.How to operate it to reset its factory seetings?
SOURCE: my daughter entered the wrong
For all android devices a google mail account is needed for purchasing apps etc. if he did not set this up and had set the pass code without the email specified the only way to get back into the phone would be to do a complete reset. Before you do this have you tried restarting the device and seeing if it gives you the ability to try to enter the code again, if not here is how to do a factory reset. As stated below this will delete everything on the sd card so i would advise you copy all the files from it onto your computer. the entire process should only take about 10 to 15 minutes depending on the phone sometimes less than this, good luck!
Performing a factory reset (hard reset)
If you're passing your phone on to someone else or your phone has a persistent problem that cannot be solved, you can do a factory reset (also called a hard reset). This returns your phone to the state it was in before the first time you turned it on.
Note: Factory reset will not remove the data and files that are in your phone's microSD card.
Factory reset is not a step to be taken lightly. It will permanently delete all your data and customized settings, and will also remove any applications you've downloaded and installed. Be sure to back up any data and files you want to keep before you do a factory reset.
Performing a factory reset using phone buttons
If you cannot turn on your phone or access the phone settings, you can still perform a factory reset by using the buttons on the phone.
SOURCE: Hi, I need help, I have SAMSUNG Galuxy S (I9000),
Do this but make sure you may wan't to lose files:
1. Turn off the i9000 phone or take out the battery and reinsert it.
2. Hold the Volume Down button
3. Press and release the Power button
4. Select Clear Storage by pressing the Volume Down button
5. Press and release the Power button
6. Press Volume Up to confirm i9000 MATER RESET
Done!
SOURCE: i attempted my unlock pattern to many time now my phone is locked
you will have to do a master reset....you will loose everything on the phone....it is important that you create a google profile, which will back up all your contacts....
if this doesnt work is because your phone doesnt have the harware keys firmware update... need to take it to a repair center and have do a software reflash
SOURCE: samsung galaxy s mobile completely
You can do a complete reset if you want and have no other option(this will erase all your data). To do this follow these steps.
Scroll to wipe data/factory reset using the volume buttons. to select it press the home button
SOURCE: I locked my Kyocera Zio
Hi ashleysmi298 go on your computer and sign in to google. Under settings go to forgot password. You need to get you gmail password. If you don't remember the only other way is to do a hard reset on the phone. But here is the bad news , You will lost all your information and settings apps and whatever else you have on the phone, Now by going to google you can get your password and user name back. If that doesn't work you will need to powwer the phone off. hold the power and the up and down voule button at the same time. You do this until t comes on the screen.Now make sure you take out your memory card . If you don't want to do any of this go to your local carrier and have them help you with the hard reset.
I’m happy to help further over the phone at https://www.6ya.com/expert/ronald_e152e07e272e4f27
how to unlock cherry mobile flare?
how to unlock cherry mobile falare ?
Add a Comment good pm
hey . ?
