Question about Garmin nuvi 255W GPS Receiver
Won't turn on, won't take a charge.
3 months old, has been charging for days and nothing. Have checked the fuse in the charger and it is fine. Is there anyway to bring this back or should it go back to Garmin for a bigger problem.
  • Anonymous Feb 07, 2009
    WONT TURN ON
  • 50 Answers
I would recommend returning it to the store you bought it if their return policy allows. Its much quicker and less hassle. Other wise you will have to send it in to Garmin yourself to have it repaired under warranty.
http://www8.garmin.com/support/warranty.html
Posted on Jan 21, 2009
Nikon s6300 won't turn on
Coolpix Cameras are tricky to use with chargers. I will assume your USB Charger EH-69P is 100 - 240V 50/60 Hz so it CAN work in many places around the world with an adapter. Do not go over 240V or you could damage it.
These cameras like to have the power supply connected when it is on to charge - meaning if you have it connected and you plug the charger in the wall it will NOT charge. So if you plug the charger in the wall first and then plug the cable in the camera it will work. The camera is actually ON when it charges and I never REMOVE the memory card when it is ON.
When you have a dead battery. Plug the camera in and make sure the ON LED lights and the Charge LED flashes. Then don't mess with it. Let it charge completely (Charge LED stops flashing and is OFF) and then unplug it. It will turn off. Then later you can turn it on.
May 08, 2017 | Nikon COOLPIX Cameras
Battery charger on quantum electric wheelchair starts out ember color then starts flashing red I check wires everything is plugged check it about 3 months ago everything was ok now th chair won't
Did you charge it at all during the 3 months? Did you store chair on a full charge? Check to see if batteries are dead. Batteries should be disconnected and/or stored on a full charge. If left connected they should be fully charge every week.
Mar 17, 2013 | Health & Beauty
Samsung N145 Plus battery charge failure
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Sep 03, 2012 | Samsung Computers & Internet
W20i charged phone, took phone off charger, phone went dead and won't turn on. phone is six months old and had no problems
As you have got this problem and cell is only 6 months old. Pls get it replaced under warranty.
Do carry the invoice with date to the service center.
Alternatively also check the charger, as sometime the cell shows charging due to inserting the pin and a low current passes through but still charger is faulty. Try using some other charger and then go ahead.
Regads,
Richee
Take some time to rate me if it works well.
Jun 14, 2011 | Sony Ericsson Cell Phones
Coleman rechargable lantern Model 5327A750. Have not used it in a while have left it on charge for over 24 hours. the night light works but the main light does not go on. Replaced the bulb and still...
just read the charging instructions. Charge for 16-18 hours. If stored for more than 6 months recharge for the full 16 hours. Do not leave the lantern on after the battery has stopped, has overdischarging the battery can cause problems in recharging to a full charge. If this does happen, switch lantern to off and recharge for 40 hours.YES 40 hours. Only the LED is the only light to be used while charging. If you hane the other light on hi or low the battery does not charge.
Hope this helps
Oct 24, 2010 | Sport & Outdoor - Others
My samsung rant wont charge. it charged yesterday but today after plugging it into the charger the Samsung name lights up and then it says "low battery please charge" but it wont charge, i did drop it in...
Phone not charging.
Hello, when a phone does not charge, it means that the phone charger or the port at which the charger is inserted in the phone is faulty.
Might be due to dust or dirt. You can Clean charging port on the phone with a brush and alcohol to remove dirt.
After cleaning it,if still not charging, you can test charger with another phone to be sure if the charger is working. And if charger works with another phone,that means the charging port on the phone is faulty and will need to replaced.
Take care.
Aug 10, 2010 | Cell Phones
2003 Yamaha 650 Classic No power from the battery or a charger.
At 55 amps you could charge the batteries on the space shuttle. A 2 amp charger is plenty. You cooked the three year old battery so a new one will be needed. Get the new battery then worry about the fuses only if the bike is still dead. The fuses are under the battery side cover if I recall correctly. Look under the seat if not by the battery.
Please rate this solution as a " FixYa ". Thanks!
Mar 24, 2009 | 2003 Yamaha V Star Classic
Jet 3 Ultra won't charge
Check the fuses may have a Blown fuse
Regards; Aaron
Sep 16, 2008 | Jet 3 Ultra Power Chair
My phone wont charge
I have the same phone and bought a new charger and it still wont work, it's the phone
Sep 13, 2007 | Samsung SPH-M500 Cellular Phone
Garmin nuvi 255W GPS Receiver Logo
343 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
