Question about Insignia IS-LCDTV32 32 in. Television
I have a 37inch insignia
And I have the blinking green light.
My wife was zapped when she turned the tv off.
Can I fix by replacing the power supply?
  • schultzjs Jan 17, 2009
    Thank-you
  • dazedandc0 May 11, 2010
    how do i test the capasitors? what is the "DM" module?
  • 11,896 Answers
Some people I contacted said it has faulty capacitors that need to be relaced. Available at radio shack.
Most likely causes in order:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
To replace capacitors:
  1. Keep yourself "grounded" when working with the circuit board. Static electricity will destroy electronic components.
  2. When replacing the Capacitors, press them "down" onto the circuit board as far as they will go, hold them down, solder into place and clip the excess terminal lengths flush with solder. Only by doing this will the metal shield (little silver box) slide down and over the circuit board during re-assembly. There is not a lot of clearance when doing this, as the 105C Capacitors are slightly longer that the originals. With minimal effort everything does fit back together.
  3. Use ONLY 105º C capacitors with a voltage rating of 35 V.
  4. Re-insert the DM circuit board into the Mother board; press virmly and ensure a proper seat of the DM board. Next, slide the metal case down and over the DM circuit board.
Posted on Jan 17, 2009
I have a 10 year old Sharp LC-46D62U flat screen tv. The power light continuously blinks green as soon as the power cord is plugged in. There is no video or audio.
TV set power supplies are subject to failure of large capacitors in the power supply which only have a shelf life of about 10 years so your power supply has likely failed. Unfortunately the cost of new TVs these days Baker's such that it's not worth repairing. And there is no simple fix that I know of. I have personally recycled hundreds of these TVs with the similar issues and indication. If you're really serious about it, you can look for a replacement power supply on eBay for the same model. If you have technical abilities than replacing the capacitors would likely fix the power supply. The capacitors are not very expensive but you need to have some technical skills. Any capacitor that has leakage or a raised top even a slight amount is likely bad. Jenna Lee for a repair we replace all the caps. Good luck
Jan 09, 2018 | Sharp Televison & Video
Philips lcd tv dont turn on, blinking green light
Just fixed that exact problem on mine and made a video on what part and how to replace it. I also added a link below for the part I bought. L5973D STMicroelectronics Mouser
Oct 04, 2012 | Philips 37MF321D 37 in. LCD Television
My panasonic th-42pwd8uk tv wont power on. When I press power it clicks to turn on then clicks again and the screen never shows up. No red lights no blinking lights just a solid green light.
Check the capacitors and replace the power components. It is an easy fix if handy with soldering electronics. Tv Repairman may charge less than $100.00 bucks to fix it !
Good luck
Sep 21, 2012 | Panasonic TH-42PWD8UK 42 in. EDTV-Ready...
My question is that my toshiba tv 37inch tv, stop working the tv went blank but the power light is still blinking with no picture. Light still blink green
It may be in safety down mode due to shorted circuits or failed power supply. I would start at the power supply section first by looking for any caps with domed/leaky tops, burnt components, etc.
Please read my guides first;
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: www.interliquidparts.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Jun 26, 2011 | Toshiba Televison & Video
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
I had a power outage and my computer when I tried to turn it back on after the power was turned back on. All it does is have a green light blink on the back of the tower and a small green light on the...
most likely the surge fried one of your ram chips... this is where i would start first sometimes the ram will work as a surge protection for your motherboard
Nov 18, 2010 | Computers & Internet
Blinking red light and tv will not turn on.
problem on power supply , u may have 2 bAD capacitor
Apr 14, 2010 | Philips 42PF9631D 42 in. Plasma Television
Tv turns on green light blinks three times then TV turns off
Ur power supply board is dead.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Apr 07, 2010 | LG 42LC2D 42 in. LCD HDTV
Tv green light is plinking. But tv won't come on, it acts like its.
Power Supply board is dead.Replaced the power supply board will solved this problems.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 20, 2010 | Apex Digital LD1919 19 in. LCD TV
Insignia IS-LCDTV32 32 in. Television Logo
157 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
