Question about Sony Cyber-shot DSC-W55 Digital Camera
When turning on my dscw55 it says access and then does nothing
I cant move pass this point then after a couple of mins it says turn the power off and then on again which i do but then it repeats the whole thing again
how can i get beyond this point?
  • nero555 Jan 20, 2009
    jonjo I have the same fault access then turn off & on again but no joy help!
  • Sony Master
  • 586 Answers
    This problem occurs when the main board which is also called SY-176 board starts malfunctioning and the main cause is (SYSTEM ERROE).   Therefore you have to replace the main board to solve this problem.
  You can contact any sony service centre nearby to you. For your convenience please visit:
www.sony.net
or
www.sonyworld.com
Here you can find contact info of nearest service centres.
Thanks for using FIXYA.
Posted on Jan 31, 2009
Someone hooked remote debugging to my phone n computer. they keep changing pass words how do i stop it
You need to go to your security settings and turn off remote access also you might try to turn off GPS for a couple days.
Feb 19, 2015 | LG Cell Phones
Replaced motor, 1st no oil pressure to guage, but motor seems to have pressure,2nd,replaced radiator, drove 6 miles round trip town and back, flushed radiator,then started and ran motor for couple min,...
As to the oil pressure check your oil pres. sending unit for power with a circuit tester while vehicle is running replace if necessary. First check the fuse for the fuel pump if it has powere on both sides when key is on check the fp relay (when you power a relay if you listen closely or put your finger on it you can normally hear or feel it click which is the equivalent of turning on a standard light switch) if none occur replace or if you can access your fuel pump check for power with key on if it has power but does nothing the pump needs to be replaced
Apr 23, 2011 | 1997 GMC Sierra
The treadmill will turn off while in the middle of a run. After a couple of min. it will turn back on.
hi, please check when machine turn off display is gone or not ,IF display is gone pls check power point, IF display is not gone check the current rating with load ,
Dec 09, 2010 | Spirit Esprit ET-8 Foldable Treadmill
Actiontec (GT704WG) Router wireless access point problem
first of all try to turn the router of, wait for atleast 5 mins and then turn it on, if it still doesnt work,
click on start on the bottom left of ur screen
click on run
type cmd and click on ok
on the black screen type ipconfig
look for ethernet adapter local area connection
take down the default gateway written ther it is usually, 192.168.1.1
open internet explorer, type these no.s on the address bar
it will ask for a username and password, if you havnt changed it
it will be
username:- admin
password:- password
then click on wireless setup and c if wireless is turned on or off, turn it on if its off and then click on apply
if its on already, turn it off and turn it on again
check if this works. else we will have to reset the router but then u will loose all the settings on it done by your isp (if any)
Sep 26, 2009 | Actiontec (GT704WG) Router
Belkin wireless router disconnects from wildblue every 2 min
There are a few things that can cause you to lose wireless connection with your wireless router.
1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the Belkin wireless router away from walls and if possible move the wireless router higher up.
2. Have you secured your wireless router from people near your from unauthorized access? Ie. changes the default password, setup encryption use WAP2 or WAP, change the default SSID, turn off SSID broadcast, and for added protection, enable MAC address filtering which allows the MAC address/es of your wireless card/s to connect to your wireless router.
3. You could be getting interference from electrical sources such as air conditioners, ard welders, washing machines etc. If so the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply) .
4. Check the channels of the wireless routers and access points in your area and and change the broadcast channel on your wireless router to an unused channel or one that has the weakest signal strength. This will minimize the interference with your wireless router from the wireless routers and access points in your area.
Sep 23, 2009 | Belkin (F5D5231-4) Router
Problem with lens
Holding the camera with one hand, gently tap it against a table or desk with the power on. The lense should retract after a couple of taps and work normally after that. It worked for me and I have seen this solution posted at other sites.
Jul 16, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
WRV54G Linksys router right out of box setup and for 5 min no prob then...hell broke loose neither computer had internet access(2 comps and an iTouch) connected via bypassing router and worked fine...
Do you have DSL or cable? Try resetting your router. Press the reset button on the back of the router and hold it it for about 5 seconds. When the router comes back up type in the router address: 192.168.1.1. If your ISP is using cable, make sure that you have DHCP enabled. If DSL, you will have to put in your username and password given to you by your ISP and you will have to enable PPPOE on your router.
Jun 11, 2009 | Linksys Wireless-G WAP54G 802.11g/b...
I cant turn on my tomtom one. I turned the unit on this morning to input a couple of postcodes and turned it off again to save battery life but when I tried to turn it on again 10 mins later it wouldnt...
I found out the problem. The instruction manual does not tell you the unit has a reset button hidden in the back section. It is now working again
It is a little button which requires a fine point or ball point pen to push it. It is in alongside the connectors in the back.
Dec 14, 2008 | GPS
Rainbow vertical lines on screen
THAT HAPPENS WHEN IT GETS TOO HOT, MAYBE YOU HAVE TOO MANY THINGS PLUGGED INTO THE SAME OUTLET
Apr 28, 2008 | Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV
Sony Cyber-shot  DSC-W55 Digital Camera Logo
44 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
