Question about Clover Corporation CDR-4070 Video Recorder
Clover CDR 4170
Any one know how to back up the system to usb flash drive. Customer support indicated to just use a flash drive and hit the back up button. The screens indicate that it should be working but nothing actually saves to the flash drive. Using 1gb flash drive in the USB port in the front.
  • Anonymous Jan 23, 2009
    thanks will try that but again the company indicated no more than 2 gb and to use sandisk stick only... thoughts on that... I just bought the 2 gig.. will let you know how that goes. :)
  • Anonymous Mar 14, 2014
    Saved a video file from a Clover CDR-4170 to a thumb drive. When I plugged it into my computer to view it the video would not play. How can I view the video from my computer?
U need at least a 4gb, then system search, enter the time and date u want to back up press enter, once u have it on screen put flash drive in usb, then hit the back up button.
Posted on Jan 22, 2009
I lost password clover tft2284c
Call the manufacture and see if they have a back door code. If not the only way to reset it is to send back to the manufacturer
Sep 03, 2014 | Clover Corporation CLOVER TFT2284C 22...
When i am coping kingston memory card slowly coping
Hello
OK, firstly you will need to understand that there is a couple of factors which play a role in the transfer speeds to your flash drive from your computer. Firstly, does your computer support USB 1.1 or USB 2.0?
If it only supports USB 1.1 your transfer speed will be round about 1.5 MB/s.
Also, test your memory stick on another computer, and see if the transfer speed is still so slow.
If it is, you can try the following steps to optimize your drive for performance.
  1. Delete all files from the drive.
  2. Go to My Computer and right-click on the flash drive, choosing Properties from the context menu.
  3. In the window that appears, click on the Hardware tab.
  4. Find the flash drive in the list of devices, click on it once and then hit the Properties button.
  5. In the new dialogue, click on the Policies tab.
  6. Select the "Optimize for performance" option if it isn't selected already and hit OK.
  7. Hit OK again to get out of the original Properties dialogue.
  8. Go to My Computer and right-click on the flash drive again, this time choosing the Format option from the context menu.
  9. In the subsequent dialogue, choose the NTFS file system from the drop-down.
  10. Select the Quick Format option.
  11. Hit OK and wait as your flash drive is formatted with the new file system.
  12. When the final dialogue appears, letting you know that the drive has been formatted, you're good to go.
If none of the above works, your circuit of the flash drive is damaged. If still in the warranty period, you need to get it replaced.
Kind regards
Andrea
Nov 24, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
The box is making a sound like its rewinding.
sounds like the harddrive is going bad , its the only moving part inside.
Oct 11, 2010 | Clover Corporation CDR-4070 Video Recorder
My 80 year old father has the CDR 4060 but can't find the manual for it. I need to know how to rewind it to look @ a break in @ his house. Can you tell me how to rewind and play
I believe that the commands are the exact same as using the model 4010.... here is the users manual for teh dvr-4010. See if that helps, if it does, please rate this answer.... :)
Thank you for using fix ya! :)
http://www.retrevo.com/d/ds/progress?doc=4e791b95ba11afe50e14194403e8eeb9
Sep 24, 2009 | Clover Corporation CDR-4060 Video Recorder
Can 't put muisc on the cdr
You prolly got a bad batch return them and choose another brand and yes there refundable or exchangeable... Try a diffrent brand disk ask I had troubles with Memorex and now i use lightscribe and i am glad I did and so would you.. Thanks Rulds2008
___________________________________________
Asker only rate please all other please hold your 2 cents your being logged by fixya.com for unwanted TFT's
May 15, 2009 | Memorex 5PK CDR 700MB 80MIN CD-R80DA...
Problem with my cdr4170
can i connect cdr 4170 to my tv screen?
Dec 26, 2008 | Clover Corporation CDR-4070 Video Recorder
I have a problem with my CDR 4170,is block with the password and i forget these,i can find my cd,
try using the channel buttons...push each button two times.
ch1 twice
ch2 twice
ch3 twice
ch4 twice
Usb not recognised
Hello ak1979 ...
1. You're plugging in your Transend USB flash drive to your computer's USB port (as you've done many times successfully before with this SAME flash drive)?
2. It says "windows not recognise usb drive due to malfunction"?
a. Is that EXECTLY what the error says?
b. Is "it" an error dialog (window that pops up), or an error message from your Windows Event error logs? If a dialog, are there any pertinent error message entries in your Windows Event (System) log [Start > Run > type "eventvwr.msc" (without quotes), then "OK"]?
Try a bit of deductive troubleshooting:
  1. Restart (Reboot) your system [for a fresh start, if you will].
  2. Try plugging in your USB flash drive again, but in a DIFFERENT USB port.
  3. Try plugging in ANY OTHER "known good" USB device into the same USB port(s) used thus far that failed.
NOTE: If you EVER get any indication Windows recognizes the flash drive (like no error msg, or it shows in "My Computer"), IMMEDIATELY perform a "Check Disk" on it:
  1. Start > Run... > type "cmd" (without quotes), then "OK".
  2. Type "chkdsk DRIVE_LTR: /f" (without quotes), then hit "Enter" [where DRIVE_LTR is the drive letter of your USB drive]. EXAMPLE: chkdsk E: /f
Good luck, and please post back:
  • to provide any corrections/updates/clarifications.
  • if you have any further questions.
  • to let me know how things work out.
"Today's the best day of my life...and NOW you're part of it!"
Dec 24, 2008 | Transcend (589307) Media
My laptop is a windows 2000. my mom had this work laptop right. neither of us know the password and it does not have a cdr drive. when i try to copy and paste the windows xp instllaton files to my flash...
there is a software called as alcohol...it makes cd image on your hard disk....first create an image of your xp cd on your system and then try to copy the files to your pen or flash drive..
then connect to the laptop..
thankyou
Aug 19, 2008 | Intel (AXXSCD) (s2894109) Internal 24x...
Can some 1 help me with my fta
Loading Viewsat Ultra Via USB Flash Drive
1. Load File(s) to your USB Flash Drive. (eg.. PFTAUSW-070911U.PGM)
2. Take USB Flash Drive and insert it into Viewsat Ultra USB Port (behind right
side door flap)
3. Using remote Hit Menu. Then Go to System Information -> Receiver Upgrade
and Hit OK
4. Go to USB and Hit OK.
5. You will now see a list of all the files located on your USB Flash Drive. Find the
file you need to load. (eg. PFTAUSW-070911U.PGM) and select it and hit OK.
6. Your Receiver is now being upgraded.
7. It will come up showing you not to power off the unit.
8. Once it has finished the receiver will reboot and you have upgraded your Viewsat
Ultra.
Dec 28, 2007 | Computers & Internet
Clover Corporation CDR-4070 Video Recorder Logo
847 people viewed this question
Top Clover Corporation Televison & Video Experts
Are you a Clover Corporation Televison and Video Expert? Answer questions, earn points and help others
