Back to:
Tags:
Acer TravelMate C312XCi  Tablet PC
Freezing up
posted by Donontherise on Jun 20, 2007
my tablet pc freezes up quite frequently. I have a gig of ram in it and I keep it maintenanced very well.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jun 20, 2007
FixYa! (100)
solocompute
Rank:Master Master
Rating: 82%, 20 votes
A few things to try.
Check the event logs on your PC for Hard drive errors. If the lockups are random they could be caused by bad blocks on your drive in a paging or system file. If you see disk errors, replace the drive immediately and make sure to keep proper backups.
Next, update all drivers, especially the video driver. Often lockups will be caused by Video driver corruption. Dont be scared to install beta versions of drivers for your laptop in an attempt to resolve the problem.
Next, search out a utility boot CD from the internet. There are several, usually running linux but most contain a memory test utility that you want to run for a long period of time (several hours) to see if after a stress period you start getting memory errors.
Next, search for speedfan on google and install it to monitor the temperature on your processor, this problem could be caused by dust buildup on the processor heat sync or cooling fan. Generally it would take some time to have this problem lock up the system, however, after the first lock up and reboot subsequent lockups would happen more quickly.
Many laptop repair depots will do a service for under $100 where they will dissassemble the machine, clean the heat sink and fan (or replace it) and apply new thermal grease.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on freezing up:
I don't want to Accept this solution
Can you Help with these Tablet PCs problems?
Tablet PCs
how to share drives between linux and xp installed on a...
Tablet PCs
dear experts, please help me install my a4tech pk635...
Tablet PCs
I just bought a tablet Genius F350and I use it with Vista....
Tablet PCs
hi i cant get my tablet pen working as it has totally no...
Tablet PCs
shah92 rank: Wiz Solved:74
Loading problems.
Repair Service
Find Tablet PC Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
