Question about Epson Stylus Photo R1800 InkJet Printer
Head cleaning after cartridge change
Every time I change any ink cartridge on my Epson R1800, I have to do a head cleaning. Sometimes it has to go through several cleaning before I can print properly. Some times I have to replace other ink catridges that are somewhat low in ink before it will go through the cleaning process.
  • Simon Jan 20, 2009
    They are all the same, I have run mine on original ink, cheap ink and even a CIS system. They allways need plenty of head cleaning. I am going back to a CIS system, because of the waste when you change a cartridge. I did however download a SSC service programme that works a treat.
    Good luck.
    Simon
  • Epson Master
  • 419 Answers
It sounds like you're trying to force the printer to clean the printhead and only ever partially resolving it before it clogs up again.
Ok... first you need to do is get a decent cleaning solution that can help de-clog the printhead. Usually Windex (the ammoniated version) is a good option but you might want to get some from your ink supplier.
Cleaning cartridges may be worth considerinb BUT I only ever use these are a passive cleaning system, not as active "clean NOW! dagnabit" impatient approaches.
Right, anyway... process is this.
  1. Leave your existing cartridges in
  2. Find a piece of paper kitchen towel or if possible a lint free piece of cloth and soak it in the cleaning solution. Fold into a 2mm or so thick pad.
  3. Move the printhead off the parking pad and out of the way to the left. (usually by starting the printer, waiting for the head to move and then pulling the power cord so you can freely move the printhead).
  4. Place the pad of solution soaked kitchen towel and then move the printhead back to sit over this in the parking pad.
  5. Then go make a cup of tea/coffee, do the ironing, or whatever but leave it alone for at least overnight.
  6. Remove the kitchen towel pad and replace with a fresh one
  7. Leave for a further 12 hours
  8. Remove the pad and turn the printer back on
  9. Run a SINGLE cleaning cycle and then a nozzle check
  10. Let the printer sit for an hour
  11. Try using the printer as normal.
What this approach does is allows the cleaning solution to slowly break down the clog by whicking up into the printhead nozzles and over time turn the hard pigment into a solution again. This requires time so patience is an absolutely essential ingredient.
A few things to note...
  • Obviously don't try to force a thick wad of paper towel under the printhead.. a single fold should be enough
  • DO NOT use the towel to scrape back and forth across the printhead as this will damage the printhead (it is incredibly sensitive and paper towel is more abrasive than you may realise!)
  • The cleaning solution is not just some off the shelf oven cleaner... If in doubt use distilled water and add more time to the process
  • If you're using cleaning cartridges do not use them to force clogs out... Instead allow the solution in them to work on the clog from above in the same way as the pad of solution in the parking pad will work on the clog from below.
Hope this works for you and try to adopt more pro-active measures to reduce the likelihood of clogging ie:
  • move out of particularly hot/warm rooms
  • move away from radiators
  • use the printer regularly (don't leave it idle)
The last one is the kicker... It's a lot like having a dog... They're happier if they're kept exercised so don't save the printer for special photos or whatever, try to use it for the odd graphic, letter too.
Good luck :)
Posted on Feb 18, 2009
Have not used my Epson R1800 for almost 6 months. When I turn on the power the printer head, with the cartridges, stayed at the very right end, not moving. The paper and ink lights flash and the head just...
Your User's Guide is available here:
http://files.support.epson.com/pdf/r1800_/r1800_ug.pdf
After leaving the printer inactive for a extended period you should expect the ink cartridges to be dried up and the print head 'gummed' in place.
You will need to refer to page 82 of the pdf, Cleaning the Printer.
As part of cleaning remove the existing ink cartridges and while the cartridges are removed try and clean the print head of any ink residue. Note that if the red light is on or flashing above an ink cartridge the printer sees it as empty (dried up).
The print head will not move if ink cartridges need replacement; replace ink cartridges according to the red lights, likely all. Press the ink button to see if the printer will begin the charging cycle. If all is well the green power light will stay on and the red ink light will go out.
If you do not get this desired outcome try Cleaning the Print Head, page 73 of the User Guide. Hold down the ink button when the red light is off for 3 seconds. Run a nozzle check pattern; if nozzels are not printing a clean pattern, repeat this process up to 3 or 4 times.
Feb 03, 2011 | Epson Stylus Photo R1800 InkJet Printer
Installed ink cartridge cannot be recognized
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can also be poor ink cartridge contacts
Nov 05, 2010 | Epson Stylus Photo R1800 InkJet Printer
Epson Stylus R1800 is not printing correctly. It is skipping spots leaving clear areas across the page. Changed all the cartridges.
your problem is not with the inks it is with the printhead... try running the maintenance and head cleaning... epson is notorious for print heads getting clogged!! good luck
Mar 31, 2010 | Epson Stylus Photo R1800 InkJet Printer
Epson PictureMate - can't clean all nozzles & Error P
Many times head cleaning will throw much ink away. 1 time about 10% of ink. After meny times head cleaning, ink will out, and need replacement. May be after head cleaning nozzle is ok, but after replacement, printer do ink charge. It may be distrub the flow of ink at head. Is the cartridge new?. Use CISS for continuity printing.
Jul 26, 2009 | Epson PictureMate C11C623001 Photo Printer
My yellow ink head on my r1800 printer is clogged.
If it is within warranty then contact epson support. If not and normal head cleaning doesnt work then try a print head cleaning solution such as:
http://websites.uk-plc.net/UK_Inkjet_Cartridges_PLUS/products/Print_Head_Cleaner.htm
Hope this helps.
Mar 12, 2009 | Epson Stylus Photo R1800 InkJet Printer
Cyan will not print
Try replacing the cartridge. Sometimes they do get clogged and won't clear no matter how many cleaning cycles you run.
....John
Mar 07, 2008 | Epson Stylus Photo R1800 InkJet Printer
How to remove print head of epson stylus photo r1800
Had the same problem - but the print head is actually easy to remove.
1) Remove ink cartridges
2) Remove 3 Phillips head screws at the bottom of the cartridge housing. (looking down from the printer front - top left, bottom left, top right).
3) There are 2 small plastic tabs on a plastic bracket that secure the flex cable on the right hand side of the cartridge housing. Gently release the tabs with a small flat head screw driver.
4) Lift the print head straight up (don't pull on the flex).
There may be a release for the flex to separate from the print head. But I did not see one. Instead I poured 1/4" of Windex in the bottom of a small plastic container and soaked my print head for about 15 minutes (occasionally agitating).
Then put back in reverse order - be sure to seat the flex in the guide (top-back-right) of the cartridge housing before screwing down. Then run a cleaning or two to flush the cleaning fluid out of the print head. (I have a waste ink tank installed so I am not worried about dumping excessive ink into the waste sponges).
The differences was remarkable - though there was still slight banding - maybe should have soaked longer (1 hr perhaps?) - I may repeat if it remains an issue.
Additionally there were large solid deposits on the left side of the print head which were responsible for scraping heavier weight photo paper. These dissolved in the Windex too.
Jan 26, 2008 | Epson Stylus Photo R1800 InkJet Printer
Unused printer
Hi, the print heads are clogged up usually caused by leaving a ink cartridge in the printer when not using it, ie over time, but epson have this problem alot.
you could try this http://www.supermediastore.com/cleaning-cartridge.html
ie if head cleaning dont work,,
this should fix it, otherwise its $48 + vat was the cheapest i found for new print heads or £75 for epson to fix it.
i would replace printer ie if cartridge dont work,,
Happy New Year
John
Dec 14, 2007 | Epson Stylus Photo R1800 InkJet Printer
Epson Stylus Photo R1800 InkJet Printer Logo
300 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
