Question about Canon PowerShot A560 Digital Camera
Hi, My memory card will not unlock...I have tried moving the switch on the side and when I re-insert to view my pics it still says "memory card error card locked". Could you please help me with this issue? Thanks! Jess
  • 6,831 Answers
Hello
If the card works in another camera or another card doesn't work in your camera , the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Sep 27, 2010
Tells me the protection switch is not functioning. i cant take pics or record. i need to know where the reset button is at.
please take out memory card from camera,
check on left side of memory card, there is Lock bar, slide it upward to unlock memory card protection and insert memory card in camera to solve this issue.
Thanks.
Feb 08, 2011 | Cameras
Inserted 4 GB memory card. new camera trying to take a pic and I keep getting the message card protected.
Memory cards particularly SD or SDHC have an option to protect the files from accidentally deletion. This is done by moving the small part of the memory card to the 'lock or unlock' position. Try to look for this small switch on the side of your memory card.
Dec 26, 2010 | Vivitar ViviCam 35 Digital Camera
I bought a canon powershot SD1300 IS camera yesterday. I inserted a 2 GB memory card in to the slot. when i switched on the cam It displays a message no memory card. what should i have to do?
I'm assuming you went through the setup procedures (setting date, time, etc). If you tried to shoot any pics with no card in the camera, you now have pics on the internal memory. You need to get rid of those by going into the menu and finding "format". Then, insert your new card (making sure the slide switch on the side of the card is in the unlocked position) and do the "format" thing again to optimize the new card for the camera.
Sep 23, 2010 | Canon PowerShot SD1300 IS IXUS 105...
Hi experts... I had a Nokia 2700... now I moved to
If you have inserted password in it then you need to put the memory card in your phone to unlock it by entering the password.
If you haven't inserted the password then see the below video how to unlock the memocry card.
http://www.youtube.com/watch#!v=Be_aHSlDFCU&feature=related
Thank You
Aug 14, 2010 | Nokia Classic 2700 Cell Phone
Images lost
Take out the memory card and try to view the pics on the camera. Are they there? If so, your camera is just using the internal memory. You need to download those pics and then format the internal memory. Then, insert your card and all should work.
Jun 30, 2010 | Nikon COOLPIX L3 Digital Camera
How to unlock my memory card
On side of The SD card there is a little lever that slides up and down this is the protection lock. PUSH it all the way to the top. Sometimes when inserting it gets caught and will move just enough to have the camera consider it locked. So be careful when inserting it.
If this does not fix it try another SD card or reformat it.
Please rate my help++++Thanks for using FIXYA
Feb 07, 2010 | Cameras
My memory card locked! i need to know how to unlock it
There is a small switch at the base that needs to be moved to the "Unlocked" position. It's at the side of the card.
Mar 26, 2009 | Cameras
Niken coolpix digital camera
Hi there and welcome to FixYa.
Check your card, there is a little switch on the side of the card. One side says locked and the other side says unlocked. Move the switch to unlocked and put it back in and try it again.
Rob
Mar 04, 2009 | Cameras
Error when turned on, "Memory card error"
if it is an SD or SDC card the check the cord for a lock on the upper left side. This will prevent a lot of functions.
Jan 15, 2009 | Cameras
Card NO formatted
If u get a lock(A small switch on the left side of the card) on ur card try changing its position.Move it to other side.
Oct 25, 2007 | Pentax Optio E30 Digital Camera
Canon PowerShot A560 Digital Camera Logo
41 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
